Gazoo Posted December 19, 2012 Share Posted December 19, 2012 Jon's cartridge will be able to run RXB when I get my part done. Alternately one of the existing 16k carts with an AVR grom slapped down on top will also fit the bill. Agreed that an RXB run would be nice! If someone wants to layout and manufacture the custom cart, I don't mind providing a dedicated AVR/GROM for it, since that much code already works (it's really only the ability to program the chip in the console that I haven't got to.) Well, if you're going to do that, I'd prefer to have an XB v2.5 cart. Gazoo Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 20, 2012 Share Posted December 20, 2012 Actually, I think I still have about 10 of the earlier version of the 512K board that use the original version of your AVR code, Tursi. Those would probably work for this type of solution. . . Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 21, 2012 Share Posted December 21, 2012 Probably would. But the 1284P is way oversized and much more expensive than you need for either of those carts, a smaller AVR would be about half the cost. Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted December 21, 2012 Author Share Posted December 21, 2012 I'm confused. Will this be for sale or DIY? Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 21, 2012 Share Posted December 21, 2012 Probably would. But the 1284P is way oversized and much more expensive than you need for either of those carts, a smaller AVR would be about half the cost. +1 if the person wants to DIY it. If they don't, we could keep on with the 1284 boards just to keep everything the same. I've been itching to try RXB in a cart Quote Link to comment Share on other sites More sharing options...
RXB Posted December 21, 2012 Share Posted December 21, 2012 Well make a RXB Cart and I will buy one as my PGRAMs do not work as my Pbox is flaky. (I suck at hardware.) Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 21, 2012 Share Posted December 21, 2012 I'm confused. Will this be for sale or DIY? So far neither, nobody has stepped up to do it. Quote Link to comment Share on other sites More sharing options...
haxtor Posted December 26, 2012 Share Posted December 26, 2012 Im strill trying to get the code working on a arduino mega :-p Quote Link to comment Share on other sites More sharing options...
globeron Posted May 10, 2015 Share Posted May 10, 2015 I am still troubleshooting the (Serial or Parallel ?) port on the nanoPEB-F18 v1 Chipset is TMS9902NL Power adapter is 5V (600 mA) (I cannot do List "SIO") I/O Error 00 but I can do List "RS232.BA-9600.DA=8.PA=N", but no result at the PC side (I tried already resetting using DosBox, Tera Term, baudrates, buffers, etc.) normal and x-over cables (Serial). but also I can do LIST "PIO" seems to work (I read on the other forum that this should not be possible) Questions 1. It is or serial or parallel correct ? (but now I do not know what it is, it has a 9-pin male D-plug) 2. if there is wrong software running on the nanoPEB, can this be upgraded ? 3. Are there any other troubleshooting steps ? Quote Link to comment Share on other sites More sharing options...
Opry99er Posted May 10, 2015 Share Posted May 10, 2015 I have never used the serial on a nano... But it should be a serial port, not PIO. From my understanding, CF7s are PIO, nanos are serial. This is 2-3 year old knowledge however... He may be making PIO nanos nowadays. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 10, 2015 Share Posted May 10, 2015 (edited) There are two versions of the Nano--one that uses the standard TI PIO and a 9902, and the other using SIO and a 16545 UART. The 9902 version came later. . . Edited May 10, 2015 by Ksarul Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 11, 2015 Share Posted May 11, 2015 imho he left PIO in the DSR by mistake OR it points to RS232 if it's a NANOPEB it's serial if it's a CF7 (with 25pin connector) its parallel Greg 2 Quote Link to comment Share on other sites More sharing options...
