Marius Posted December 9, 2011 Share Posted December 9, 2011 Hi, yesterday I upgraded my iBook G4 with a SSD. Everything went fine, except for the fact that my trackpad connector 'broke' from my Logic board. I was able to fix it, and I soldered it back to. But since the connector now only is fixed by 4 very tiny SMD solder contacts, I would like to add some extra stability. The only thing I could think of was putting some hot glue against the connector and the PCB. But I don't have experience with that. I am afraid the glue is too hot and will melt solder contacts. I saw on internet a glue-pistol with glue-temperature like 195 degrees CELCIUS. That appears to be rather hot, but again: I do not have any experience. So I hope someone can give me a hint. I know it is not atari related, but I think a lot of experienced electronics people are here, so I asked my question here! Greetz Marius Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 9, 2011 Share Posted December 9, 2011 (edited) Shouldn't be a worry - hot silicone glue melts at a fraction of the temp that solder does. Unsure the exact figure, but probably not much more than that of boiling water. If you wanted to apply at a lower temp, then you could apply it indirectly although it firms up pretty quickly. Or maybe turn the gun off for 10-20 seconds then apply otherwise as normal. Or if you wanted to go the old fashioned way, maybe 2-part araldyte would work, although removing that stuff would probably risk damage. http://en.wikipedia....t-melt_adhesive Looks like there's all manner of types, many being poly/plastic based. So, melting point could be anywhere around 120 - 190 Deg C. ed2 -At the higher end, you 'd be close to the melting point of leaded solder, so maybe testing against something disposable is advisable. Edited December 9, 2011 by Rybags Quote Link to comment Share on other sites More sharing options...
candle Posted December 9, 2011 Share Posted December 9, 2011 i would rather go with epoxy glue than hot glue Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 9, 2011 Share Posted December 9, 2011 If one uses hot melt, it can easily be removed with IPA. Just curious -- is there a similar method for epoxy? -Larry i would rather go with epoxy glue than hot glue Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 9, 2011 Share Posted December 9, 2011 Indian Pale Ale removes hot glue? Great - gonna try this. 1 Quote Link to comment Share on other sites More sharing options...
candle Posted December 10, 2011 Share Posted December 10, 2011 for epoxy - heat it up and pry it loose its getting soft and flexible when heated up (200-250 celcius degrees) and it won't affect plastic parts of connectors at this temperature besides - there is a capton tape to shield these parts Quote Link to comment Share on other sites More sharing options...
