tschak909 Posted July 15, 2014 Share Posted July 15, 2014 Hi. I'm messing around and am setting up FoReM XE 5.4 onto a 16MB disk. So far, have managed to get everything loaded correctly, but when I finally start FoReM-XE, it loops at Initializing, taking up sector after sector, until the disk gets full, and just loops trying to write one more sector...no error messages...what could I be doing wrong ? -Thom Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted July 15, 2014 Share Posted July 15, 2014 Not sure... did you setup the message bases? I've never has any trouble getting it working here (other than when I modify the hell out of it...) Are you running the Start program first and letting that load foremxe? What is your modem interface? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 15, 2014 Author Share Posted July 15, 2014 n/m found the problem, was missing the Z: Handler, now trying to figure out why it's hanging up after I connect... grrr.. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 15, 2014 Author Share Posted July 15, 2014 My modem interface is the emulated R: in Altirra, which provides a Telnet interface. It looks like i'm going to have to patch the hell out of it to get it to properly connect and pass to the main BBS. Quote Link to comment Share on other sites More sharing options...
phaeron Posted July 15, 2014 Share Posted July 15, 2014 From what I remember, FXEP is a pain to debug because it constantly has TRAP handlers that hide any problems that occur. Most of the time I had to use the debugger to trap on the BASIC interpreter's write to STOPLN to see what line failed. It also uses EXTEND, which makes it harder to dump the BASIC code live. Two caveats on running it with Altirra. First, there was a bug in Altirra's R: handler that was causing FXEP to rapid-drop connections. You need a 2.50 test build with the following fix in the changelog: * Serial: Fixed control line status from status commands issued between OPEN and XIO 40 (was causing ForemXEP drops). Second, you will have trouble connecting above 2400 baud unless you edit the FXEP code's handling of short response codes, per the FXEP manual. Altirra's modem returns Conexant codes, which differ above 2400 baud from the US Robotics codes that FXEP defaults to. The other way is just to disable serial port throttling. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 15, 2014 Author Share Posted July 15, 2014 Ah, thanks, welp, that answers that. Yes, I've found the result code trapping code, and have been twiddling with it.. guess I'll wait for the next build of Altirra... God FoReM's code is a mess, I had forgotten just how horribly glutenous that BASIC could get, and yeah, trap everything, KEEP RUNNING AT ALL COSTS! EVEN IF IT'S OFF A CLIFF! The error I _was_ having, was because the Z: handler wasn't loaded, and it was just trying and trying again and again to open it, while being hit by a 130 error, only indication of this wound up being the user log, that was being filled up to oblivion. -Thom From what I remember, FXEP is a pain to debug because it constantly has TRAP handlers that hide any problems that occur. Most of the time I had to use the debugger to trap on the BASIC interpreter's write to STOPLN to see what line failed. It also uses EXTEND, which makes it harder to dump the BASIC code live. Two caveats on running it with Altirra. First, there was a bug in Altirra's R: handler that was causing FXEP to rapid-drop connections. You need a 2.50 test build with the following fix in the changelog: * Serial: Fixed control line status from status commands issued between OPEN and XIO 40 (was causing ForemXEP drops). Second, you will have trouble connecting above 2400 baud unless you edit the FXEP code's handling of short response codes, per the FXEP manual. Altirra's modem returns Conexant codes, which differ above 2400 baud from the US Robotics codes that FXEP defaults to. The other way is just to disable serial port throttling. Quote Link to comment Share on other sites More sharing options...
