+MrFish Posted February 2 Share Posted February 2 3 hours ago, tjlazer said: ok, where is this "pixel glitch" on the title screen? I can't find it. It's where the arrow points to in this image; and also in all identical locations of the border all along that side. It pops out and back in continually during the animation. 2 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted February 2 Share Posted February 2 15 hours ago, MrFish said: It's where the arrow points to in this image; and also in all identical locations of the border all along that side. It pops out and back in continually during the animation. 😱I am only seeing it after more than 40 years.😅 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 2 Share Posted February 2 37 minutes ago, ascrnet said: 😱I am only seeing it after more than 40 years.😅 Yeah, I'm glad I only saw it after it was fixed too. Quote Link to comment Share on other sites More sharing options...
Jetboot Jack Posted February 3 Share Posted February 3 Annoyed me every time I played from the day I bought my original cart! I find it funny how something so visible to me is invisible to others - I guess we all have slightly different wiring in our brains 😛 And now it is gone 🙂 sTeVE Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 4 Share Posted February 4 but how about adding the effect all the way around the inner edges of the box instead of removing it? could look interesting Quote Link to comment Share on other sites More sharing options...
Jetboot Jack Posted February 4 Share Posted February 4 11 hours ago, _The Doctor__ said: but how about adding the effect all the way around the inner edges of the box instead of removing it? could look interesting No 😝 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted February 4 Share Posted February 4 reassemble the project to make the xex to include the latest cosmetic change. 😉 Joust Fix.xex Quote Link to comment Share on other sites More sharing options...
ACML Posted February 5 Share Posted February 5 2 hours ago, ascrnet said: reassemble the project to make the xex to include the latest cosmetic change. 😉 Joust Fix.xex 16.11 kB · 3 downloads This version still won't load and execute with the SDRIVE loader for some reason. When the load finishes, you just get a silent black screen. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted February 5 Share Posted February 5 13 hours ago, ACML said: This version still won't load and execute with the SDRIVE loader for some reason. When the load finishes, you just get a silent black screen. The only explanation is that XEX support is very basic. Did you test it using an ATR with menu for example? According to what I see in the emulator it should work without problems. EXE: Loading program 0006-0019 to 2000-2013 EXE: Loading program 001E-001F to 02E2-02E3 EXE: Jumping to 2000 EXE: Loading program 0024-4023 to 8000-BFFF EXE: Loading program 4028-402A to 8488-848A EXE: Loading program 402F-4031 to 862D-862F EXE: Loading program 4036-4056 to 7F00-7F20 EXE: Loading program 405B-406D to 2000-2012 EXE: Loading program 4072-4073 to 02E0-02E1 EXE: Launching at 2000 Quote Link to comment Share on other sites More sharing options...
ACML Posted February 5 Share Posted February 5 The SDRIVE loader has been around awhile and is pretty robust, so I feel there has to be something different about this XEX. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 5 Share Posted February 5 If it works on all others and only fails on a certain device and it's variants... then... Quote Link to comment Share on other sites More sharing options...
ascrnet Posted February 5 Share Posted February 5 1 hour ago, ACML said: The SDRIVE loader has been around awhile and is pretty robust, so I feel there has to be something different about this XEX. Do the test I told you about to see if it loads from an ATR to rule things out. Some chargers have problems when an XEX uses 02E2-02E3 one or more than one for example. 😉 Quote Link to comment Share on other sites More sharing options...
ACML Posted February 5 Share Posted February 5 2 hours ago, _The Doctor__ said: If it works on all others and only fails on a certain device and it's variants... then... The SDRIVE has no problem loading previous XEX versions of Joust, so the issue is with this XEX file, not the SDRIVE. Quote Link to comment Share on other sites More sharing options...
Xuel Posted February 6 Share Posted February 6 On 2/1/2024 at 12:37 PM, ACML said: Any idea why this won't load with SDRIVE? It works fine with SIO2SD and Fujinet, but the XEX on SDRIVE will not execute. It loads, but goes to black screen and never starts. Can you try this XEX? It uses a simpler load sequence: joust.xex 2 3 Quote Link to comment Share on other sites More sharing options...
ACML Posted February 6 Share Posted February 6 25 minutes ago, Xuel said: Can you try this XEX? It uses a simpler load sequence: joust.xex 16.09 kB · 2 downloads Xuel, That did the trick. Works great now on a SDRIVE loader. Thank you very much, again! Quote Link to comment Share on other sites More sharing options...
