jericho_21 Posted November 26, 2012 Share Posted November 26, 2012 Hello, everybody: I am wanting to learn about assembly language programming on the Atari 8-bit computer. To start off learning, would I have to go to learn BASIC first, or just delve into assembly code directly? I am completely novice at this, but I am quite interested in learn to code for the Atari. Also, is there any way I can get tutorials from certain individuals who know more about programming than I do? I appreciate any advice. Thanks! Quote Link to comment Share on other sites More sharing options...
Grevle Posted November 26, 2012 Share Posted November 26, 2012 Probably best to start with Basic, Basic is direct, so when you type in a program you can run it by typing run, and if anything is wrong you get the basic error codes, these codes are explained in The Atari Basic Manual. Also when programming Atari its vital to learn someting about the memory map of the Atar 8-bit, and the various adresses. Im new to assembler myself but is a different way of programming, takes more code to do something and program must be assembled to run it.,For pure speed Assembler is Fastest. Turbo Basix XL is about 3 times faster than Atari basic and have more commands than Atari Basic. Turbo Basic XL is a disc based Basic and should be easy to find on the net somewhere.Its also compitable With Atari basic so the Manual for Atari Basic also apply to Turbo basic. Its also possible to use assembler routines within A Basic program. 1 Quote Link to comment Share on other sites More sharing options...
jericho_21 Posted November 26, 2012 Author Share Posted November 26, 2012 Thanks for the reply. I thought it was BASIC I needed to start off with. Then that is how I will approach it. Thanks, again. Quote Link to comment Share on other sites More sharing options...
sack-c0s Posted December 5, 2012 Share Posted December 5, 2012 (edited) I grew up on the C64, so the only difference between assembler and BASIC was the speed it ran at, so this one bit of advice is based on my experiences there. If you go the basic route pay particular attention to the PEEK and POKE instructions, as once you know how they work and can control things that way transitioning to assembler will be a lot easier because that's the closest to how you will be working in 6502 (or any assembly language for that matter) Edited December 5, 2012 by sack-c0s Quote Link to comment Share on other sites More sharing options...
jericho_21 Posted December 5, 2012 Author Share Posted December 5, 2012 Thanks again. I will definitely keep that in mind for sure. Your advice is helpful. Quote Link to comment Share on other sites More sharing options...
JonnyBritish Posted December 5, 2012 Share Posted December 5, 2012 On the Atari you you have other languages to choose from including Action! from OSS Software However if assembler is where you want to go check out this tutorial on 6502 coding. It is not Atari specific but may be helpful http://skilldrick.gi...6502/index.html Quote Link to comment Share on other sites More sharing options...
jericho_21 Posted December 5, 2012 Author Share Posted December 5, 2012 (edited) I have seen that tutorial before. In fact, I do have a bookmark to it. I will check it out. Thanks! Edited December 5, 2012 by jericho_21 Quote Link to comment Share on other sites More sharing options...
AtariMagic! Posted December 27, 2012 Share Posted December 27, 2012 can good looking games be achieved with Turbo Basic ? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 28, 2012 Share Posted December 28, 2012 can good looking games be achieved with Turbo Basic ? KE-Soft (Kemal Ezcan) from Germany did a lot of decent stuff using TB. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted December 28, 2012 Share Posted December 28, 2012 Don't forget there is also a compiler for TB which can dramatically improve the speed of the program. Quote Link to comment Share on other sites More sharing options...
AtariMagic! Posted December 28, 2012 Share Posted December 28, 2012 Don't forget there is also a compiler for TB which can dramatically improve the speed of the program. which is the compiler? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted December 29, 2012 Share Posted December 29, 2012 There is a program called COMPILER.COM which will have the compiler. It compiles to a .CTB file which can then be run from another program called RUNTIME.COM ... you can also use a linker to make it into a standalone executable. http://www.page6.org/pd_lib/special/pd_ds006.htm this one contains TB plus the compiler This post has the Turbo BASIC linker: http://www.atariage.com/forums/topic/205312-turbo-basic-programming-for-compiler/#entry2640798 Quote Link to comment Share on other sites More sharing options...
AtariMagic! Posted December 29, 2012 Share Posted December 29, 2012 There is a program called COMPILER.COM which will have the compiler. It compiles to a .CTB file which can then be run from another program called RUNTIME.COM ... you can also use a linker to make it into a standalone executable. http://www.page6.org...al/pd_ds006.htm this one contains TB plus the compiler This post has the Turbo BASIC linker: http://www.atariage....r/#entry2640798 thank you very much sir! what about 5200 conversions? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted December 29, 2012 Share Posted December 29, 2012 (edited) Unfortunately, none of the BASIC languages on the Atari XL can be used to generate running code natively on the 5200. There was a 5200 BASIC developed awhile back, and I think you can get it in this thread: http://www.atariage....basic-compiler/ This runs natively on a PC, and takes BASIC code, and compiles it into a 5200 executable. Edited December 29, 2012 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
bob_er Posted December 29, 2012 Share Posted December 29, 2012 can good looking games be achieved with Turbo Basic ? Check this: http://atari.fandal.cz/detail.php?files_id=4267 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted January 22, 2013 Share Posted January 22, 2013 Hi jericho_21, how are you getting on? I've just started looking at assembler again (about my 5th attempt) but have programmed lots of Atari BASIC games over the years and one Turbo BASIC game (Gwobby Strikes Back!) check them out on the Gwobby Web Site. Other atariage members have created Turbo BASIC games see Grelve's Web Site and Synthpopalooza's Tetricize A good way of getting started in BASIC (or assembler) would be to work through some of the Atari Computer manuals, books (atariarchives.org) or magazines (many on atariage.com) Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted January 27, 2013 Share Posted January 27, 2013 What kind of cross-development resources are there for A8's? Quote Link to comment Share on other sites More sharing options...
snicklin Posted January 27, 2013 Share Posted January 27, 2013 What kind of cross-development resources are there for A8's? Personally, I use MADS or CC65 for cross-development. There's no way I could go back to coding on the actual Atari. 1 Quote Link to comment Share on other sites More sharing options...
