+Larry Posted December 23, 2011 Share Posted December 23, 2011 For use as "pull-ups", LED's, etc. any issues with using 1/8th watt resistors in our A8's? Any particular places to avoid 1/8th watt? -Larry Quote Link to comment Share on other sites More sharing options...
+5-11under Posted December 23, 2011 Share Posted December 23, 2011 Should be fine. P=VI or P=V*V/R (P is power in Watts, V is voltage in volts, I is current in amps, R is resistance in ohms). For instance, if the voltage drop is 3.3V (LED 1.7V, adding up to 5V), and the resistor is 300 ohms, then power is about 0.036 Amps (36 mA, or about 1/27 W). You've got a safety factor of about 3 for a 1/8 Watt resistor. Quote Link to comment Share on other sites More sharing options...
