crusherbad64 Posted March 7, 2014 Share Posted March 7, 2014 So the link below is the problem I'm having and I was hoping someone would answer the question I'm having. Am I doing something wrong or is it a bad cable or the converter box is bad or what because I'm lost. Thanks. http://youtu.be/ZDRyU_t7GKw Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted March 7, 2014 Share Posted March 7, 2014 It could be the converter - have you any other SCART sources to test with? I have a similar box and a similar Bravia TV and it works. It's not great, but I at least get a picture. Quote Link to comment Share on other sites More sharing options...
crusherbad64 Posted March 7, 2014 Author Share Posted March 7, 2014 Nope, this is my first ever SCART cable and I have nothing to try it on besides what was in the video. I might try getting a replacement and see if it works. Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted March 7, 2014 Share Posted March 7, 2014 Does the box have HDMI-in for scaling 720 to 1080? Just so you can test if it puts out any signal at all. Quote Link to comment Share on other sites More sharing options...
crusherbad64 Posted March 7, 2014 Author Share Posted March 7, 2014 The HDMI to HDMI works but just not the scart input. Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted March 7, 2014 Share Posted March 7, 2014 Hmm, even the Atari SCART cables can be iffy, but usually you miss some of the audio or just some of the colour channels and a wiggle "fixes" it. Can you check continuity of the pins through the cable? I can't offer much more than that, sorry :/ Quote Link to comment Share on other sites More sharing options...
NinSEGA Posted March 7, 2014 Share Posted March 7, 2014 Make sure it's not for Japan SCART. Quote Link to comment Share on other sites More sharing options...
SloeGin Posted March 8, 2014 Share Posted March 8, 2014 I have the same SCART>HDMI box you're using and I had the exact same problem. The good news is that I was able to get everything working; the bad news (depending on your skill level) is that I had to modify my SCART cable. This post from Zerosquare provided me with the solution I was looking for. Here's what I wound up doing (see attached pic): Disconnected the wire on pin 16 and tucked it to the side (in case I ever want to undo the mod) Connected a 150 ohm resistor to pins 8 and 16. I consider my soldering skills to be slightly above "shamefully embarrassing" but I was able to pull this off. Just be gentle after you remove the plastic cover on the SCART connector; some of the wires look like they could easily break off if they were bent or snagged. 1 Quote Link to comment Share on other sites More sharing options...
twoquickcapri Posted March 8, 2014 Share Posted March 8, 2014 (edited) I have the same scart cable and HDMI converter and it looks like the signal from the Jaguar RGB is being drop and picked up over a over again. The little box in the lower left corner only shows up when the incoming signal changes. I to have problems getting my Jaguar to work with this converter box. I normally get 5 to 20 min. of video then it will drop the signal and picks it back up again. I've tried the converter with a RGB Modded N64 and Amiga CD32 and they both don't have a problem with dropped signals. I also have one of those cheap SCART to Component converter that are all over eBay and the Jaguar works fine with it but recording devices like the hauppauge hd pvr and Elgato Game Capture HD don't like the component output and will not record video for the converter. [ebay]221156873851[/ebay] Edited March 8, 2014 by twoquickcapri Quote Link to comment Share on other sites More sharing options...
Willard Posted March 8, 2014 Share Posted March 8, 2014 well that answers that. i was about to get one of those for my cd32 Quote Link to comment Share on other sites More sharing options...
twoquickcapri Posted March 8, 2014 Share Posted March 8, 2014 well that answers that. i was about to get one of those for my cd32 The HDMI converter works well with the CD32 and it converts PAL to NTSC. The only thing I don't like is it forces 16:9 and I use a 4:3 HD CRT TV for oldsckool gaming and the TV letterboxes the picture to get the 16:9 ratio. Quote Link to comment Share on other sites More sharing options...
Willard Posted March 8, 2014 Share Posted March 8, 2014 that was unexpected, i actually have a scaler that can force 16:9 back to 4:3, i'm guessing scaling from one source then re-scaling from another would distort the video somehow but PAL to NTSC is what I need it for as I have an NTSC console with RGB expansion module. might try it out... i probably should've read your post a little more thoroughly rather than just cutting out where it says "does not work on jaguar". are there any issues with the image quality like softened or jerky picture with games like roadkill that have alot of scrolling? Quote Link to comment Share on other sites More sharing options...
san-d-2000 Posted September 1, 2014 Share Posted September 1, 2014 I have the same SCART>HDMI box you're using and I had the exact same problem. The good news is that I was able to get everything working; the bad news (depending on your skill level) is that I had to modify my SCART cable. This post from Zerosquare provided me with the solution I was looking for. Here's what I wound up doing (see attached pic): Disconnected the wire on pin 16 and tucked it to the side (in case I ever want to undo the mod) Connected a 150 ohm resistor to pins 8 and 16. I consider my soldering skills to be slightly above "shamefully embarrassing" but I was able to pull this off. Just be gentle after you remove the plastic cover on the SCART connector; some of the wires look like they could easily break off if they were bent or snagged. SCART mod .jpg Thanks for this, i can finaly play my French scart Atari 7800 on my Sony Bravia TV 1 Quote Link to comment Share on other sites More sharing options...
