+nanochess Posted October 31, 2013 Share Posted October 31, 2013 Hi everybody. Just I was having a doubt about scanline variation in Atari VCS. Suppose we have an NTSC game with 262 lines, but once each (let us say) 5 frames, it changes to 263 lines. It would roll in a TV? This would be valid for PAL60? I'm thinking that no roll would occur, because it would fit in the standard 525 lines of NTSC. There is any game doing this? Now another question, this time about PAL, I've noted that in Stella the screen goes gray when 313 lines happen. This happens in real console? what happens if most of time the game generates 312 lines, and only one frame each second of 313 lines. The frame would be gray? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 31, 2013 Share Posted October 31, 2013 It won't roll the screen, but it will noticeably jitter the picture up/down. Yep - PAL TVs will show a monochrome image if they receive an odd number of scanlines from the Atari. As such it's best practice to always output a consistent number of scanlines, and always have that number be even. 2 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 31, 2013 Share Posted October 31, 2013 Some modern adapters will apparently freeze the image from that point on (making the issue a game-killer). Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted October 31, 2013 Share Posted October 31, 2013 NanoChess, my ASDK framework was doing this in one of it's kernels. OmegaMatrix fixed the bug by adjusting the timer delay values They needed to be decreased by one with WYSNC's padded (around or in the top blank); the counters run down in blocks of 64 cycles and the load varied just a bit so it would sometimes overrun; reducing it by one allowed the WYSNC spacer to resolve this as the extra 14 cycles were enough for the variance in the load. It sounds like your issue is similar. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted October 31, 2013 Author Share Posted October 31, 2013 (edited) Mr SQL, my problem is that sometimes a sprite is way too much to the right only for one frame and the code for the full line does 77 cycles instead of 76. So it triggers the extra line and from what SpiceWare says, I wouldn't like a jitter picture and worst a freezed picture like Nukey Shay says. I'll try to rewrite the code to position the first sprite before the kernel. Edited October 31, 2013 by nanochess Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 31, 2013 Share Posted October 31, 2013 Mr SQL, my problem is that sometimes a sprite is way too much to the right only for one frame and the code for the full line does 77 cycles instead of 76. So it triggers the extra line and from what SpiceWare says, I wouldn't like a jitter picture and worst a freezed picture like Nukey Shay says. I'll try to rewrite the code to position the first sprite before the kernel. I suspect that's when a sprite moved left and wrapped from 0 to 255. When moving left use code like this: if X = 0 X = 159 else X = X - 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted October 31, 2013 Author Share Posted October 31, 2013 I've the classic positioning routine "SBC #15 BCS" and I've an X coordinate in the range 150-159, so it uses 5 extra cycles while updating various other TIA registers, so by one tiny cycle it wraps to an extra line and gives me 263 lines. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 1, 2013 Author Share Posted November 1, 2013 (edited) Well, just I've confirmed in real hardware that changing from 262 to 263 lines causes a small jittering in screen. I'm working towards to solve it. If anyone wants to see my homebrew board in action, I'm putting a picture Edited November 1, 2013 by nanochess Quote Link to comment Share on other sites More sharing options...
