object list
Your my Heroe.. answering this noobish question.. sorry for that.. after reading a little slower the v8 doc i saw it by myselfe (and couldnt delet this stupide question from forum :-(
btw
as im now trying getting into the objectlist-refresh mechanism i ask myselfe how much ready the jag is after the standard startup.s in the example
the objectlistroutines... can they be used in the rest of a project? maybe small modification of for example "#license" and "#BMP_PHRASES".. just doing it a little more common for other values accessable
im asking this because as i saw on the "TESTRGB" demo source there is the identical Subroutine "InitLister" <-> "make_list" just with some other imputvalues like "MY_LISTSIZE" in stead of "LISTSIZE"
my goal is to understand the objectpart completly and create a nice and common startup for my further coding
greetings and good night
Well, the Object Processor trashes the list as it processes it meaning you have to do one of the following:
1) Fix up the broken parts of the list every frame
2) Create a fresh list every frame
or
3) Make a copy of the list (a shadow list) and blit that over the live list every frame
The easiest is the 3rd method because then you don't have to do all that crappy time intensive bit-shifting more than once.
  • Like 4
  • 8 years later...
You are supposed to have your game objects in C# with the properties your game needs. You then write out a display list for the OP. In any game with 60 fps action, the list is fire and forget. If you do slower games, you are supposed to use a frame buffer and set it to the correct double buffer mostly hard coded in your interrupt routine.
For performance you need to clip some values while you write the list. So in a way you already trash it on write. It is like the sprite multiplexing on C64. It is low level.
  • Haha 1
  • Confused 2
as you are talking about Object list, an additionnal question :
if i want to use lots of sprites, i think i need to use several object lists, so that the object processor does not read the complete object list for all lines ?
so shall i put some YPOS < x test every N lines and bra jumps ?
or is there any way to have object list for 0 to N lines, then object list for N to N*2 lines, and so on, N*2 to N*3, N*3 to N*4 etc until 256 lines ?
I like C#. It avoids a lot of pitfalls like in python which is always slow. Both have GC. C programming language needs to have everything volatile. In C# or at least in Java you don't have pointers. You can let the runtime move objects around.
ARC in objective C only tells you the number of references. You cannot iterate and update them. With only 4k SRAM this is bad.
  • Confused 2
Not full blown, but people already compile IL to C and also AOT-compile for iPhone . Would just be funny to grab a simple, modern Unity3d example and write a compiler which works for this and then go from there.
On 1/25/2022 at 2:17 PM, jguff said:
Is there now a C# compiler for Atari Jaguar?  Python as well?  Either would be a big step up from the 32 bit Primate compiler i'm using...
Bob
  • Confused 2
  • 1 month later...
or
The simplest way is rather a mixture of 1) and 3) (at least for small projects) and this is what is done in the examples of the Atari development kit: save the 2 parts that are corrupted and recopy them at each vbl
move.l #listbuf+BITMAP_OFF,a0
move.l bmpupdate,(a0)
move.l bmpupdate+4.4(a0)
Ok, it's good for 1 object :)
One could easily port EmuTOS to the Jag and then run any Atari ST C compiler you want.  Surely with the right transpiling software you could take a Unity3D example from 2022 and run it directly!  C and C++ and C# are the same whether iPhone or Atari Jaguar, right?
I started porting EmuTOS to Jaguar last year with some success.
Unfortunately I stuck on "move #$2700,SR" instruction, which are placed  in a different EmuTOS places and it appears that it can blocks the VBL interrupt.
Missing VBL interrupt means missing set of the Object Processor list and finally destroyed ram by the OP and EmuTOS crash.
I have back to it and find a workaround.
Edited by Cyprian
Matthias Domin had TOS running on Jaguar already in the late 90s.
No idea how Matthias did it in his port, but it sounds like the best thing for you to do in yours is to disable all but the VBL and set a critical flag that tells the VBL handler to just repair the OP list and exit without doing the normal vblank routines. When the SR is restored and ints are enabled, you can clear the critical flag so the vblank runs like normal.
I'll try to look onto Matthias code then
2 hours ago, 42bs said:
Or let the GPU handle object list Update/restore.
nice idea, I'll try that
