amiman99 Posted July 19, 2022 Share Posted July 19, 2022 Anyone here knows how I can connect this arcade panel to my MVS? 2 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 3 hours ago, amiman99 said: Anyone here knows how I can connect this arcade panel to my MVS? Hi amiman. I'll ask @Reaperman to stop by to see if he can be of assistance bro. I'm sure he can help you with this for sure. Thank you for stopping by. Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 Hi guys, SNK JAPAN@SNKPofficial_jp 【K OF XV ICFC Weekly Series】 7月21日(木)にFinalを開催! ぜひご覧ください! >YouTube https://youtube.com/c/SNKesportsGlobal… #KOF15 #KOFXV #ICFCKOFXV Translated from Japanese by [KOF XV ICFC Weekly Series] Final will be held on Thursday, July 21st! Please take a look! > YouTube https://youtube.com/c/SNKesportsGlobal… #KOF15 #KOFXV #ICFCKOFXV 4:02 AM · Jul 15, 2022· Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 Hi guys, SNK GLOBAL @SNKPofficial 【KOF XV ICFC Weekly Series】 Final begins on July 21st! Tune in to find out! >YouTube https://youtube.com/c/SNKesportsGlobal… #KOF15 #KOFXV #ICFCKOFXV 4:00 AM · Jul 15, 2022· Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 Hi guys, SNK GLOBAL@SNKPofficial 4h 【KOFXV】 Here's a few words from the BGM composer. #KOF15 #KOFXV Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 Hi guys, SNK GLOBAL@SNKPofficial 5h 【KOF XV】 We have the track CLUB-M ~Flute in the Blue Sky~ -KOF XV ver.- which plays when Andy and Mai fight! Give it a listen! Anthony... 1 Quote Link to comment Share on other sites More sharing options...
Reaperman Posted July 19, 2022 Share Posted July 19, 2022 (edited) 12 hours ago, amiman99 said: Anyone here knows how I can connect this arcade panel to my MVS? Short answer: If your cab doesn't have the connector, pull all that junk out, and connect the quick connects on your cab's existing JAMMA harness directly to the control panel's switch contacts as usual. Probably replace those switches (at least) while you're there too. Longer answer: I've haven't seen one quite like that (kinda close), but I only have experience with my romstar MVS cab, and I suspect maybe the big-reds used them--certainly that's not really an arcade standard of any kind. I do have a couple similar but much larger connectors in my Atari/Midway driving cab, and I think they just borrow whatever is handy at the time from the automotive wiring world. Meaning finding an exact match decades later is tricky--and probably isn't necessary. An alternative to just running JAMMA in there, is getting both halves of a similar connector (like this one) and wire those--but having a connector there seems like adding a step of complexity that doesn't really need to exist. I think they were used to aid assembly at the factory, with the knock on effect of making them easier for operators to swap out as a unit and service back at the shop. Edited July 19, 2022 by Reaperman 2 Quote Link to comment Share on other sites More sharing options...
amiman99 Posted July 19, 2022 Share Posted July 19, 2022 1 hour ago, Reaperman said: Short answer: If your cab doesn't have the connector, pull all that junk out, and connect the quick connects on your cab's existing JAMMA harness directly to the control panel's switch contacts as usual. Probably replace those switches (at least) while you're there too. Longer answer: I've haven't seen one quite like that (kinda close), but I only have experience with my romstar MVS cab, and I suspect maybe the big-reds used them--certainly that's not really an arcade standard of any kind. I do have a couple similar but much larger connectors in my Atari/Midway driving cab, and I think they just borrow whatever is handy at the time from the automotive wiring world. Meaning finding an exact match decades later is tricky--and probably isn't necessary. An alternative to just running JAMMA in there, is getting both halves of a similar connector (like this one) and wire those--but having a connector there seems like adding a step of complexity that doesn't really need to exist. I think they were used to aid assembly at the factory, with the knock on effect of making them easier for operators to swap out as a unit and service back at the shop. Thanks for your input. I don't have an arcade cabinet right now, maybe in the future I can build one. I have MVS 1slot in a custom case built by me. Since I have an official arcade joystick panel I was thinking to make a cabinet, but the connectors threw me off. For now, I cut that connector and install DB15 (I will also build a box to install this control panel), so it's compatible with my current setup, but in the future I will get a Neo Geo wiring harness. 3 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 19, 2022 Author Share Posted July 19, 2022 Hi guys, NeoCverA@NeoCverA 2h These could be final pre-production images of the Visco: Mini Arcade Bartop. Anthony... 2 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, SNK GLOBAL@SNKPofficial Jul 17 Announcement: We are supporting this tournament via our e-sports support program! #SNK #KOFXV Anthony.. 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, SNK GLOBAL@SNKPofficial 3h Announcement: We are supporting this tournament via our e-sports support program! #SNK #KOFXV start.gg UNGA // The King of Fighters XV: Season #2 // Round #2 The best place for UNGA // The King of Fighters XV: Season #2 // Round #2 brackets, streams, standings and schedules all in one place! Anthony.. Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, SNK JAPAN @SNKPofficial_jp 【お知らせ】オンラインにてKOF XVのランキングバトルが開催されます。ぜひご参加ください! #SNK #KOFXV Translated from Japanese by [Notice] KOF XV ranking battle will be held online. Please join us! #SNK #KOFXV tonamel.com KOF XV ランキングバトル【拳劇】第4幕 | Tonamel KOF XV ランキングバトル【拳劇】第4幕 tournament page! You can check the tournament schedule and rules here. 2:00 AM · Jul 18, 2022· Anthony.. Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, 稲坂浩臣(STUDIO24) @studio24inasaka ■ギース生産中■ スケジュールに追われながらも徐々に全貌が現れてきたギース様に興奮しながら作ってます!いい出来です! 何とか月内にお届けすべく死力を尽くす毎日!パッケージも最高なんですが届いてのお楽しみにしますね! ラストスパート! #餓狼伝説 #SNK #studio24餓狼 Translated from Japanese by ■ Geese is in production ■ I'm excited to make Geese-sama, whose whole picture is gradually appearing while being chased by the schedule! Good work! Every day I try my best to deliver it within a month! The package is great, but I'm looking forward to it! Last spurt! #餓狼伝説 #SNK #studio24餓狼 12:21 PM · Jul 19, 2022· Anthony.. Quote Link to comment Share on other sites More sharing options...
enoofu Posted July 20, 2022 Share Posted July 20, 2022 (edited) On 7/18/2022 at 11:13 PM, amiman99 said: Anyone here knows how I can connect this arcade panel to my MVS? Hard to tell wiring size but guessing .093 as these would be using multiple different wire sizes for American and Japanese controls. As these connectors can only fit one way they are designed to prevent wiring issues if you re-install the cable. 9 and 12 pin connectors were common for Jamma back in the day. Guessing the 9 pin is the pins for joystick 4 of them for left , right , up , and down. Other 4 are ground, with one unused. Guessing the 12 pin is for the buttons, 4 for ABCD, 1 for Start, 1 for Select, and the rest basically grounds These would plug into Female Adaptors that are then attached to by normal wires into a Jamma edge connector. Molex 9 Pin .093 Power Connector Male Plug Molex Connector, RECEPTACLE, 12-PIN, 0.093" MACHINE HARNESS https://ksarcade.net/new-used-pinball-boards-parts/molex-03-09-1126.html Edited July 20, 2022 by enoofu 2 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, Retro Arcade Stick Collective@RASCofficial 19h We're featuring one historic arcade stick a day in preparation for the Arcade Stick Museum event at #evo2022 The NEO•GEO AES stick was made to allow the user to achieve the arcade experience at home. One of the first with authentic arcade parts. Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, More from AtariAge member @SpicedUp!. Thank you as always Riko. NeoGeoForever@Neo_Geo_Forever Jul 19 Retro Gamer Magazine's "Perfect Ten Games" for the Neo Geo AES. Visit our Magazine Scan section here : https://neogeoforever.com/page/magazine-scan-menu… #NeoGeo #SNK #RETROGAMING #retrogames #arcade #KOF #FatalFury #MetalSlug Anthony.. 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 20, 2022 Author Share Posted July 20, 2022 Hi guys, More from @SpicedUp!. NeoGeoForever@Neo_Geo_Forever 6h Zed Blade, a refreshingly straightforward horizontal shooter where you battle against an evil super computer. Released by NMK for the Neo Geo in 1994 #NeoGeo #SNK #RETROGAMING #retrogames #arcadegames #NMK Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 Hi guys, SNK GLOBAL@SNKPofficial 22h 【KOF XV】 The PlayStation Store Summer Sale has begun! KOF XV, the latest in the KOF series, is 35% OFF! Up to 70% OFF for other SNK titles as well! #KOF15 #KOFXV Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 Hi guys, SNK GLOBAL@SNKPofficial 6h 【EVO2022】 SNK's official website for EVO 2022 is now open! In addition to KOF XV being a main-stage game, EVO 2022 will also feature an SNK booth exhibit with a variety of fun events! Please check it out! >Website https://snk-corp.co.jp/us/games/kof-xv/evo2022.pdf… #KOF15 #KOFXV #Evo2022 Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 Hi guys, SNK JAPAN@SNKPofficial_jp 【KOF XV ICFC Weekly Series】 獲得ポイントの上位8名による決勝大会「WEEK 9 FINALS」を7月21日(木)20時より開催! >日本語配信はこちら! https:// Translated from Japanese by [KOF XV ICFC Weekly Series] The final tournament "WEEK 9 FINALS" by the top 8 points earned will be held from 20:00 on Thursday, July 21st! > Click here for Japanese delivery! https://youtu.be/yFFcNtqh-Uo > Cast Yukinosuke @yukinojoooo Score @score33333 Gama no Abura @gamanoabura_nsb Eri @SSBU_Ellie #KOF15 #KOFXV #ICFCKOFXV 4:00 AM · Jul 20, 2022· Anthony... 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 Hi guys, SNK GLOBAL@SNKPofficial 5h [ACA NEOGEO APP] THE LAST BLADE ACA NEOGEO is available to download on iOS/Android devices today! App Store:https://apps.apple.com/us/app/the-last-blade-aca-neogeo/id1613290975… Google Play:https://play.google.com/store/apps/details?id=com.snk.acalb1… Look forward to more games on the way! #SNK #NEOGEO #ACANEOGEO Anthony.. 1 Quote Link to comment Share on other sites More sharing options...
amiman99 Posted July 21, 2022 Share Posted July 21, 2022 On 7/20/2022 at 12:50 AM, enoofu said: Hard to tell wiring size but guessing .093 as these would be using multiple different wire sizes for American and Japanese controls. As these connectors can only fit one way they are designed to prevent wiring issues if you re-install the cable. 9 and 12 pin connectors were common for Jamma back in the day. Guessing the 9 pin is the pins for joystick 4 of them for left , right , up , and down. Other 4 are ground, with one unused. Guessing the 12 pin is for the buttons, 4 for ABCD, 1 for Start, 1 for Select, and the rest basically grounds These would plug into Female Adaptors that are then attached to by normal wires into a Jamma edge connector. Molex 9 Pin .093 Power Connector Male Plug Molex Connector, RECEPTACLE, 12-PIN, 0.093" MACHINE HARNESS https://ksarcade.net/new-used-pinball-boards-parts/molex-03-09-1126.html I'll get jamma harness to make things easier. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Hwlngmad Posted July 21, 2022 Share Posted July 21, 2022 19 hours ago, Charlie Cat said: Hi guys, More from AtariAge member @SpicedUp!. Thank you as always Riko. NeoGeoForever@Neo_Geo_Forever Jul 19 Retro Gamer Magazine's "Perfect Ten Games" for the Neo Geo AES. Visit our Magazine Scan section here : https://neogeoforever.com/page/magazine-scan-menu… #NeoGeo #SNK #RETROGAMING #retrogames #arcade #KOF #FatalFury #MetalSlug Anthony.. What? No League Bowling?!? I cry gutter ball ?? 2 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 5 hours ago, Hwlngmad said: What? No League Bowling?!? I cry gutter ball ?? Hahaha. Good one Ryan. Anthony.. 1 Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted July 21, 2022 Author Share Posted July 21, 2022 Hi guys, SNK GLOBAL@SNKPofficial 20h [ACA NEOGEO APP] THE LAST BLADE ACA NEOGEO is available to download on iOS/Android devices today! App Store:https://apps.apple.com/us/app/the-last-blade-aca-neogeo/id1613290975… Google Play:https://play.google.com/store/apps/details?id=com.snk.acalb1… Look forward to more games on the way! #SNK #NEOGEO #ACANEOGEO Anthony... 1 Quote Link to comment Share on other sites More sharing options...
