Farb Posted January 5, 2012 Share Posted January 5, 2012 I've spent some time reverse engineering APE's PRO format to allow SIO2Arduino to support PRO images. I realize there isn't much information around since it's a closed format. I was going to publish the work I've done in hopes that it would be useful to (or potentially be improved) by others. Does anyone see a problem with releasing what information I've gathered? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 5, 2012 Share Posted January 5, 2012 You could ask Steve Tucker (Atarimax), he might just give you the .pro info you need. I don't know whether you're better off supporting .pro or the Vapi stuff - personally when I run a game I just want the thing to function, and don't really care about the nostalgia value of having every single sector read occur just as it did originally. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 5, 2012 Share Posted January 5, 2012 Avery might know some bits as Altirra supports PRO images, he did explain a bit of it to me a long time ago in a easy to understand newbie way Steve as Rybags said is the main man as its his baby in the end... Quote Link to comment Share on other sites More sharing options...
Farb Posted January 5, 2012 Author Share Posted January 5, 2012 I have most of the PRO images that come with APE working properly (Bandits, Jumpman, Karateka, Archon 2, Ballblazer)... although Archon 1 is still giving me trouble for some reason even though it only has one phantom sector and uses phantom mode 2 the same as the others. I'll contact Steve and see if he's willing to help fill in some of the gaps. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 5, 2012 Share Posted January 5, 2012 EA game - they were pretty heavy with the protection. Chances are it could use timing and status bit checks. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 5, 2012 Share Posted January 5, 2012 I seem to remember timing checks, a happy drive had to be put in 'un happy' mode to play it, it also rings a bell from something Mike aka The Mole said about cracking most of the EA titles, they gave him the biggest challenge. Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 6, 2012 Share Posted January 6, 2012 The main problem I have with the .PRO format is that it is not a proper protected disk image format. Instead, as far as I can tell, it encodes the sector load pattern of the loader. This creates the following problems: You cannot recreate a viable physical disk from a .PRO image. The .PRO format either stores or cannot be interpreted without data that could not be inferred from the disk layout itself. This either means that you cannot create a .PRO image without either instrumenting an actual load of the disk -- thus requiring enough of it to be run to hit all of the protected areas of the disk -- or having pre-knowledge of the loader's protection strategy in either the imaging software or the disk emulator. The latter is especially troublesome as it involves direct attacks on specific protections and calling that imaging is questionable. In the general case, blind imaging of a protected disk with an unknown protection into .PRO could be impossible because it could require information that simply is not on the disk (i.e. manual-based protection or randomized sector check pattern). Disk emulation accuracy actually has to be degraded in order to run a .PRO disk, because the phantom sector order has to be obeyed regardless of load timing. In contrast, the VAPI (ATX) format is a more appropriate imaging format because it is simply a representation of the physical disk and it contains enough information to correctly emulate both the timing and order of disk loads. The main problem with it is that the direct way of creating one requires a drive interface that can do a raw track read, which you can't do with a standard 810 disk drive and apparently normally requires an expanded 1050. I believe it would still be possible to create a VAPI image purely with standard SIO disk read commands, but it would involve carefully timing all of the sector reads to determine timing for each sector and to pick up any phantom sectors. Now, regarding the Archon I .PRO image, it turns out that not only can Altirra boot the Archon I .pro image, it can do so with SIO patch enabled. The loader uses SIOV! Here's the disk activity output from the Archon I load: DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=8.73 >> 0.00. DISK: Reading vsec= 2 (1/1) (trk=0), psec= 1, chk=63, rot=8.38 >> 0.50. DISK: Reading vsec= 3 (1/1) (trk=0), psec= 2, chk=fd, rot=8.88 >> 0.06. DISK: Reading vsec= 4 (1/1) (trk=0), psec= 3, chk=f7, rot=8.44 >> 0.56. DISK: Reading vsec= 5 (1/1) (trk=0), psec= 4, chk=3c, rot=8.94 >> 0.11. DISK: Reading vsec= 6 (1/1) (trk=0), psec= 5, chk=ac, rot=8.49 >> 0.61. DISK: Reading vsec= 49 (1/1) (trk=2), psec= 49, chk=6b, rot=9.08 >> 0.33. DISK: Reading vsec= 50 (1/1) (trk=2), psec= 50, chk=fe, rot=9.71 >> 0.83. DISK: Reading vsec= 51 (1/1) (trk=2), psec= 51, chk=b2, rot=10.21 >> 0.39. DISK: Reading vsec= 52 (1/1) (trk=2), psec= 52, chk=7c, rot=10.76 >> 0.89. DISK: Reading vsec= 9 (1/1) (trk=0), psec= 8, chk=23, rot=11.34 >> 0.22. DISK: Reading vsec= 9 (1/1) (trk=0), psec= 8, chk=23, rot=11.60 >> 0.22. DISK: Reading vsec= 10 (1/1) (trk=0), psec= 9, chk=f2, rot=11.60 >> 0.72. DISK: Reading vsec= 11 (1/1) (trk=0), psec= 10, chk=94, rot=12.09 >> 0.28. DISK: Reading vsec= 12 (1/1) (trk=0), psec= 11, chk=0a, rot=12.65 >> 0.78. DISK: Reading vsec= 13 (1/1) (trk=0), psec= 12, chk=f2, rot=13.15 >> 0.33. DISK: Reading vsec= 14 (1/1) (trk=0), psec= 13, chk=f4, rot=13.71 >> 0.83. DISK: Reading vsec= 15 (1/1) (trk=0), psec= 14, chk=be, rot=14.21 >> 0.39. DISK: Reading vsec= 16 (1/1) (trk=0), psec= 15, chk=40, rot=14.76 >> 0.89. DISK: Reading vsec= 17 (1/1) (trk=0), psec= 16, chk=f3, rot=15.26 >> 0.44. DISK: Reading vsec= 18 (1/1) (trk=0), psec= 17, chk=d7, rot=15.82 >> 0.94. DISK: Reading vsec= 19 (1/1) (trk=1), psec= 18, chk=4a, rot=16.32 >> 0.00. DISK: Reading vsec= 20 (1/1) (trk=1), psec= 19, chk=6a, rot=16.37 >> 0.50. DISK: Reading vsec= 21 (1/1) (trk=1), psec= 20, chk=b9, rot=16.87 >> 0.06. DISK: Reading vsec= 22 (1/1) (trk=1), psec= 21, chk=65, rot=16.43 >> 0.56. DISK: Reading vsec= 23 (1/1) (trk=1), psec= 22, chk=65, rot=16.93 >> 0.11. DISK: Reading vsec= 24 (1/1) (trk=1), psec= 23, chk=0a, rot=16.48 >> 0.61. DISK: Reading vsec= 25 (1/1) (trk=1), psec= 24, chk=7b, rot=16.98 >> 0.17. DISK: Reading vsec= 26 (1/1) (trk=1), psec= 25, chk=76, rot=16.54 >> 0.67. DISK: Reading vsec= 27 (1/1) (trk=1), psec= 26, chk=50, rot=17.04 >> 0.22. DISK: Reading vsec= 28 (1/1) (trk=1), psec= 27, chk=d9, rot=17.59 >> 0.72. DISK: Reading vsec= 29 (1/1) (trk=1), psec= 28, chk=98, rot=18.09 >> 0.28. DISK: Reading vsec= 30 (1/1) (trk=1), psec= 29, chk=3f, rot=18.65 >> 0.78. DISK: Reading vsec= 31 (1/1) (trk=1), psec= 30, chk=80, rot=19.15 >> 0.33. DISK: Reading vsec= 32 (1/1) (trk=1), psec= 31, chk=6f, rot=19.71 >> 0.83. DISK: Reading vsec= 33 (1/1) (trk=1), psec= 32, chk=e0, rot=20.21 >> 0.39. DISK: Reading vsec= 34 (1/1) (trk=1), psec= 33, chk=24, rot=20.76 >> 0.89. DISK: Reading vsec= 35 (1/1) (trk=1), psec= 34, chk=94, rot=21.26 >> 0.44. DISK: Reading vsec= 36 (1/1) (trk=1), psec= 35, chk=dd, rot=21.82 >> 0.94. DISK: Reading vsec= 37 (1/1) (trk=2), psec= 36, chk=02, rot=22.32 >> 0.00. DISK: Reading vsec= 38 (1/1) (trk=2), psec= 37, chk=90, rot=22.37 >> 0.50. DISK: Reading vsec= 39 (1/1) (trk=2), psec= 38, chk=f9, rot=22.87 >> 0.06. DISK: Reading vsec= 40 (1/1) (trk=2), psec= 39, chk=6e, rot=22.43 >> 0.56. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=25.30 >> 0.00. DISK: Reading vsec= 9 (1/1) (trk=0), psec= 8, chk=23, rot=25.49 >> 0.22. DISK: Reading vsec= 50 (1/1) (trk=2), psec= 50, chk=fe, rot=25.71 >> 0.83. DISK: Reading vsec= 41 (1/2) (trk=2), psec= 40, chk=ff, rot=30.57 >> 0.11. DISK: Reading vsec= 41 (2/2) (trk=2), psec= 41, chk=df, rot=30.49 >> 1.11. DISK: Reading vsec= 54 (1/1) (trk=2), psec= 54, chk=ab, rot=32.15 >> 0.94. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.36 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.51 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.51 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.50 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.51 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.51 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.52 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.52 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.52 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.49 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.37 >> 0.00. DISK: Reading vsec= 1 (1/1) (trk=0), psec= 0, chk=5d, rot=33.54 >> 0.00. DISK: Reading vsec= 19 (1/1) (trk=1), psec= 18, chk=4a, rot=33.37 >> 0.00. DISK: Reading vsec= 19 (1/1) (trk=1), psec= 18, chk=4a, rot=33.53 >> 0.00. DISK: Reading vsec=145 (1/1) (trk=, psec=145, chk=f0, rot=33.37 >> 0.00. DISK: Reading vsec= 37 (1/1) (trk=2), psec= 36, chk=02, rot=33.53 >> 0.00. DISK: Reading vsec=181 (1/1) (trk=10), psec=181, chk=72, rot=33.37 >> 0.00. DISK: Reading vsec= 55 (1/1) (trk=3), psec= 55, chk=4f, rot=33.52 >> 0.00. DISK: Reading vsec= 37 (1/1) (trk=2), psec= 36, chk=02, rot=33.37 >> 0.00. DISK: Reading vsec= 73 (1/1) (trk=4), psec= 73, chk=87, rot=33.54 >> 0.00. DISK: Reading vsec= 55 (1/1) (trk=3), psec= 55, chk=4f, rot=33.37 >> 0.00. DISK: Reading vsec= 91 (1/1) (trk=5), psec= 91, chk=d3, rot=33.53 >> 0.00. DISK: Reading vsec=145 (1/1) (trk=, psec=145, chk=f0, rot=33.37 >> 0.00. DISK: Reading vsec=109 (1/1) (trk=6), psec=109, chk=2b, rot=33.53 >> 0.00. DISK: Reading vsec= 55 (1/1) (trk=3), psec= 55, chk=4f, rot=33.37 >> 0.00. DISK: Reading vsec= 54 (1/1) (trk=2), psec= 54, chk=ab, rot=33.52 >> 0.94. DISK: Reading vsec= 55 (1/1) (trk=3), psec= 55, chk=4f, rot=34.32 >> 0.00. DISK: Reading vsec= 56 (1/1) (trk=3), psec= 56, chk=27, rot=34.38 >> 0.50. DISK: Reading vsec= 57 (1/1) (trk=3), psec= 57, chk=1a, rot=34.88 >> 0.06. DISK: Reading vsec= 58 (1/1) (trk=3), psec= 58, chk=a8, rot=34.43 >> 0.56. DISK: Reading vsec= 59 (1/1) (trk=3), psec= 59, chk=fd, rot=34.93 >> 0.11. DISK: Reading vsec= 60 (1/1) (trk=3), psec= 60, chk=46, rot=34.49 >> 0.61. DISK: Reading vsec= 61 (1/1) (trk=3), psec= 61, chk=7c, rot=34.99 >> 0.17. DISK: Reading vsec= 62 (1/1) (trk=3), psec= 62, chk=d5, rot=34.54 >> 0.67. DISK: Reading vsec= 63 (1/1) (trk=3), psec= 63, chk=55, rot=35.04 >> 0.22. DISK: Reading vsec= 64 (1/1) (trk=3), psec= 64, chk=6c, rot=35.60 >> 0.72. DISK: Reading vsec= 65 (1/1) (trk=3), psec= 65, chk=1d, rot=36.10 >> 0.28. DISK: Reading vsec= 66 (1/1) (trk=3), psec= 66, chk=a0, rot=36.65 >> 0.78. DISK: Reading vsec= 67 (1/1) (trk=3), psec= 67, chk=d1, rot=37.15 >> 0.33. DISK: Reading vsec= 68 (1/1) (trk=3), psec= 68, chk=ff, rot=37.71 >> 0.83. DISK: Reading vsec= 69 (1/1) (trk=3), psec= 69, chk=98, rot=38.21 >> 0.39. DISK: Reading vsec= 70 (1/1) (trk=3), psec= 70, chk=6e, rot=38.76 >> 0.89. DISK: Reading vsec= 71 (1/1) (trk=3), psec= 71, chk=6e, rot=39.26 >> 0.44. DISK: Reading vsec= 72 (1/1) (trk=3), psec= 72, chk=0d, rot=39.82 >> 0.94. DISK: Reading vsec= 73 (1/1) (trk=4), psec= 73, chk=87, rot=40.32 >> 0.00. DISK: Reading vsec= 74 (1/1) (trk=4), psec= 74, chk=be, rot=40.38 >> 0.50. DISK: Reading vsec= 75 (1/1) (trk=4), psec= 75, chk=ee, rot=40.88 >> 0.06. DISK: Reading vsec= 76 (1/1) (trk=4), psec= 76, chk=fe, rot=40.43 >> 0.56. DISK: Reading vsec= 77 (1/1) (trk=4), psec= 77, chk=f9, rot=40.93 >> 0.11. DISK: Reading vsec= 78 (1/1) (trk=4), psec= 78, chk=72, rot=40.49 >> 0.61. DISK: Reading vsec= 79 (1/1) (trk=4), psec= 79, chk=88, rot=40.99 >> 0.17. DISK: Reading vsec= 80 (1/1) (trk=4), psec= 80, chk=0d, rot=40.54 >> 0.67. DISK: Reading vsec= 81 (1/1) (trk=4), psec= 81, chk=dc, rot=41.04 >> 0.22. DISK: Reading vsec= 82 (1/1) (trk=4), psec= 82, chk=fb, rot=41.60 >> 0.72. DISK: Reading vsec= 83 (1/1) (trk=4), psec= 83, chk=09, rot=42.10 >> 0.28. DISK: Reading vsec= 84 (1/1) (trk=4), psec= 84, chk=4f, rot=42.66 >> 0.78. DISK: Reading vsec= 85 (1/1) (trk=4), psec= 85, chk=e8, rot=43.15 >> 0.33. DISK: Reading vsec= 86 (1/1) (trk=4), psec= 86, chk=aa, rot=43.71 >> 0.83. DISK: Reading vsec= 87 (1/1) (trk=4), psec= 87, chk=1c, rot=44.21 >> 0.39. DISK: Reading vsec= 88 (1/1) (trk=4), psec= 88, chk=60, rot=44.76 >> 0.89. DISK: Reading vsec= 89 (1/1) (trk=4), psec= 89, chk=42, rot=45.26 >> 0.44. DISK: Reading vsec= 90 (1/1) (trk=4), psec= 90, chk=12, rot=45.82 >> 0.94. DISK: Reading vsec= 91 (1/1) (trk=5), psec= 91, chk=d3, rot=46.32 >> 0.00. DISK: Reading vsec= 92 (1/1) (trk=5), psec= 92, chk=4f, rot=46.38 >> 0.50. DISK: Reading vsec= 93 (1/1) (trk=5), psec= 93, chk=52, rot=46.88 >> 0.06. DISK: Reading vsec= 94 (1/1) (trk=5), psec= 94, chk=a7, rot=46.43 >> 0.56. DISK: Reading vsec= 95 (1/1) (trk=5), psec= 95, chk=b5, rot=46.93 >> 0.11. DISK: Reading vsec= 96 (1/1) (trk=5), psec= 96, chk=59, rot=46.49 >> 0.61. DISK: Reading vsec= 97 (1/1) (trk=5), psec= 97, chk=7c, rot=46.99 >> 0.17. DISK: Reading vsec= 98 (1/1) (trk=5), psec= 98, chk=6f, rot=46.54 >> 0.67. DISK: Reading vsec= 99 (1/1) (trk=5), psec= 99, chk=8b, rot=47.04 >> 0.22. DISK: Reading vsec=100 (1/1) (trk=5), psec=100, chk=5e, rot=47.60 >> 0.72. DISK: Reading vsec=101 (1/1) (trk=5), psec=101, chk=ff, rot=48.10 >> 0.28. DISK: Reading vsec=102 (1/1) (trk=5), psec=102, chk=b4, rot=48.65 >> 0.78. DISK: Reading vsec=103 (1/1) (trk=5), psec=103, chk=33, rot=49.15 >> 0.33. DISK: Reading vsec=104 (1/1) (trk=5), psec=104, chk=d6, rot=49.71 >> 0.83. DISK: Reading vsec=105 (1/1) (trk=5), psec=105, chk=88, rot=50.21 >> 0.39. DISK: Reading vsec=106 (1/1) (trk=5), psec=106, chk=51, rot=50.76 >> 0.89. DISK: Reading vsec=107 (1/1) (trk=5), psec=107, chk=83, rot=51.27 >> 0.44. DISK: Reading vsec=108 (1/1) (trk=5), psec=108, chk=fe, rot=51.82 >> 0.94. DISK: Reading vsec=109 (1/1) (trk=6), psec=109, chk=2b, rot=52.32 >> 0.00. DISK: Reading vsec=110 (1/1) (trk=6), psec=110, chk=08, rot=52.38 >> 0.50. DISK: Reading vsec=111 (1/1) (trk=6), psec=111, chk=a2, rot=52.88 >> 0.06. DISK: Reading vsec=112 (1/1) (trk=6), psec=112, chk=04, rot=52.43 >> 0.56. DISK: Reading vsec=113 (1/1) (trk=6), psec=113, chk=5d, rot=52.93 >> 0.11. DISK: Reading vsec=114 (1/1) (trk=6), psec=114, chk=c8, rot=52.49 >> 0.61. DISK: Reading vsec=115 (1/1) (trk=6), psec=115, chk=19, rot=52.99 >> 0.17. DISK: Reading vsec=116 (1/1) (trk=6), psec=116, chk=77, rot=52.54 >> 0.67. DISK: Reading vsec=117 (1/1) (trk=6), psec=117, chk=87, rot=53.04 >> 0.22. DISK: Reading vsec=118 (1/1) (trk=6), psec=118, chk=cf, rot=53.60 >> 0.72. DISK: Reading vsec=119 (1/1) (trk=6), psec=119, chk=35, rot=54.10 >> 0.28. DISK: Reading vsec=120 (1/1) (trk=6), psec=120, chk=3c, rot=54.65 >> 0.78. DISK: Reading vsec=121 (1/1) (trk=6), psec=121, chk=97, rot=55.15 >> 0.33. DISK: Reading vsec=122 (1/1) (trk=6), psec=122, chk=e3, rot=55.71 >> 0.83. DISK: Reading vsec=123 (1/1) (trk=6), psec=123, chk=bb, rot=56.21 >> 0.39. DISK: Reading vsec=124 (1/1) (trk=6), psec=124, chk=52, rot=56.76 >> 0.89. DISK: Reading vsec=125 (1/1) (trk=6), psec=125, chk=87, rot=57.26 >> 0.44. DISK: Reading vsec=126 (1/1) (trk=6), psec=126, chk=70, rot=57.82 >> 0.94. DISK: Reading vsec=127 (1/1) (trk=7), psec=127, chk=ee, rot=58.32 >> 0.00. DISK: Reading vsec=128 (1/1) (trk=7), psec=128, chk=c0, rot=58.38 >> 0.50. DISK: Reading vsec=129 (1/1) (trk=7), psec=129, chk=10, rot=58.88 >> 0.06. DISK: Reading vsec=130 (1/1) (trk=7), psec=130, chk=c1, rot=58.43 >> 0.56. DISK: Reading vsec=131 (1/1) (trk=7), psec=131, chk=02, rot=58.93 >> 0.11. DISK: Reading vsec=132 (1/1) (trk=7), psec=132, chk=f8, rot=58.49 >> 0.61. DISK: Reading vsec=133 (1/1) (trk=7), psec=133, chk=9b, rot=58.99 >> 0.17. DISK: Reading vsec=134 (1/1) (trk=7), psec=134, chk=99, rot=58.54 >> 0.67. DISK: Reading vsec=135 (1/1) (trk=7), psec=135, chk=e3, rot=59.04 >> 0.22. DISK: Reading vsec=136 (1/1) (trk=7), psec=136, chk=bd, rot=59.60 >> 0.72. DISK: Reading vsec=137 (1/1) (trk=7), psec=137, chk=50, rot=60.10 >> 0.28. DISK: Reading vsec=138 (1/1) (trk=7), psec=138, chk=1c, rot=60.65 >> 0.78. DISK: Reading vsec=139 (1/1) (trk=7), psec=139, chk=f7, rot=61.15 >> 0.33. DISK: Reading vsec=140 (1/1) (trk=7), psec=140, chk=65, rot=61.71 >> 0.83. DISK: Reading vsec=141 (1/1) (trk=7), psec=141, chk=9d, rot=62.21 >> 0.39. DISK: Reading vsec=142 (1/1) (trk=7), psec=142, chk=2d, rot=62.76 >> 0.89. DISK: Reading vsec=143 (1/1) (trk=7), psec=143, chk=ae, rot=63.26 >> 0.44. DISK: Reading vsec=144 (1/1) (trk=7), psec=144, chk=30, rot=63.82 >> 0.94. DISK: Reading vsec=145 (1/1) (trk=, psec=145, chk=f0, rot=64.32 >> 0.00. DISK: Reading vsec=146 (1/1) (trk=, psec=146, chk=0a, rot=64.38 >> 0.50. DISK: Reading vsec=147 (1/1) (trk=, psec=147, chk=f9, rot=64.88 >> 0.06. DISK: Reading vsec=148 (1/1) (trk=, psec=148, chk=58, rot=64.43 >> 0.56. DISK: Reading vsec=149 (1/1) (trk=, psec=149, chk=de, rot=64.93 >> 0.11. DISK: Reading vsec=150 (1/1) (trk=, psec=150, chk=76, rot=64.49 >> 0.61. DISK: Reading vsec=151 (1/1) (trk=, psec=151, chk=f6, rot=64.99 >> 0.17. DISK: Reading vsec=152 (1/1) (trk=, psec=152, chk=94, rot=64.54 >> 0.67. DISK: Reading vsec=153 (1/1) (trk=, psec=153, chk=1e, rot=65.04 >> 0.22. DISK: Reading vsec=154 (1/1) (trk=, psec=154, chk=24, rot=65.60 >> 0.72. DISK: Reading vsec=155 (1/1) (trk=, psec=155, chk=bc, rot=66.10 >> 0.28. DISK: Reading vsec=156 (1/1) (trk=, psec=156, chk=34, rot=66.65 >> 0.78. DISK: Reading vsec=157 (1/1) (trk=, psec=157, chk=f1, rot=67.15 >> 0.33. DISK: Reading vsec=158 (1/1) (trk=, psec=158, chk=3f, rot=67.71 >> 0.83. DISK: Reading vsec=159 (1/1) (trk=, psec=159, chk=54, rot=68.21 >> 0.39. DISK: Reading vsec=160 (1/1) (trk=, psec=160, chk=78, rot=68.76 >> 0.89. DISK: Reading vsec=161 (1/1) (trk=, psec=161, chk=0e, rot=69.26 >> 0.44. DISK: Reading vsec=162 (1/1) (trk=, psec=162, chk=3b, rot=69.82 >> 0.94. DISK: Reading vsec=163 (1/1) (trk=9), psec=163, chk=e8, rot=70.32 >> 0.00. DISK: Reading vsec=164 (1/1) (trk=9), psec=164, chk=20, rot=70.38 >> 0.50. DISK: Reading vsec=165 (1/1) (trk=9), psec=165, chk=1c, rot=70.88 >> 0.06. DISK: Reading vsec=166 (1/1) (trk=9), psec=166, chk=b3, rot=70.43 >> 0.56. DISK: Reading vsec=167 (1/1) (trk=9), psec=167, chk=87, rot=70.93 >> 0.11. DISK: Reading vsec=168 (1/1) (trk=9), psec=168, chk=6d, rot=70.49 >> 0.61. DISK: Reading vsec=169 (1/1) (trk=9), psec=169, chk=d9, rot=70.99 >> 0.17. DISK: Reading vsec=170 (1/1) (trk=9), psec=170, chk=3d, rot=70.54 >> 0.67. DISK: Reading vsec=171 (1/1) (trk=9), psec=171, chk=cf, rot=71.04 >> 0.22. DISK: Reading vsec=172 (1/1) (trk=9), psec=172, chk=bf, rot=71.60 >> 0.72. DISK: Reading vsec=173 (1/1) (trk=9), psec=173, chk=1b, rot=72.10 >> 0.28. DISK: Reading vsec=174 (1/1) (trk=9), psec=174, chk=1e, rot=72.65 >> 0.78. DISK: Reading vsec=175 (1/1) (trk=9), psec=175, chk=33, rot=73.16 >> 0.33. DISK: Reading vsec=176 (1/1) (trk=9), psec=176, chk=df, rot=73.71 >> 0.83. DISK: Reading vsec=177 (1/1) (trk=9), psec=177, chk=b0, rot=74.21 >> 0.39. DISK: Reading vsec=178 (1/1) (trk=9), psec=178, chk=6a, rot=74.76 >> 0.89. DISK: Reading vsec=179 (1/1) (trk=9), psec=179, chk=2e, rot=75.26 >> 0.44. DISK: Reading vsec=180 (1/1) (trk=9), psec=180, chk=90, rot=75.82 >> 0.94. DISK: Reading vsec=181 (1/1) (trk=10), psec=181, chk=72, rot=76.32 >> 0.00. DISK: Reading vsec=182 (1/1) (trk=10), psec=182, chk=a6, rot=76.38 >> 0.50. DISK: Reading vsec=183 (1/1) (trk=10), psec=183, chk=06, rot=76.88 >> 0.06. DISK: Reading vsec=184 (1/1) (trk=10), psec=184, chk=0b, rot=76.43 >> 0.56. DISK: Reading vsec=185 (1/1) (trk=10), psec=185, chk=4f, rot=76.93 >> 0.11. DISK: Reading vsec=186 (1/1) (trk=10), psec=186, chk=06, rot=76.49 >> 0.61. DISK: Reading vsec=187 (1/1) (trk=10), psec=187, chk=5a, rot=76.99 >> 0.17. DISK: Reading vsec=188 (1/1) (trk=10), psec=188, chk=0c, rot=76.54 >> 0.67. DISK: Reading vsec=189 (1/1) (trk=10), psec=189, chk=80, rot=77.04 >> 0.22. DISK: Reading vsec=190 (1/1) (trk=10), psec=190, chk=21, rot=77.60 >> 0.72. DISK: Reading vsec=191 (1/1) (trk=10), psec=191, chk=a1, rot=78.10 >> 0.28. DISK: Reading vsec=192 (1/1) (trk=10), psec=192, chk=1a, rot=78.65 >> 0.78. DISK: Reading vsec=193 (1/1) (trk=10), psec=193, chk=dc, rot=79.15 >> 0.33. DISK: Reading vsec=194 (1/1) (trk=10), psec=194, chk=98, rot=79.71 >> 0.83. DISK: Reading vsec=195 (1/1) (trk=10), psec=195, chk=f9, rot=80.21 >> 0.39. DISK: Reading vsec=196 (1/1) (trk=10), psec=196, chk=8e, rot=80.76 >> 0.89. DISK: Reading vsec=197 (1/1) (trk=10), psec=197, chk=7b, rot=81.27 >> 0.44. DISK: Reading vsec=198 (1/1) (trk=10), psec=198, chk=e4, rot=81.82 >> 0.94. DISK: Reading vsec=199 (1/1) (trk=11), psec=199, chk=68, rot=82.32 >> 0.00. DISK: Reading vsec=200 (1/1) (trk=11), psec=200, chk=fd, rot=82.38 >> 0.50. DISK: Reading vsec=201 (1/1) (trk=11), psec=201, chk=0e, rot=82.88 >> 0.06. DISK: Reading vsec=202 (1/1) (trk=11), psec=202, chk=f9, rot=82.43 >> 0.56. DISK: Reading vsec=203 (1/1) (trk=11), psec=203, chk=91, rot=82.93 >> 0.11. DISK: Reading vsec=204 (1/1) (trk=11), psec=204, chk=8e, rot=82.49 >> 0.61. DISK: Reading vsec=205 (1/1) (trk=11), psec=205, chk=11, rot=82.99 >> 0.17. DISK: Reading vsec=206 (1/1) (trk=11), psec=206, chk=02, rot=82.54 >> 0.67. DISK: Reading vsec=207 (1/1) (trk=11), psec=207, chk=69, rot=83.04 >> 0.22. DISK: Reading vsec=208 (1/1) (trk=11), psec=208, chk=8f, rot=83.60 >> 0.72. DISK: Reading vsec=209 (1/1) (trk=11), psec=209, chk=b5, rot=84.10 >> 0.28. DISK: Reading vsec=210 (1/1) (trk=11), psec=210, chk=73, rot=84.65 >> 0.78. DISK: Reading vsec=211 (1/1) (trk=11), psec=211, chk=db, rot=85.15 >> 0.33. DISK: Reading vsec=212 (1/1) (trk=11), psec=212, chk=75, rot=85.71 >> 0.83. DISK: Reading vsec=213 (1/1) (trk=11), psec=213, chk=74, rot=86.21 >> 0.39. DISK: Reading vsec=214 (1/1) (trk=11), psec=214, chk=c0, rot=86.76 >> 0.89. DISK: Reading vsec=215 (1/1) (trk=11), psec=215, chk=51, rot=87.26 >> 0.44. DISK: Reading vsec=216 (1/1) (trk=11), psec=216, chk=ff, rot=87.82 >> 0.94. DISK: Reading vsec=217 (1/1) (trk=12), psec=217, chk=4b, rot=88.32 >> 0.00. DISK: Reading vsec=218 (1/1) (trk=12), psec=218, chk=0b, rot=88.38 >> 0.50. DISK: Reading vsec=219 (1/1) (trk=12), psec=219, chk=2d, rot=88.88 >> 0.06. DISK: Reading vsec=220 (1/1) (trk=12), psec=220, chk=ce, rot=88.43 >> 0.56. DISK: Reading vsec=221 (1/1) (trk=12), psec=221, chk=f5, rot=88.93 >> 0.11. DISK: Reading vsec=222 (1/1) (trk=12), psec=222, chk=ff, rot=88.49 >> 0.61. DISK: Reading vsec=223 (1/1) (trk=12), psec=223, chk=7b, rot=88.99 >> 0.17. DISK: Reading vsec=224 (1/1) (trk=12), psec=224, chk=6c, rot=88.54 >> 0.67. DISK: Reading vsec=225 (1/1) (trk=12), psec=225, chk=39, rot=89.04 >> 0.22. DISK: Reading vsec=226 (1/1) (trk=12), psec=226, chk=35, rot=89.60 >> 0.72. DISK: Reading vsec=227 (1/1) (trk=12), psec=227, chk=27, rot=90.10 >> 0.28. DISK: Reading vsec=228 (1/1) (trk=12), psec=228, chk=81, rot=90.65 >> 0.78. DISK: Reading vsec=229 (1/1) (trk=12), psec=229, chk=3b, rot=91.15 >> 0.33. DISK: Reading vsec=230 (1/1) (trk=12), psec=230, chk=b9, rot=91.71 >> 0.83. DISK: Reading vsec=231 (1/1) (trk=12), psec=231, chk=d5, rot=92.21 >> 0.39. DISK: Reading vsec=232 (1/1) (trk=12), psec=232, chk=11, rot=92.76 >> 0.89. DISK: Reading vsec=233 (1/1) (trk=12), psec=233, chk=66, rot=93.26 >> 0.44. DISK: Reading vsec=234 (1/1) (trk=12), psec=234, chk=44, rot=93.82 >> 0.94. DISK: Reading vsec=235 (1/1) (trk=13), psec=235, chk=ac, rot=94.32 >> 0.00. DISK: Reading vsec=236 (1/1) (trk=13), psec=236, chk=08, rot=94.38 >> 0.50. DISK: Reading vsec=237 (1/1) (trk=13), psec=237, chk=d0, rot=94.88 >> 0.06. DISK: Reading vsec=238 (1/1) (trk=13), psec=238, chk=01, rot=94.43 >> 0.56. DISK: Reading vsec=239 (1/1) (trk=13), psec=239, chk=52, rot=94.93 >> 0.11. DISK: Reading vsec=240 (1/1) (trk=13), psec=240, chk=60, rot=94.49 >> 0.61. DISK: Reading vsec=241 (1/1) (trk=13), psec=241, chk=35, rot=94.99 >> 0.17. DISK: Reading vsec=242 (1/1) (trk=13), psec=242, chk=11, rot=94.54 >> 0.67. DISK: Reading vsec=243 (1/1) (trk=13), psec=243, chk=29, rot=95.04 >> 0.22. DISK: Reading vsec=244 (1/1) (trk=13), psec=244, chk=2c, rot=95.60 >> 0.72. DISK: Reading vsec=245 (1/1) (trk=13), psec=245, chk=d9, rot=96.10 >> 0.28. DISK: Reading vsec=246 (1/1) (trk=13), psec=246, chk=a6, rot=96.65 >> 0.78. DISK: Reading vsec=247 (1/1) (trk=13), psec=247, chk=32, rot=97.15 >> 0.33. DISK: Reading vsec=248 (1/1) (trk=13), psec=248, chk=31, rot=97.71 >> 0.83. DISK: Reading vsec=249 (1/1) (trk=13), psec=249, chk=f7, rot=98.21 >> 0.39. DISK: Reading vsec=250 (1/1) (trk=13), psec=250, chk=f0, rot=98.76 >> 0.89. DISK: Reading vsec=251 (1/1) (trk=13), psec=251, chk=0e, rot=99.26 >> 0.44. DISK: Reading vsec=252 (1/1) (trk=13), psec=252, chk=94, rot=99.82 >> 0.94. DISK: Reading vsec=253 (1/1) (trk=14), psec=253, chk=56, rot=100.32 >> 0.00. Quote Link to comment Share on other sites More sharing options...
serj Posted January 6, 2012 Share Posted January 6, 2012 Can any of you put archives *. pro file with disk images? very difficult to find such images. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 6, 2012 Author Share Posted January 6, 2012 Thanks for SIO dump of the Archon load, phaeron. I didn't know that Altirra could do that! I don't disagree that VAPI/ATX is a better format for imaging copy-protected disks. My problem with it is the same problem I have with the SPS's IPF format -- there's no way for an end-user to create disk images (someone please correct me if I'm mistaken here). I realize that both ATX and IPF are WAY better for creating preservation quality images. When I can personally create an ATX file from a physical disk, it will become more interesting to me. Right now, PRO is the only format that allows me to do that and hence why I want to support it in SIO2Arduino. I personally have a lot of working PRO images I've made from my disk collection and I haven't seen any other hardware-based Atari drive emulators that can load them. Plus, the past few evenings have been a fun lesson in Atari disk copy protection which has always been a fascinating mystery to me. Anyway, my intent with the thread wasn't to be an advocate for the PRO format. It exists for better or for worse and very few people know how it works. I definitely feel it deserves credit for what it is and it would be great for it to be properly documented. I was questioning whether I should help get the ball rolling on that front or whether it would ruffle any feathers. Quote Link to comment Share on other sites More sharing options...
ijor Posted January 6, 2012 Share Posted January 6, 2012 I have most of the PRO images that come with APE working properly (Bandits, Jumpman, Karateka, Archon 2, Ballblazer)... although Archon 1 is still giving me trouble for some reason even though it only has one phantom sector and uses phantom mode 2 the same as the others. If by "phantom" you mean a sector with weak (or fuzzy, or flakey) bits, then Archon doesn't have any. Archon has the older EA protection, the same one in MULE. It has one duplicated sector (possibly Steve used the term phantom for a duplicated sector), and it has skew aligned tracks. Skew align requires rather strict (or at least constant, in this particular case) timing. Now, regarding the Archon I .PRO image, it turns out that not only can Altirra boot the Archon I .pro image, it can do so with SIO patch enabled. The loader uses SIOV! It doesn't surprise me. The way the "skew align" check is implemented, is by checking a more or less constant timing when reading sectors across tracks. It is not uncommon for emulators (and SIO2PC type setups) to "fool" the protection check. As long as every sector read would take the same time (since the previous one), that would make the protection check to pass. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 6, 2012 Author Share Posted January 6, 2012 If by "phantom" you mean a sector with weak (or fuzzy, or flakey) bits, then Archon doesn't have any. Archon has the older EA protection, the same one in MULE. It has one duplicated sector (possibly Steve used the term phantom for a duplicated sector), and it has skew aligned tracks. Skew align requires rather strict (or at least constant, in this particular case) timing. I'm using the same terminology that the PRO format uses. I believe what PRO calls a phantom sector is indeed a duplicated sector -- multiple reads of the same sector return different data. In the case of PRO, it can alternate between 5 sets of additional sector data. It doesn't surprise me. The way the "skew align" check is implemented, is by checking a more or less constant timing when reading sectors across tracks. It is not uncommon for emulators (and SIO2PC type setups) to "fool" the protection check. As long as every sector read would take the same time (since the previous one), that would make the protection check to pass. Interesting, I wasn't familiar with skew alignment... your nice writeup on the VAPI site clarified that for me. I will have to check if the problem lies in my emulation of the duplicate sector or the the timing of sector reads. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 6, 2012 Author Share Posted January 6, 2012 (edited) Now, regarding the Archon I .PRO image, it turns out that not only can Altirra boot the Archon I .pro image, it can do so with SIO patch enabled. The loader uses SIOV! Here's the disk activity output from the Archon I load: Puzzling, when I try booting the Archon I PRO image with Alitirra 2.00 (on a Mac under Parallels), the emulator just crashes around sector 50. It appears that each time I boot, the first sector read after the batch of 21 sector 1 reads is different. I think that jibes with your comment that the loader is using SIOV. I wonder if it's vectoring based on timing or something strange like that? Edited January 6, 2012 by Farb Quote Link to comment Share on other sites More sharing options...
ijor Posted January 7, 2012 Share Posted January 7, 2012 (edited) It appears that each time I boot, the first sector read after the batch of 21 sector 1 reads is different. This is intentional. The protection selects random tracks, and checks that each track is (skew) aligned correctly. I will have to check if the problem lies in my emulation of the duplicate sector or the the timing of sector reads. That's pretty easy if you have some log of the sectors read. If the duplicate sector fails, it would lock immediately at that point. The duplicated sector is sector #41 (see Phaeron dump, it is read twice in a row). Skew align checking is performed later. Edited January 7, 2012 by ijor Quote Link to comment Share on other sites More sharing options...
Farb Posted January 7, 2012 Author Share Posted January 7, 2012 (edited) That's pretty easy if you have some log of the sectors read. If the duplicate sector fails, it would lock immediately at that point. The duplicated sector is sector #41 (see Phaeron dump, it is read twice in a row). Skew align checking is performed later. That makes sense. Here's what I see: 31 52 1 0 84 : READ 1 31 52 2 0 85 : READ 2 31 52 3 0 86 : READ 3 31 52 4 0 87 : READ 4 31 52 5 0 88 : READ 5 31 52 6 0 89 : READ 6 31 52 31 0 B4 : READ 49 31 52 32 0 B5 : READ 50 31 52 33 0 B6 : READ 51 31 52 34 0 B7 : READ 52 31 52 9 0 8C : READ 9 31 52 9 0 8C : READ 9 31 52 A 0 8D : READ 10 31 52 B 0 8E : READ 11 31 52 C 0 8F : READ 12 31 52 D 0 90 : READ 13 31 52 E 0 91 : READ 14 31 52 F 0 92 : READ 15 31 52 10 0 93 : READ 16 31 52 11 0 94 : READ 17 31 52 12 0 95 : READ 18 31 52 13 0 96 : READ 19 31 52 14 0 97 : READ 20 31 52 15 0 98 : READ 21 31 52 16 0 99 : READ 22 31 52 17 0 9A : READ 23 31 52 18 0 9B : READ 24 31 52 19 0 9C : READ 25 31 52 1A 0 9D : READ 26 31 52 1B 0 9E : READ 27 31 52 1C 0 9F : READ 28 31 52 1D 0 A0 : READ 29 31 52 1E 0 A1 : READ 30 31 52 1F 0 A2 : READ 31 31 52 20 0 A3 : READ 32 31 52 21 0 A4 : READ 33 31 52 22 0 A5 : READ 34 31 52 23 0 A6 : READ 35 31 52 24 0 A7 : READ 36 31 52 25 0 A8 : READ 37 31 52 26 0 A9 : READ 38 31 52 27 0 AA : READ 39 31 52 28 0 AB : READ 40 31 52 1 0 84 : READ 1 31 52 9 0 8C : READ 9 31 52 32 0 B5 : READ 50 31 52 29 0 AC : READ 41 31 52 29 0 AC : READ 41 31 52 36 0 B9 : READ 54 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 7F 0 3 : READ 127 31 52 13 0 96 : READ 19 31 52 D9 0 5D : READ 217 31 52 25 0 A8 : READ 37 31 52 1 0 84 : READ 1 31 52 37 0 BA : READ 55 31 52 FD 0 81 : READ 253 31 52 49 0 CC : READ 73 31 52 D9 0 5D : READ 217 31 52 5B 0 DE : READ 91 31 52 7F 0 3 : READ 127 31 52 6D 0 F0 : READ 109 31 52 FD 0 81 : READ 253 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 1 0 84 : READ 1 31 52 A3 0 27 : READ 163 31 52 13 0 96 : READ 19 31 52 A3 0 27 : READ 163 31 52 25 0 A8 : READ 37 31 52 6D 0 F0 : READ 109 31 52 37 0 BA : READ 55 31 52 13 0 96 : READ 19 31 52 49 0 CC : READ 73 31 52 D9 0 5D : READ 217 31 52 5B 0 DE : READ 91 31 52 EB 0 6F : READ 235 31 52 6D 0 F0 : READ 109 31 52 49 0 CC : READ 73 Edited January 7, 2012 by Farb Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 7, 2012 Share Posted January 7, 2012 You should be able to boot it in Altirra 2.00 with default settings (/resetall), followed by setting up and switching to the XL kernel. It will not boot with the built-in kernel due to a custom OS check, and it will not boot with the accurate disk timing option because that overrides .PRO sector ordering. Looking at the dump, you passed the phantom sector check, and I'd say skew is the problem. I don't suppose you have an optimization to avoid hitting the backing store when the sector is already resident on the device? The emulator is running the program in virtualized time and can therefore do or not do I/O effectively instantly, but your device would have to spend real time doing that and you might be getting screwed by the variance. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 7, 2012 Author Share Posted January 7, 2012 Looking at the dump, you passed the phantom sector check, and I'd say skew is the problem. I don't suppose you have an optimization to avoid hitting the backing store when the sector is already resident on the device? The emulator is running the program in virtualized time and can therefore do or not do I/O effectively instantly, but your device would have to spend real time doing that and you might be getting screwed by the variance. Unfortunately, the device only has 8K of RAM so I can't load much data into memory from the backing store. I tried changing my algorithm to load and retain a track's worth of sector data at a time. My hope was that each time a skew check read a sector on a different track, the overall time to read a track and return a sector within it would be fairly consistent. It seems that there is a variance of around 1-2 milliseconds between each skew check read and that doesn't appear to cut it as the image still won't load. Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 7, 2012 Share Posted January 7, 2012 You might need to resort to a time delay to fix this, like padding out the ACK-to-Complete whenever the same sector is re-read or a sector on another track is requested. It'll slow down directory operations in DOS, but you could enable it only with .PRO images and a 5ms delay wouldn't be too bad. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 8, 2012 Author Share Posted January 8, 2012 (edited) That's a good pointer in the right direction, phaeron. As a test, I tried making EVERY sector read consistently take 111ms and that worked. However, trying to make all sector reads take a consistent amount of time (6ms) and all track changes a consistent amount of time (105ms) doesn't work. So there's still something I'm not understanding. For example, here's a log of a failed load: 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111576 us 31 52 2 0 85 : READ 2 Read sector and sent complete in 6160 us 31 52 3 0 86 : READ 3 Read sector and sent complete in 6156 us 31 52 4 0 87 : READ 4 Read sector and sent complete in 6152 us 31 52 5 0 88 : READ 5 Read sector and sent complete in 6152 us 31 52 6 0 89 : READ 6 Read sector and sent complete in 6160 us 31 52 31 0 B4 : READ 49 Changing tracks Read sector and sent complete in 111548 us 31 52 32 0 B5 : READ 50 Read sector and sent complete in 6156 us 31 52 33 0 B6 : READ 51 Read sector and sent complete in 6160 us 31 52 34 0 B7 : READ 52 Read sector and sent complete in 6164 us 31 52 9 0 8C : READ 9 Changing tracks Read sector and sent complete in 111568 us 31 52 9 0 8C : READ 9 Read sector and sent complete in 6156 us 31 52 A 0 8D : READ 10 Read sector and sent complete in 6156 us 31 52 B 0 8E : READ 11 Read sector and sent complete in 6160 us 31 52 C 0 8F : READ 12 Read sector and sent complete in 6164 us 31 52 D 0 90 : READ 13 Read sector and sent complete in 6156 us 31 52 E 0 91 : READ 14 Read sector and sent complete in 6180 us 31 52 F 0 92 : READ 15 Read sector and sent complete in 6156 us 31 52 10 0 93 : READ 16 Read sector and sent complete in 6160 us 31 52 11 0 94 : READ 17 Read sector and sent complete in 6160 us 31 52 12 0 95 : READ 18 Read sector and sent complete in 6156 us 31 52 13 0 96 : READ 19 Changing tracks Read sector and sent complete in 111568 us 31 52 14 0 97 : READ 20 Read sector and sent complete in 6160 us 31 52 15 0 98 : READ 21 Read sector and sent complete in 6152 us 31 52 16 0 99 : READ 22 Read sector and sent complete in 6160 us 31 52 17 0 9A : READ 23 Read sector and sent complete in 6160 us 31 52 18 0 9B : READ 24 Read sector and sent complete in 6160 us 31 52 19 0 9C : READ 25 Read sector and sent complete in 6156 us 31 52 1A 0 9D : READ 26 Read sector and sent complete in 6156 us 31 52 1B 0 9E : READ 27 Read sector and sent complete in 6160 us 31 52 1C 0 9F : READ 28 Read sector and sent complete in 6152 us 31 52 1D 0 A0 : READ 29 Read sector and sent complete in 6164 us 31 52 1E 0 A1 : READ 30 Read sector and sent complete in 6156 us 31 52 1F 0 A2 : READ 31 Read sector and sent complete in 6152 us 31 52 20 0 A3 : READ 32 Read sector and sent complete in 6152 us 31 52 21 0 A4 : READ 33 Read sector and sent complete in 6160 us 31 52 22 0 A5 : READ 34 Read sector and sent complete in 6152 us 31 52 23 0 A6 : READ 35 Read sector and sent complete in 6156 us 31 52 24 0 A7 : READ 36 Read sector and sent complete in 6156 us 31 52 25 0 A8 : READ 37 Changing tracks Read sector and sent complete in 111568 us 31 52 26 0 A9 : READ 38 Read sector and sent complete in 6156 us 31 52 27 0 AA : READ 39 Read sector and sent complete in 6152 us 31 52 28 0 AB : READ 40 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111564 us 31 52 9 0 8C : READ 9 Read sector and sent complete in 6164 us 31 52 32 0 B5 : READ 50 Changing tracks Read sector and sent complete in 111552 us 31 52 29 0 AC : READ 41 Read sector and sent complete in 6160 us 31 52 29 0 AC : READ 41 Using phantom sector Read sector and sent complete in 13952 us 31 52 36 0 B9 : READ 54 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111564 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6152 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6164 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6164 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6152 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6152 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6148 us 31 52 A3 0 27 : READ 163 Changing tracks Read sector and sent complete in 111560 us 31 52 13 0 96 : READ 19 Changing tracks Read sector and sent complete in 111552 us 31 52 37 0 BA : READ 55 Changing tracks Read sector and sent complete in 111560 us 31 52 25 0 A8 : READ 37 Changing tracks Read sector and sent complete in 111552 us 31 52 6D 0 F0 : READ 109 Changing tracks Read sector and sent complete in 111552 us 31 52 37 0 BA : READ 55 Changing tracks Read sector and sent complete in 111548 us 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111568 us 31 52 49 0 CC : READ 73 Changing tracks Read sector and sent complete in 111552 us 31 52 FD 0 81 : READ 253 Changing tracks Read sector and sent complete in 111540 us 31 52 5B 0 DE : READ 91 Changing tracks Read sector and sent complete in 111552 us 31 52 6D 0 F0 : READ 109 Changing tracks Read sector and sent complete in 111572 us 31 52 6D 0 F0 : READ 109 Read sector and sent complete in 6160 us 31 52 D9 0 5D : READ 217 Changing tracks Read sector and sent complete in 111540 us 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111564 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6148 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6164 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6152 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6164 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6164 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6156 us 31 52 1 0 84 : READ 1 Read sector and sent complete in 6160 us 31 52 D9 0 5D : READ 217 Changing tracks Read sector and sent complete in 111544 us 31 52 13 0 96 : READ 19 Changing tracks Read sector and sent complete in 111556 us 31 52 A3 0 27 : READ 163 Changing tracks Read sector and sent complete in 111560 us 31 52 25 0 A8 : READ 37 Changing tracks Read sector and sent complete in 111552 us 31 52 1 0 84 : READ 1 Changing tracks Read sector and sent complete in 111560 us 31 52 37 0 BA : READ 55 Changing tracks Read sector and sent complete in 111552 us 31 52 6D 0 F0 : READ 109 Changing tracks Read sector and sent complete in 111552 us 31 52 49 0 CC : READ 73 Changing tracks Read sector and sent complete in 111552 us 31 52 6D 0 F0 : READ 109 Changing tracks Read sector and sent complete in 111548 us 31 52 5B 0 DE : READ 91 Changing tracks Read sector and sent complete in 111556 us 31 52 7F 0 3 : READ 127 Changing tracks Read sector and sent complete in 111580 us 31 52 6D 0 F0 : READ 109 Changing tracks Read sector and sent complete in 111552 us 31 52 49 0 CC : READ 73 Changing tracks Read sector and sent complete in 111548 us Edited January 8, 2012 by Farb Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 8, 2012 Share Posted January 8, 2012 The time for a read frame without delays is around 75ms, so you've got about 81 ms vs. 180ms... that looks way off. What you really need is for the time between the ends of data frames of adjacent requests to be multiples of a common value (the simulated disk rotation speed). If you can equalize the delays for all requests, then it works out for a particular loader, but if you've got a longer delay for one case then that needs to be a multiple of the total time. What you may need to do instead is stall until it's been a multiple of 80ms since the end of the last request, or 208ms if you want to be faithful to 288 RPM. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 8, 2012 Share Posted January 8, 2012 Also note - although the games probably don't/can't check unless using custom SIO - The delay for a read should also be for the "Complete" reply from peripheral, not just the transmission of the data frame. So you have: Read Command ... peripheral "Ack" ... peripheral (extra) delay ... peripheral "Complete" ... peripheral data frame. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 8, 2012 Author Share Posted January 8, 2012 (edited) Well, the actual read times for sector data when read from the SD backing store individually (no track buffering) is under 10ms. So, as phaeron mentioned earlier, I if I just make all sector reads take a consistent 75ms, the skew check seems to pass. That seems to be the easiest route to the goal and I'll only enable it if a PRO image is mounted. Edited January 8, 2012 by Farb Quote Link to comment Share on other sites More sharing options...
ijor Posted January 9, 2012 Share Posted January 9, 2012 As a test, I tried making EVERY sector read consistently take 111ms and that worked. However, trying to make all sector reads take a consistent amount of time (6ms) and all track changes a consistent amount of time (105ms) doesn't work. So there's still something I'm not understanding. Do you see in the logs that the protection is reading sector 1 more than a dozen times? Why you do think it does so ? Well, what it does is to compute the average timing to read two sectors that are perfectly aligned in the same angular position. In effect, it is computing the average RPM. Later, it reads aligned sectors, but now in two different tracks. And it expects that the timing will match close enough to the timing computed when it read sector 1, or a multiple of it. Otherwise, the skew align check fails (as it happens to you in your second test). So, as phaeron mentioned earlier, I if I just make all sector reads take a consistent 75ms, the skew check seems to pass. That seems to be the easiest route to the goal and I'll only enable it if a PRO image is mounted. That depends on which exactly is the goal. If all you want is to run this protection, in this specific EA implementation, then that's ok. But as phaeron is saying, that strategy would break with different protections, or even possibly with a different implementation of this protection. If your goal is to emulate copy protected disks as many as possible, then there is no option other than trying to emulate the real timing as accurately as possibly. Btw, most original loaders use SIOV or DSKINV ($E453). Very few go directly to the hardware (Lucasfilm games is a notable case). **** Note to the Admin and mods **** There is something in this thread that some browsers don't like. Some versions of Firefox hang and some versions of the Android browser crash. I assume I am not the only one seeing this behaviour, am i? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 9, 2012 Share Posted January 9, 2012 Working OK for me... FF 3.0.18 One thing I do notice elsewhere, if someone puts attachments at the bottom of post then edits, the "edited by" box can overlay the attachments. Quote Link to comment Share on other sites More sharing options...
Farb Posted January 9, 2012 Author Share Posted January 9, 2012 @ijor, thanks for the explanation. I would be very interested in emulating accurate timing. Is there any recommended old reference document or book that would help in the regard? Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted January 10, 2012 Share Posted January 10, 2012 FF 9.0.1 looks fine here. Quote Link to comment Share on other sites More sharing options...
