+Gemintronic Posted March 14, 2013 Share Posted March 14, 2013 Probably my bad. If he's got proper GOSUBs leading to proper RETURNs he should be okay. Otherwise it's just like C: it'll let you do screwy things and it will seem OK until it isn't. Assuming his bB is correct that leaves only the inline assembly. Stuff like: asm .DotPlayer LDX #<playerDot STX player1pointerlo STX player2pointerlo STX player3pointerlo STX player4pointerlo STX player5pointerlo LDA #>playerDot STA player1pointerhi STA player2pointerhi STA player3pointerhi STA player4pointerhi STA player5pointerhi LDA #2 STA player1height STA player2height STA player3height STA player4height STA player5height . end and pop: goto badmove asm playerDot .byte %1 end Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 14, 2013 Author Share Posted March 14, 2013 The cycle74_HMCLR is a result of code changing during dasm passes, causing the code labels to shift and be different between passes. (which dasm can't handle) The cause of this shifting is the changes you made to multisprite.h when you made pb_multisprite.h. You made some labels equate to other labels. e.g. P0Top = temp5 Use actual values, and your problem will go away. Huh, odd. I didn't make those changes. Here's what I did: missile0x = $80 missile1x = $81 ballx = $82 ; multisprite stuff below - 5 bytes each starting with spritex SpriteIndex = $83 player0x = $84 NewSpriteX = $85 ; X position player1x = $85 player2x = $86 player3x = $87 player4x = $88 player5x = $89 objecty = $8A missile0y = $8A missile1y = $8B bally = $8C player0y = $8D NewSpriteY = $8E ; Y position player1y = $8E player2y = $8F player3y = $90 player4y = $91 player5y = $92 to ; multisprite stuff below - 5 bytes each starting with spritex SpriteIndex = $80 player0x = $81 NewSpriteX = $82 ; X position player1x = $82 player2x = $83 player3x = $84 player4x = $85 player5x = $86 missile1x = $87 ballx = $88 missile0x = $89 player0y = $8A objecty = $8A NewSpriteY = $8B ; Y position player1y = $8B player2y = $8C player3y = $8D player4y = $8E player5y = $8F missile1y = $90 bally = $91 missile0y = $92 As you can see, I realigned the missiles and ball so that I could reference player1y[0] - player1y[7] using a for loop. I never changed P0Top to point to a variable rather than a memory address, because I never modified that far down, so I wonder how that happened? You're absolutely right, though. Once I copied those values over from multisprite.h, it compiles again without an error. Weird. That just leaves the problems with DPC+... Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 14, 2013 Share Posted March 14, 2013 After I dumped the files from BB_dpc.zip into my bB folder omega.bas compiled just fine. [3/14/2013 4:00:47 PM] bblint found the following errors in omega.bas warning(): Found 33 commands that use end, and 30 "end" commands. That bit of output is probably bblint not understanding something about the DPC+ stuff. The actual ROM runs fine. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 14, 2013 Author Share Posted March 14, 2013 I get those lack of "end" command errors all the time. Kind of annoying, but not problematic, so far as I can see. I wish I was having as much luck with it as you are, loon. I get the following error when I compile (and this is using the latest version of bB, both if I use the nice package Atarius gave me or if I use the fresh install I showed in the video on the first page of this thread): [3/14/2013 3:02:51 PM] bblint found the following errors in omega.bas warning(): Found 33 commands that use end, and 30 "end" commands. 2600 Basic compilation completed. free ram: 9 DPC free RAM= bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 bytes of ROM space left in bank 5 bytes of ROM space left in bank 6 bytes of ROM space left in graphics bank free ram: 9 DPC free RAM= 603 --> repo 1ab2 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 14, 2013 Author Share Posted March 14, 2013 (edited) It looks like someone else had a similar problem, though I'm not clear on what he did to resolve it. If anyone has any ideas, I'm still stumped on this one. And I still have no idea what caused whatever-it-was to break in the first place. :s Edited March 14, 2013 by Cybearg Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 I tried sharing the drive with my batariBasic stuff on it and seeing if things would compile on a different computer. Since the computer hadn't run VisualbB before, I had to set up Stella's location, bB's location, and the project's location. I used the same relative paths as I used on my main computer (except that I copied Stella over to VbB's main directory to use it from there instead). The result: the DPC+ Omega game DOES compile, albeit with the same warning listed above (repo 1ab2) and without any of the remaining ROM sizes being reported--they're all blank. The game compiles and runs, though. This other computer is a 64-bit Windows 7 machine, just like the one I normally work on. So are there some kind of registry-based values for bB or VisualbB which could have become corrupted, preventing me from compiling DPC+ on one computer while the same files work fine on a different computer? And what is this mysterious -> rep 1ab2 and how can I get the remaining ROM space to be reported again? Quote Link to comment Share on other sites More sharing options...
jwierer Posted March 15, 2013 Share Posted March 15, 2013 The vbB settings are in HLKM\Software\VisualbB, but the only thing that would have an effect is the compiler path. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 15, 2013 Share Posted March 15, 2013 This isn't going to be helpful to you at all, but I generally don't see the remaining ROM space reported when I compile with DPC. It says "<blank> bytes free" for each bank. I assumed it was a bug that would be worked out in the future... Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 This isn't going to be helpful to you at all, but I generally don't see the remaining ROM space reported when I compile with DPC. It says "<blank> bytes free" for each bank. I assumed it was a bug that would be worked out in the future... Oh... Well then how can you tell where you are? Are there any registry options that bB sets that could be mucking with this computer? Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 15, 2013 Share Posted March 15, 2013 Oh... Well then how can you tell where you are? Are there any registry options that bB sets that could be mucking with this computer? Since I haven't made an actual game with DPC yet I didn't really worry about it. My demos have all been very small. bB doesn't make any registry changes at all, but Visual bB likely does. I know I mentioned it before, but I don't use Visual bB and I don't know what changes it might make. It's a great tool and works very well, it's just not something I'm interested in. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 15, 2013 Share Posted March 15, 2013 A quick note to jwierer since I'm sure you're reading this thread, I mean no disrespect to your efforts. Visual batari basic is a really cool tool and it's helped lots of people break in to bB. I'm just an old school "must use a text editor" kind of guy. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 VisualbB is basically just a text editor except it has nice tools included for making playfields and sprites quickly and intuitively, as opposed to trying to type out an upside-down sprite with your keyboard. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 15, 2013 Share Posted March 15, 2013 VisualbB is basically just a text editor except it has nice tools included for making playfields and sprites quickly and intuitively, as opposed to trying to type out an upside-down sprite with your keyboard. Yeah, I know. I've installed it and played around with it, just never used it for a project. I've been in IT for a few decades now, and I'd really rather use vi on my UNIX servers than windows notepad, but I'm stuck with windows laptops at work and at home so notepad is my 2nd favorite choice. I'm so used to a simple text editor that I feel more productive using one. That's why all my source code posts are in .txt format. I'm a masochistic programmer. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 But, getting back to the problem, if I've replaced bB and VisualbB and I can confirm that both work on a different system, what can I do to fix their DPC+ compatibility for this system? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 15, 2013 Share Posted March 15, 2013 A quick note to jwierer since I'm sure you're reading this thread, I mean no disrespect to your efforts. Visual batari basic is a really cool tool and it's helped lots of people break in to bB. I'm just an old school "must use a text editor" kind of guy. You can disable syntax checking and color coding if you want to use VbB like a plain old text editor. Unlike with a plain text editor, you can do some cool stuff from the right-click menu. For example, you can highlight a label name used with a goto or gosub and instantly jump to where the actual label is. You can't do that with a plain text editor and it can save you a lot of time when working on a large program or working on a program made by somebody else. Click anywhere in a program and select Identify Current Bank and VbB will tell you which bank you're in (another thing a plain text editor can't do). You can also highlight lines of code and make them all REM statements or un-REM them. Highlight lines of data and instantly reverse their order. You can also force minimum spacing that you've previously set up on the settings page (I use 3 spaces). When you use VbB, you can also access the various other tools that VbB has like the Sprite Editor, Playfield Editor, Music and Sound Editor, Score Editor, Title Screen Editor, Graphics Converter and so on. Quote Link to comment Share on other sites More sharing options...
jwierer Posted March 15, 2013 Share Posted March 15, 2013 A quick note to jwierer since I'm sure you're reading this thread, I mean no disrespect to your efforts. Visual batari basic is a really cool tool and it's helped lots of people break in to bB. I'm just an old school "must use a text editor" kind of guy. No offense taken -Jeff Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 15, 2013 Share Posted March 15, 2013 No offense taken -Jeff I fully blame VisualbB for allowing me to use batari BASIC. Without a proper, robust IDE I would have never made a game signed by Freddy Krueger or spoken at an Arcade Expo or get my games published by an indie comic book artist. This is not to dispute Atarius Maximus's viewpoint. I fully believe NOTEPAD.EXE is the best web page editor ever. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 Still no suggestions? I tried deleting every VisualbB registry file I could find, then re-ran and re-configured VbB. I've attached zips which include my bB folder/assember and my VbB folder/Stella, along with a registry file for my main VbB registry. Perhaps someone can find something amiss here somewhere. Keep in mind: The problem is that I am unable to compile ANY DPC+ game. I've tried Food Fight, an example Atarius posted in his "Getting Started with DPC+" thread, and my own game, posted earlier here (which Atarius and others have confirmed DOES compile correctly on their systems). The complication is that, using the exact same files, I AM able to compile DPC+ on another machine, but I want to be able to compile it on THIS machine because THIS is my work station. Also keep in mind that DPC+ WAS able to compile on this machine, up until the crash I described in the original post of this thread. Does anyone have any idea what could be wrong? Does anyone see something wrong with my registry or files? Please, please help! bbDPC.zip vbB.zip Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 15, 2013 Share Posted March 15, 2013 After I dumped the BB_dpc.zip into my BatariBASIC folder and then RevEngs new bblint executable omega.bas had ZERO errors. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 15, 2013 Author Share Posted March 15, 2013 (edited) After I dumped the BB_dpc.zip into my BatariBASIC folder and then RevEngs new bblint executable omega.bas had ZERO errors. Did it ever not work for you? For me, DPC+ games DO compile, but they don't report the size, I get the notice of: --> repo 1ab2 ... And Stella opens a ROM that's just noise and garbled colors on the screen. Edited March 15, 2013 by Cybearg Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 15, 2013 Share Posted March 15, 2013 Deez errors http://www.atariage.com/forums/topic/209985-visual-bb-committed-suicide/page__st__50#entry2715826 RevEng was Ninja quick and updated bblint, though. Quote Link to comment Share on other sites More sharing options...
iesposta Posted March 15, 2013 Share Posted March 15, 2013 I get those lack of "end" command errors all the time. Kind of annoying, but not problematic, so far as I can see. I wish I was having as much luck with it as you are, loon. I get the following error when I compile (and this is using the latest version of bB, both if I use the nice package Atarius gave me or if I use the fresh install I showed in the video on the first page of this thread): [3/14/2013 3:02:51 PM] bblint found the following errors in omega.bas warning(): Found 33 commands that use end, and 30 "end" commands. 2600 Basic compilation completed. free ram: 9 DPC free RAM= bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 bytes of ROM space left in bank 5 bytes of ROM space left in bank 6 bytes of ROM space left in graphics bank free ram: 9 DPC free RAM= 603 --> repo 1ab2 I have run into that blankness before. It was from something out of order or missing in Bank 1. I said before that I can define one variable too many with space left in Bank 1 and get this. I can leave out set optimisation inlinerand or something and I get this. It does compile and run fine - I don't have your corruption problem - but shows blank. This must be some kind of bug. Example: rem batari Basic Program rem created 12/22/2011 9:06:04 PM by Visual bB Version 1.0.0.565 rem ***************************************************** bank 1 temp1 = temp1 set tv ntsc set kernel DPC+ set smartbranching on set optimization inlinerand set kernel_options collision(playfield,player1) const font=alarmclock dim xp= a.b xp=30.0 dim yp=c.d yp=37.0 scorecolors: $98 $96 $98 $96 $98 $96 $98 $96 end score = 123456 goto MAIN bank2 Add another variable and blank. Add another variable and blank. Quote Link to comment Share on other sites More sharing options...
jwierer Posted March 16, 2013 Share Posted March 16, 2013 Still no suggestions? I tried deleting every VisualbB registry file I could find, then re-ran and re-configured VbB. I've attached zips which include my bB folder/assember and my VbB folder/Stella, along with a registry file for my main VbB registry. Perhaps someone can find something amiss here somewhere. Keep in mind: The problem is that I am unable to compile ANY DPC+ game. I've tried Food Fight, an example Atarius posted in his "Getting Started with DPC+" thread, and my own game, posted earlier here (which Atarius and others have confirmed DOES compile correctly on their systems). The complication is that, using the exact same files, I AM able to compile DPC+ on another machine, but I want to be able to compile it on THIS machine because THIS is my work station. Also keep in mind that DPC+ WAS able to compile on this machine, up until the crash I described in the original post of this thread. Does anyone have any idea what could be wrong? Does anyone see something wrong with my registry or files? Please, please help! Still sounds like it's actually not executing the right compiler. Have you tried deleting, moving, or archiving any other version of the compiler on your workstation? That would at least eliminate the case that a different compiler running. The vbB settings won't have any effect on running the compiler from the commandline so don't kill yourself messing with those. -Jeff Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 16, 2013 Author Share Posted March 16, 2013 Still sounds like it's actually not executing the right compiler. Have you tried deleting, moving, or archiving any other version of the compiler on your workstation? That would at least eliminate the case that a different compiler running. The vbB settings won't have any effect on running the compiler from the commandline so don't kill yourself messing with those. -Jeff As per your suggestion, I deleted all but the single version of bB that I want to use. Sadly, I get the same issue. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 16, 2013 Share Posted March 16, 2013 You sound technically savvy, Cybearg. Back up our stuff and install a fresh copy of Windows. Pending that you can fudge it by running bB in XP compatibility mode which is really a virtual machine. Either way guarantees zero software corruption from the previous install. This could be the first telltale sign your OS is going south. Quote Link to comment Share on other sites More sharing options...
