Koji77 Posted January 29, 2014 Author Share Posted January 29, 2014 the configurator only lets me select the rs232 option... that's where it detects on com 3 but states driver unable to load... using usb mode only Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 27, 2015 Share Posted August 27, 2015 driver for device must be loaded, usb5200, or ftdi, or other... to match the device only after they are installed do you connect the usb converter and or usb sio combination, after that you load and make sure config is set to software only in ape 3.0.6. leave and come back in.... should be working... you can manually cycle thru the com ports till one hits if the autoconfig fails. or just get the vcp versions and have at it. If installation is done in wrong order you may have to yank other drivers out and re-install.... on one pc I removed the usb5200 drivers installed the usb converter driver for the generic device and then did the software manual com config and that worked for a problematic set up... don't remember if I ever put the usb5200 drivers back in afterwards or not.... that worked as well... in any event after a year an answer is given. Good luck Quote Link to comment Share on other sites More sharing options...
