twh/f2 Posted April 27, 2013 Share Posted April 27, 2013 Hi *, i was kind of unlucky with my tries to backup and restore my IDEPLUS 2.0 CF cards using my Windows computer. Maybe I'm missing something and therefore I would be happy if someone could provide me some help. At the beginning everything seems to work out well. That's what I'm using: * IDEPLUS2.0 * IDE<->CF adapter / http://www.ably.com.tw/pdt/viewpdt.asp?absp=20&cat=CBL_ADAPTER * I have two identical SanDisk Ultra 4 GB CompactFlash Using the IDEPLUS tools I have a nice and fast SDX system. I had issues using the Master/Slave mode with IDEPLUS2.0 so I'm only using one Master CF card. When I attach my CF card to the PC then Windows of course asks me to format the disk, because it does not recognize it's file system. I'm ignoring that. I would like to Backup/Restore/Clone my CF card. I'm using TrueImage - a Windows tool which supports sector-by-sector backups and MBA restores. The problem after restoring / cloning: * not booting / working system * when booting from Floppy Disk into SDX I see corrupted / unusable HDD drives * however: partition table can be seen using FDISK2 The other concerning problem is, that after reading out the original CF disk and plugging it back to the IDEPLUS2.0 it is also unusable anymore. greetings, twh Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 27, 2013 Share Posted April 27, 2013 First, it is safer to re-partition the disk with FJC APT-compliant FDISK. This will establish a protective MBR on the disk which should prevent Windows from destroying the disk contents. Second, you might try a Windows version of the Unix tool called "dd". A version is here http://www.chrysocome.net/dd I have to add that I did not try it on Windows, so I don't know how safe/reliable it is. But the Unix version works fine. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted April 27, 2013 Share Posted April 27, 2013 http://www.alexpage.de/usb-image-tool/download/ This one has done very well for me. Also download the 1 sector backup image to clean a bad Windows CF-MBR. Quote Link to comment Share on other sites More sharing options...
twh/f2 Posted August 7, 2013 Author Share Posted August 7, 2013 Ok. For the records: I successfully cloned a CF card today. In the result the Atari boots and SDX does not recognize any difference... Hooray! * I have used the FJC APT-compliant FDISK / partition table. * I used a USB2IDE bridge * I used TrueImage (Acronis) a commercial backup/restore tool suite Using TrueImage it's important to activate sector-by-sector option in the recovery dialogue. (which is not set by default). If not set, it won't work at all. I only managed to backup/restore a CF with my new SIDE2. I think my IDEPLUS2.0 was not compatible to the CF/Adapter I used or it was kind of broken. greetings, \twh Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted August 11, 2013 Share Posted August 11, 2013 Oppinion: Windows is total shite when it comes to raw manipulation of storage devices. If you care about your data, use DD (or similar) on an xNIX or MAC machine.. Quote Link to comment Share on other sites More sharing options...
kogden Posted August 14, 2013 Share Posted August 14, 2013 I'm with MetalGuy on that one.... dd on linux or MacOS X is the simplest most effective way to make an image of ANYTHING. Windows tools can be finicky. I've even used dd to make images of CD's in funky formats like the DEC Ultrix install CD's for my MicroVAX. Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted August 31, 2013 Share Posted August 31, 2013 Ok. For the records: I successfully cloned a CF card today. ... I only managed to backup/restore a CF with my new SIDE2. I think my IDEPLUS2.0 was not compatible to the CF/Adapter I used or it was kind of broken If it is an IDEplus from the first run of 2011 a fix might be needed if you cannot find a compatible CF adaptor. Quote Link to comment Share on other sites More sharing options...
