Gurner Posted May 22, 2014 Share Posted May 22, 2014 I've got a couple of joysticks / game pads that have the same style of simple board inside: When the stick is moved or the button is pressed, the thin metal "blister" is pressed onto the contact below. However, sometimes, the contact only works when the stick or button is pressed super-hard, making it almost useless. - It's not a wiring issue, and the blisters line-up correctly with the contacts underneath. - This is for buttons on other controllers too, any ideas?? Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted May 22, 2014 Share Posted May 22, 2014 As I recall there are four small "pins" moulded into the joystick which press the switches, look to see if these have worn away or broken off. If that appear to be the case it may be possible to glue a section of plastic cockatiel stick in its place to restore operation although it that may not work for very long. However if all the "pins" appear to be ok try pressing the buttons with your fingers, if you still have difficult making them switch then problem is with the contact, replacing them with http://www.omron.com/ecb/products/pdf/en-b3d.pdf may restore operation although not having tried I myself I cannot be certain of that or of how easy it would be to perform the replacement. Quote Link to comment Share on other sites More sharing options...
UKRetrogamer Posted May 22, 2014 Share Posted May 22, 2014 (edited) Is the same true if you hold the circuit and press the blisters with a thumb? If not, I'd look at the plastic handle. Specifically, the ring at the base of the handle. If the ring becomes worn, the joystick becomes unresponsive. An alternative is to buy an upgraded circuit with gold-plated contacts from Best Electronics. Best carry spares for the joystick, including the plastic handle inserts. I have 2 upgraded 2600 joysticks fitted with these boards and they're ultra-responsive and feel like new. IIRC the boards aren't expensive. You might want to check out Bradley's troubleshooting instructions here: http://www.best-electronics-ca.com/CX40_REBUILD%20KIT.htm Edited May 22, 2014 by UKRetrogamer Quote Link to comment Share on other sites More sharing options...
UKRetrogamer Posted May 22, 2014 Share Posted May 22, 2014 If that appear to be the case it may be possible to glue a section of plastic cockatiel stick in its place to restore operation As opposed to Macaw or Parrot sticks? Gotta love auto-correct. Quote Link to comment Share on other sites More sharing options...
UKRetrogamer Posted May 22, 2014 Share Posted May 22, 2014 ...I also seem to remember seeing a hack somewhere to replace the domed switches with micro-switches. While I wouldn't mind trying this, it just wouldn't *feel* authentic. I prefer the dull, tactile click of the original blister switches in my CX40. I'll see if I can dig out a link and report back... Quote Link to comment Share on other sites More sharing options...
thecrypticodor Posted May 22, 2014 Share Posted May 22, 2014 Peel off the original tape thoroughly clean the domes as well as the contact points. Then re-tape them back down with packaging tape. Should work like new after that. Quote Link to comment Share on other sites More sharing options...
Gurner Posted May 22, 2014 Author Share Posted May 22, 2014 Peel off the original tape thoroughly clean the domes as well as the contact points. Then re-tape them back down with packaging tape. Should work like new after that. You're right, it works!! Thanks Funny that it didn't LOOK like the contacts were in the wrong spots visually, but removing it and replacing it again worked. Quote Link to comment Share on other sites More sharing options...
