NML32 Posted May 18, 2012 Share Posted May 18, 2012 I don't mind Perfboard. 1 Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 18, 2012 Share Posted May 18, 2012 Hello Ray 98% of all hardware upgrades for the Atari 8 bit computer nowadays come with a PCB. Check out VBXE, SIO2SD (all versions I know), Turbo Freezer, Nunjoy, MIDI-Interface (both by HARdwareDOC), all dual Pokey upgrades, Ultimate 1MB, etc., etc., etc. AFAIK these aren't using cheap pcboards and they do seem to be affordable. Mathy Quote Link to comment Share on other sites More sharing options...
atari8warez Posted May 18, 2012 Author Share Posted May 18, 2012 Hello Ray 98% of all hardware upgrades for the Atari 8 bit computer nowadays come with a PCB. Check out VBXE, SIO2SD (all versions I know), Turbo Freezer, Nunjoy, MIDI-Interface (both by HARdwareDOC), all dual Pokey upgrades, Ultimate 1MB, etc., etc., etc. AFAIK these aren't using cheap pcboards and they do seem to be affordable. Mathy Yes Mathy, I am aware of those upgrades but my question was not who uses pcboards in their upgrades, rather how important is using one as far as the end-users of these upgrades are concerned and whether this is a deciding factor when one considers buying one of these upgrades. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted May 18, 2012 Author Share Posted May 18, 2012 I have now all the required parts (my cables have arrived, as seen above) to start the actual ordering process. Please see the order thread here Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted May 18, 2012 Share Posted May 18, 2012 It may actually be less time consuming to use PCBs rather than perf boards. This may only have a significant impact if you produce like 20 units a month. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted May 19, 2012 Author Share Posted May 19, 2012 (edited) It may actually be less time consuming to use PCBs rather than perf boards. This may only have a significant impact if you produce like 20 units a month. Yes it may, at the least I wouldn't have to do point-to-point wire soldering, however for a small/simple design like this the impact is not significant as you noted. Had I gone with larger quantities i would have seriously considered to start with a pcb design. Small volume also allows me to throughly test every individual device, each connection is double checked with a multimeter each solder joint is examined with a magnifier. That may sound extreme but that's how I work, and I can afford to do that because I do not work for living (not anymore), and I do not do this to make a living and I am, although not a perfectionist, would like to do my job (or hobby) right. Edited May 19, 2012 by atari8warez Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted May 19, 2012 Share Posted May 19, 2012 I'd settle for the most practical solution. Me too. Quote Link to comment Share on other sites More sharing options...
