grownup Posted February 27, 2014 Share Posted February 27, 2014 (edited) I must say, I was very impressed with the quality of video this bulky, obsolete A/V box put out. But then one day, it just broke. I lightly tapped it, and the wire fell off! See the photo. So my question is, how should I fix this? Can I cut into the black wire and connect a gold connector from Radio Shack to the cut back wire, and throw away the box, or will I make matters worse? Im nost exactly sure how complicated it is inside that black wire. Maybe I should solder the thing back on. What do you techs suggest? Edited February 27, 2014 by grownup Quote Link to comment Share on other sites More sharing options...
Osgeld Posted February 27, 2014 Share Posted February 27, 2014 (edited) pop the lid open (gently) with a screwdriver inside that cable is two wires, you can see them in the rounded part of the inner cable jacket, just strip a little bit, remove the broken section inside and solder down the freshly stripped wire. should be cake, but that inner insulator is probably something nice n stretchy, I would clip the middle section out a little with a hobby knife or box cutter and try your darndest not to knick the wire inside the jacket as its probably solid wire, which will eventually lead to the same failure. (when they make something like that in a factory they use a pair of cut out blades that come from top and bottom and pull back all mechanically, its quite possible the wire was nicked the entire time and it just took this long to fail) if you are feeling skippy you can reinforce stuff with hot melt glue, which should not be that hard to remove if future repairs are ever needed Edited February 27, 2014 by Osgeld Quote Link to comment Share on other sites More sharing options...
RickR Posted February 27, 2014 Share Posted February 27, 2014 Buy a composite cable and enjoy a much cleaner picture. They are about $10. 1 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted February 27, 2014 Share Posted February 27, 2014 yea I would do composite as well but if you have the setup reattaching these could get you up and running while the cable is in the mail 1 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted February 27, 2014 Share Posted February 27, 2014 http://www.stageselect.com/News/NewsViewer.aspx?NewsID=174 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted February 27, 2014 Share Posted February 27, 2014 What do you techs suggest? You have three options, my suggestion is #3 if you have a few extra bucks to spare. It's also being actively supported. 1) Fix it, and have marginal video. 2) Get a composite cable and enjoy improved quality. 3) Go VGA (if you have a monitor or modern HDTV) and really enjoy the view with << THIS >> Option #3 is what most people are going to now as they get 80 column capability and improved graphics in many programs, but above all the video is CRYSTAL CLEAR and sharp as hell. After running with the F18A (plug in update) the regular output looks like MUD to me. Quote Link to comment Share on other sites More sharing options...
grownup Posted February 27, 2014 Author Share Posted February 27, 2014 thank you for all the advise. I will think it all over and decide. Quote Link to comment Share on other sites More sharing options...
eightbit Posted February 28, 2014 Share Posted February 28, 2014 Composite is fine for the TI99. I think VGA is overkill. If you have a good TV with a good composite, it looks great. On my old 2004 Aquos it looks like monitor quality. If you need a composite cable I think I have an extra to sell for cheap. Just shoot me a pm. Quote Link to comment Share on other sites More sharing options...
carlsson Posted February 28, 2014 Share Posted February 28, 2014 (edited) As it looks like the F18A currently is out of stock, perhaps a simple composite video cable is good for now, in particular if the poster has some parts and the know how to solder it up. Edited February 28, 2014 by carlsson Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted February 28, 2014 Share Posted February 28, 2014 I use the same composite cable for the TI that I use with my A8 computers... Quote Link to comment Share on other sites More sharing options...
grownup Posted March 5, 2014 Author Share Posted March 5, 2014 pop the lid open (gently) with a screwdriver inside that cable is two wires, you can see them in the rounded part of the inner cable jacket, just strip a little bit.... Thanks for your detailed, experienced information, Osgeld. I had no idea a screwdriver would pop that off like that. I fixed it and it works as good as new. Perhaps some day Ill upgrade to one of the other options people have nmentioned here, but for now, this was great. 1 Quote Link to comment Share on other sites More sharing options...
