mimo Posted April 26, 2012 Share Posted April 26, 2012 My 800 has a dead space bar. I have checked with a multimeter and there is no connection being made. The keyboard is a PCB with switched soldered directly to it, no mylar, traces are intact. On removing the key cap, I can see 3 copper(?) prongs that look like they should make contact with the larger single copper contact on the other side of the key. At some point, it looks like these have been bent out of shape. I have straightened everything up, but still no joy. Any ideas? Anyone got a good 800 keyboard for sale cheap? (this 800 was a demo machine at my local Atari dealer (May's Computers) in the 80's, so probably too quite a pounding) Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted April 26, 2012 Share Posted April 26, 2012 (this 800 was a demo machine at my local Atari dealer (May's Computers) in the 80's, so probably too quite a pounding) probably too many sessions of Defender Can you bridge the connections and see if the space gets registered. I would need to get home and open up my 800 and see what you are talking about. Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted April 26, 2012 Share Posted April 26, 2012 (edited) This is attributed to "hyperspace" in Defender, I know, personally. Recently, I had to break down and buy one from B&C on Ebay. eBay Auction -- Item Number: 130685497536 I know it's a lot, but it was a really nice 800 I like. Sucks, that this is a defect. I wonder if the actual failure is in the mylar, or what??? I've never seen the ACTUAL failure discussed - merely that the failure exists, and slapping the spacebar (sometimes with a big toe if the 800's on the floor, functioning as a game console) is responsible. I wonder if components from another key (from an extra, defunct 800 keyboard) couldn't be salvaged to repair the defect on the [presumably] simple contact switch that has failed?? I don't know jack, but ain't a keyboard switch a momentary switch? Edited April 26, 2012 by wood_jl Quote Link to comment Share on other sites More sharing options...
mimo Posted April 26, 2012 Author Share Posted April 26, 2012 I have put everything away for tonight, will have another look tomorrow. You should be able to see what I mean by taking off any of the other key caps, they all work in the same way Quote Link to comment Share on other sites More sharing options...
mimo Posted April 26, 2012 Author Share Posted April 26, 2012 This is attributed to "hyperspace" in Defender, I know, personally. Recently, I had to break down and buy one from B&C on Ebay. eBay Auction -- Item Number: 130685497536 I know it's a lot, but it was a really nice 800 I like. Sucks, that this is a defect. I wonder if the actual failure is in the mylar, or what??? I've never seen the ACTUAL failure discussed - merely that the failure exists, and slapping the spacebar (sometimes with a big toe if the 800's on the floor, functioning as a game console) is responsible. I wonder if components from another key (from an extra, defunct 800 keyboard) couldn't be salvaged to repair the defect on the [presumably] simple contact switch that has failed?? I don't know jack, but ain't a keyboard switch a momentary switch? Thanks, I am aware that brad and Bruce have the keyboards available, but, double that price with postage to the UK, and potentially add another $50 in import duty, tax and handling fee, and it gets rather expensive. As I said in my initial post, there is no mylar to be at fault. All the keys are in one big unit, each key individually soldered to the PCB. If there is no easy fix, I will have to get creative with the dremmel, araldite and a micro switch. But I will probably end up killing it altogether Quote Link to comment Share on other sites More sharing options...
NuY Posted April 26, 2012 Share Posted April 26, 2012 I feel your pain Mike, but I did like your tag of "not woking" Is it a Chinese 800? Quote Link to comment Share on other sites More sharing options...
mimo Posted April 26, 2012 Author Share Posted April 26, 2012 I feel your pain Mike, but I did like your tag of "not woking" Is it a Chinese 800? lol, no, thats using a droid phone instead of a real computer Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 8, 2013 Share Posted April 8, 2013 (edited) Just hit the same issue here with an 800 I'm working on. The pin under one of the contact springs under the space bar has completely fallen out, so must have parted company with the top of the spring inside the switch. It appears the 800 keyboards are IMPOSSIBLE to dismantle. One idea I had - since I can't get the bad switch out to replace it - is to fit a second switch next to the dead one and patch it into the circuit??? Edited April 8, 2013 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
mimo Posted April 8, 2013 Author Share Posted April 8, 2013 Just hit the same issue here with an 800 I'm working on. The pin under one of the contact springs under the space bar has completely fallen out, so must have parted company with the top of the spring inside the switch. It appears the 800 keyboards are IMPOSSIBLE to dismantle. One idea I had - since I can't get the bad switch out to replace it - is to fit a second switch next to the dead one and patch it into the circuit??? not a bad idea if you can ass rig it. Luckily I got a replacement , brand new but with issues (the ribbon cable not soldered on correctly and several key caps fall off way too easily!) Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 8, 2013 Share Posted April 8, 2013 (edited) not a bad idea if you can ass rig it. Luckily I got a replacement , brand new but with issues (the ribbon cable not soldered on correctly and several key caps fall off way too easily!) Yep - a couple of keys had fallen off this machine in transit too. Luckily easily re-affixed, although I see cracks on a couple of the white plungers. There's a NOS 800 keyboard for sale on eBay, but the seller points out that the plungers are a bit brittle. Fortunately I took an ass-rigging course a while back... in fact I'm now ass-rig certified (by ARCA, the Ass-Riggers' Certification Authority). So we should be OK here. Edited April 8, 2013 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
mimo Posted April 8, 2013 Author Share Posted April 8, 2013 Do you have the full Metal Guy ass rigging certificate or is it one of those online print yourself qualifications? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 8, 2013 Share Posted April 8, 2013 Do you have the full Metal Guy ass rigging certificate or is it one of those online print yourself qualifications? The full MetalGuy ass-rigging certificate, of course - produced with PrintShop. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 9, 2013 Share Posted April 9, 2013 (edited) Right - I think I fixed this. After consulting the Ass-Rigger's Compendium last night, I decided it might be possible to access the underside of the contacts by drilling up through the PCB - so this is what I tried today. I did the left pin in the picture first (almost severing a PCB trace - hence the jumper wire), probing inside the hole with the iron to tin the spring and then connecting a wire to the other through-hole. Then the other pin fell off so I had to do the same to the right hand spring. Then the whole keyboard ribbon cable fell off at the PCB so I had to resolder that as well... this is just a gift which keeps on giving. Anyway: it appears to work. I don't know how long it will last, but at least it's possible to type on this machine again. Edited April 9, 2013 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 9, 2013 Share Posted April 9, 2013 Thanks for all your hard work on getting my 800 back to life Jon! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 9, 2013 Share Posted April 9, 2013 Thanks for all your hard work on getting my 800 back to life Jon! No problem. It's working beautifully now and it's a sight to behold. Quote Link to comment Share on other sites More sharing options...
richard_g Posted April 12, 2013 Share Posted April 12, 2013 not a bad idea if you can ass rig it. Luckily I got a replacement , brand new but with issues (the ribbon cable not soldered on correctly and several key caps fall off way too easily!) Did you manage to fix those key plungers in the end? Quote Link to comment Share on other sites More sharing options...
oracle_jedi Posted May 26, 2016 Share Posted May 26, 2016 (edited) My entry for the Ass-Rigger Award. When the pins are bent flat there is actually enough room under the keyboard for this hack to work. I insulated the contacts in electrical tape to prevent any shorts against the resistors that lie immediately behind the joystick ports. The keyboard works best now if you press on the right, but that's still better than no spacebar at all. Edited May 26, 2016 by oracle_jedi 1 Quote Link to comment Share on other sites More sharing options...
