+Saturn Posted September 29, 2014 Share Posted September 29, 2014 Hi,I collected, compiled and tested this info with flawless results. I'm posting what I have so hopefully others can benefit from this (overly) detailed, step-by-step info. Props and credit to Matthias, Jagware and Reboot for the info & tools. While there are alternatives to complete the encryption process a lot faster than the method I've detailed here, this way is a lot more fun imho Also, needed another cool link for my sig**************************************************************************************Websites:Step by step to your own encrypted Jaguar CD (zip file here w/ all Matthias' original tools)How to encrypt a Jaguar CDMatthias Domin homepageJiFFI downloadDOE CB (Alternative to clip.exe for copying text to the clipboard. Put cb.exe and main.c in "CD Tutorial files (updated ver)")***************************Just the steps:***************************Convert the file to BJL w/ JiFFI and change the file extension to BINMove the game file to the "CD Tutorial files (updated ver)" folderEdit "(Step2)(a).bat" w/ the game file's name in 3 places, quick save and run itRun "(Step2)(b).bat"Put a blank CD-R in the burnerRun "scanbus.bat"Edit "(Step3)burnunen.bat" w/ the device numbers and game file name (in one place)Quick save and run itTest the unencrypted game disk using a bypass methodSwap the 'BJL CD-encryption disk' into the Jag CD and power it upOpen HyperTerminal-File-Open-Jag Transfer.ht-Transfer-Receive File...Set a destination folderSet 'Use receiving protocol:' to XmodemClick the 'Receive' buttonPaste Filename of: cd_hash.dat THEN STOP!When prompted swap the CD in the Jag w/ the burnt onePress Pause and IMMEDIATELY click OK to confirm the "cd_hash.dat" file name.After completion of transfer, move "cd_hash.dat to folderRun "(Step4)PADCD.bat"Put a blank CD in the burnerEdit "(Step5)burnenc.bat" w/ the device numbers and game file name (in one place)Quick save and run itPlay the game************************************************************************************The directory structure of my setup:The following files are in a folder named "CD Tutorial files (updated ver)." They are the default contents and are able to return to only these afterward, if desired by running Xcleanup.bat. *Contents of batch/text files at bottom*!Instructions.txt(Step2)(a).bat(Step2)(b).bat(Step3)burnunen.bat(Step4)PADCD.bat(Step5)burnenc.batcb.exeCDEN16.ABScdrecord.execygwin1.dllhyperterm.bathypertrm.dll (copy this into the folder from original location)hypertrm.exe (copy this into the folder from original location)l.batmain.cMAKETRK.EXEPADCD.COMPM_DUMMY.DATscanbus.batText.txtTrk_2b.rawwarning.wavXcleanup.bat (this is the only Read Only file in the folder)***************************The detailed description***************************http://www.mdgames.de/jaguarcd/CreatingJaguarCDs.htmlStep 1, Define the CD-layout:-To ensure the (.ABS, .COF, etc.) file is a usable, header-less Binary, convert it to BJL format with JiFFI, then manually change it's file extension from BJL to BIN. (Doesn't matter if it was already header-less, the conversion with JiFFI won't hurt a thing, to my knowledge, and may save a coaster)*Note the load and run address(es) in the name of the converted file*-Make sure the game's filename doesn't exceed 8 characters (before the BIN file extension) as this will create problems later when the software automatically shortens it.-Add the single ".BIN" game file to "CD Tutorial files (updated ver)" folder per the example provided at "Step by step to your own encrypted Jaguar CD" website.************************************************************************************Step 2, Collect and convert the track-files:-To create the Boot Track, the easiest way is to edit the contents of "(Step2)(a).bat" to reflect the name of the single .BIN file being used, "Whatever.BIN" ex:MAKETRK -b4000 -z Whatever.BINPADCD +100000 Whatever.T00 Whatever.RAW-Quick save and double click it to create the necessary files.*WHATEVER.RAW and WHATEVER.T00 will be created*-To create the Dummy Track, the easiest way is to double click "(Step2)(b).bat" & it'll create the necessary files.Here's the text in (Step2)(b).bat:MAKETRK -z -t1 -mTRAK PM_DUMMY.DATPADCD +100000 PM_DUMMY.T01 PM_DUMMY.RAW*PM_DUMMY.RAW and PM_DUMMY.T01 will be created*************************************************************************************Step 3, Burn the unencrypted CD:The easiest way to determine what the burner drive's numbers are is to double click "scanbus.bat." (It HAS to be in the same folder as cdrecord.exe & cygwin1.dll)*Alternatively:*-Click Start-Run and type: cmd*-Paste the path to the folder followed by: cdrecord -scanbus.*ex:*C:\Users\Cylon10\Desktop\JagCD Creator package 09-25-14\CD Tutorial Files\cdrecord -scanbus-Determine the number of your CD burning device. (ex, my Laptop= 0,1,0 - my XP Desktop= 1,1,0)-Edit 'your burner specific' info into "(Step3)burnunen.bat" file along with the file name (one place for the name) to use and quick save it. ie, WHATEVER.RAW. (It HAS to end w/ the .RAW file extension)Matthias' example of "(Step3)burnunen.bat":cdrecord -speed=1 -dev=0,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=0,1,0 -pad -tao -audio hv.raw pm_dummy.raw trk_2b.rawAfter replacing with the current file:cdrecord -speed=1 -dev=0,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=0,1,0 -pad -tao -audio WHATEVER.RAW pm_dummy.raw trk_2b.raw-Place a blank CD-R into the burner.-Double click "(Step3)burnunen.bat" to start recording.NOTE: (Step3)burnunen.bat includes the "-tao" (track at once) switch which is necessary in newer versions of cdrecord*The cmd window with the cdrecord info will disappear when all operations are complete and will conveniently copy "cd_hash.dat" to the clipboard for use in Step 4*************************************************************************************Step 4, Encrypt the CD:Go to http://www.mdgames.de/jag_eng.htm and about halfway down the page, download and burn to disk one of the "BJL-version of the CD-encryption program" files. There's a .CDI and Nero version.**Before placing the 'BJL CD-encryption disk' in the Jag CD, setup the following:-(Preferrably) on a Windows XP machine connect the adapter to an RS232 serial port. The J.U.G.S. device is confirmed working on U.S. Jaguars. Matthias' pinout has not worked for me as the U.S. and European Jaguars apparently have different signaling.*For J.U.G.S. pinout, these adapters work using the same color code:http://www.amazon.com/gp/product/B008NCDN3I/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1*Color code is: red=1, black=2, yellow=3, green=5*A more comprehensive description here: http://atariage.com/forums/topic/229118-rj11-to-db9-pinout/?p=3071346*For Matthias' pinout, these adapters utilize the same color code (incompatible for me thus far in the U.S.):http://www.amazon.com/gp/product/B008NCDN3I/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1*Color code is: yellow=2, black=3, red=5*Matthias' pinout:http://www.mdgames.de/jaguarcd/cdencryption.htm-Connect a Jaglink Cable (or any "4 terminal" telephone line) to the RJ11 side of the adapter.-Connect the other end of the (telephone) line to a Jaglink (or compatible RS232 supporting device) that's connected to a Jaguar.Copy the two HyperTerminal files from their locations in XP to "CD Tutorial files (updated ver)." (the working folder)C:\Program Files\Windows NT\hypertrm.exeC:\WINODWS\system32\hypertrm.dllWhen you're ready to test an actual file after setting all this up, it should open automatically after the cmd window of "(Step3)burnunen.bat" closes, with data copied to the clipboard.(Should work in Windows 7 or above. If not, copy the included "hypertrm.exe" & "hypertrm.dll" files from the Apps folder to a location on your computer and open hyperterm.exe from there)-Either way, use the info detailed below to configure it:*-Open and configure Hyperterminal in Windows XP:*Start-All Programs-Accessories-Communications-HyperTerminal*Setup a new connection (use File-New Connection, if not prompted) with these settings:*Name: Jag Transfer (or whatever name you prefer)*Choose icon (if applicable)*In the "Connect To" box click the drop window next to "Connect using:" at the bottom and select COM1 (or the appropriate choice for your setup)*Click OK*In "Port Settings" box change "Bits per second:" to 115200*Data bits: 8*Parity: None*Stop bits: 1*Change "Flow Control:" to None*Click Apply*Click OK*(With HyperTerminal open onscreen and "Jag Transfer" as the current connection,) click File-Properties.*Click the "Settings" tab and ensure the following (from top to bottom of dialog box) are ticked/enabled:*Function, arrow, and ctrl keys act as: Terminal Keys (already set as default)*Backspace key sends: Ctrl+H (already set as default)*Emulation: TTY (has to be adjusted)*Telnet terminal: TELETYPE-33 (already set as default)*Backscroll buffer lines: 10 (has to be adjusted)*-Click the "ASCII Setup..." button at the bottom of the Settings dialog box and double check *the settings. The default are correct (if the below matches):*ASCII Sending:*Send line ends with line feeds: unticked*Echo typed characters locally: unticked*Line delay: 0 milliseconds.*Character delay: 0 milliseconds.*ASCII Receiving:*Append line feeds to incoming line ends: unticked*Force incoming data to 7-bit ASCII: unticked*Wrap lines that exceed terminal width: ticked*-Click OK*-Click OK(Alternatively, download & install teraterm-4.84.exe. See bottom of article for configuration)-Open HyperTerminal-Click File-Open and select 'Jag Transfer.ht'-Click Transfer-Receive File...-Set a destination folder (I use C:/1)-Set 'Use receiving protocol:' to Xmodem-Click the 'Receive' button***IMPORTANT!***-Paste (data automatically copied to clipboard after Step 3) or type in a Filename of:cd_hash.dat THEN STOP!!!!!**Once the above settings are verified and the name's entered in the Save filename dialog box, place the 'BJL CD-encryption disk' into the Jaguar CD unit and power up the Jaguar.-When prompted, remove the 'BJL CD-encryption disk' and replace the newly burned unencrypted game disk.*The Jaguar will read the contents, prepare Xmodem transfer and the side borders of the screen will turn green.***IMPORTANT!***-Press Pause on the Jaguar controller and IMMEDIATELY click OK to confirm the "cd_hash.dat" file name.-After however long it takes to transfer the data, the Hyperterminal transfer info screen will automatically disappear and the characters "Transmission finished!" will appear in the original HyperTerminal window.-Close HyperTerminal (or run through the process again to compare file sizes)-Navigate to the folder you saved "cd_hash.dat" to and move it into the 'CD Tutorial Files (updated ver)' folder.-Double click "(Step4)PADCD.bat" to pad the file to the right size (no need to edit if you used the name "cd_hash.dat")*TRK_2.RAW will be created*-Test the unencrypted version of the game using a bypass method************************************************************************************Step 5, Burn the encrypted CD:-Put a blank CD in the burner-Edit the "(Step5)burnenc.bat" file with the info (name/drive) for the current game file & setup. (One place for the name)ex; The original text from Matthias' example at http://www.mdgames.de/jaguarcd/cdencryption.htm is:cdrecord -speed=2 -dev=0,0,0 -pad -audio -multi warning.wavcdrecord -speed=2 -dev=0,0,0 -pad -audio bootprg.raw mainprg.raw trk_2.rawThe new info would be:cdrecord -speed=2 -dev=0,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=2 -dev=0,1,0 -pad -tao -audio WHATEVER.RAW pm_dummy.raw trk_2.raw-Click the "(Step5)burnenc.bat" file to write to the CD-When the black cmd window for cdrecord clears, eject the disk and play it on the Jaguar CD.*To automatically remove custom files and return the "CD Tutorial files (updated ver)" folder to its default state, the cmd window will prompt, "Are you sure you want to delete your files? [Y/N]"Choosing Yes or clicking the X to close the window will delete, choosing No will cancel.If you choose No and later find you want to restore the folder to default, double click "Xcleanup.bat."Please bear in mind, TeraTerm functionality has not been 100% tested/configured!*TeraTerm configuration:Open TeraTermTick "Serial" (changing from the default TCP/IP) and choose the COM Port to use.Click OKClick Setup at the top of the black windowClick Serial Port from the listChange Baud rate to 115200Data: 8 bitParity: noneStop: 1Flow control: noneTransmit delay: 0 msec/char 0 msec/lineTo receive the file, click File-Transfer-XMODEM-ReceiveNavigate to the file and move it to the working folder.************************************************************************************Contents of batch/text files in "CD Tutorial files (updated ver)" folder:!Instructions.txtall of the above(Step2)(a).bat (edit for every new project)MAKETRK -b4000 -z Whatever.binPADCD +100000 Whatever.T00 Whatever.RAW(Step2)(b).bat (no editing needed)MAKETRK -z -t1 -mTRAK PM_DUMMY.DATPADCD +100000 PM_DUMMY.T01 PM_DUMMY.RAW(Step3)burnunen.bat (edit for every new project)cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=1,1,0 -pad -tao -audio Whatever.RAW pm_dummy.raw trk_2b.rawclscall hyperterm.battype Text.txt | cb(Step4)PADCD.bat (no editing needed if file name cd_hash.dat is used)PADCD -2 *100002 CD_HASH.DAT TRK_2.RAW(Step5)burnenc.bat (edit for every new project)cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=1,1,0 -pad -tao -audio Whatever.raw pm_dummy.raw trk_2.rawclscall Xcleanup.bathyperterm.bat (no edit)start hypertrm.exel.bat (no edit)jag_lo -n -8 -b 0x100000 cden16.absscanbus.bat (no edit)cdrecord -scanbuspauseText.txt (no edit)cd_hash.datXcleanup.bat (Set as Read Only-no edit)@ECHO OFF:choiceset /P c=Are you sure you want to delete your files? [Y/N]if /I "%c%" EQU "Y" goto :goneif /I "%c%" EQU "N" goto :closegoto :choice:closeexit:gonemkdir tempmove !Instructions.txt tempmove (Step2)(a).bat tempmove (Step2)(b).bat tempmove (Step3)burnunen.bat tempmove (Step4)PADCD.bat tempmove (Step5)burnenc.bat tempmove cb.exe tempmove CDEN16.ABS tempmove cdrecord.exe tempmove cygwin1.dll tempmove hyperterm.bat tempmove hypertrm.dll tempmove hypertrm.exe tempmove l.bat tempmove main.c tempmove MAKETRK.EXE tempmove PADCD.COM tempmove PM_DUMMY.DAT tempmove scanbus.bat tempmove Text.txt tempmove Trk_2b.raw tempmove warning.wav temperase *.* /Qmove temp\* .rmdir temp 3 Quote Link to comment Share on other sites More sharing options...
ggn Posted September 30, 2014 Share Posted September 30, 2014 That's a nice guide there, good stuff that everything's been collected into once place! Two things I'd like to note: 1) Step 4 can be simplified a LOT if you have a skunkboard - just get our modified ecncryptor for Skunkboard, connect the skunkboard to the PC, open a jcp session like this: "jcp -c rbt_cden.abs", do the encryption steps on the jaguar as usual and wait for the transfer to finish so you'll be left with a file called "key.ggn" which should be the "cd_hash.dat" file in step 4. It might take a minute or two but that's the price you have to pay for us not bothering to speed the process up after we got it stable . 2) After we tried this process a few times we got so fed up that we ended up creating ULS (which morphed into JiFFI) which has a "get jaguar binary and spit out a discjuggler .cdi file" option. So now we can encrypt any bjl/abs/etc file without the need to use a jaguar at all . 5 Quote Link to comment Share on other sites More sharing options...
+Saturn Posted September 30, 2014 Author Share Posted September 30, 2014 That's interesting, especially the history of how JiFFI came to be Cyrano Jones pointed me to the 'Skunkboarded' encryptor and I was looking forward to investigating it next. Thanks for the details as I'll know that much more going in. I spent a couple of weeks jumping between Matthias' 3 pages and once I had a clue exactly what was needed and got the process to work, I made a 'super' folder for it all. Thanks for the props 1 Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted September 30, 2014 Share Posted September 30, 2014 I got a cart that will test encrypted discs easy when i made a cd to see if its ok... I think b&c or best sells them. Quote Link to comment Share on other sites More sharing options...
omf Posted September 30, 2014 Share Posted September 30, 2014 I got a cart that will test encrypted discs easy when i made a cd to see if its ok... I think b&c or best sells them. it was b&c, i actually uploaded the binary of that cart to the yopaz / elansar cd thread to aid in dodgey disc testing go check it out if anyone wants it 2 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted January 29, 2015 Share Posted January 29, 2015 (edited) Okay, I am not getting something, I think. Soooo, I get that JiFFi will take an ABS file and quick as a bunny make a .cdi file that should boot in the Jag no problem. So, I did that, the resulting CD-R works AWESOME with a Bypass cart. Without a cart, the JagCD just spins and spins and spins. Looks like it is THINKING about loading it, but never does (or I got tired of waiting) and it never displays the CD? symbol either. So, what am I not doing correctly? Edited January 29, 2015 by MacRorie Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted January 29, 2015 Share Posted January 29, 2015 Probably not burning it correctly. Check this. Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted January 29, 2015 Share Posted January 29, 2015 If it runs with a bypass but not without it is a media issue. My opinion (I have no proof, only a conclusion formed from lots of experience) is that the jaguar is very picky when it comes to performing the hash check - if the timing is out on that it'll fail. Too much seeking and out-of-the ordinary response times and it isn't happy. This is where the suitability (not necessarily quality) of the recordable media comes into play. Find a brand that works for you. It doesn't have to be the most expensive or best known, just the one that works best in your Jaguar CD. Quote Link to comment Share on other sites More sharing options...
ovalbugmann Posted January 29, 2015 Share Posted January 29, 2015 Yeah, That's happened to me before, an encrypted BIWN JagCD that after two years it would only boot with a bypass cart. I recommend Taiyo Yuden/JVC, gold Verbatim even gold MAM-A if you can afford it. Don't use just any old CD-Rs only high quality ones. Atari took away all the redundancy, error checking, correcting attributes with its proprietary CD format. Everything's got to be like perfect pretty much to run and or last years. All the original Atari dev CDs were top quality gold cyan dye ones. Quote Link to comment Share on other sites More sharing options...
Felyx Posted January 29, 2015 Share Posted January 29, 2015 As I print CD covers on my CD-R, I use Verbatim white CD-R (special for printing on it) and so far i never see any fail in reading. I am not sure they are top quality: to me they are just "normal" standard quality we can expect from branded CD-R. Now it is said CD-R dont last forever so let's see in how many years I will have to start again burning CD-R to replace the existing ones. Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted February 25, 2015 Share Posted February 25, 2015 So, I have been merrily burning CD-Rs of all of the home-brews I can find and all of the ST ported goodness that Cyrano has been putting out, but I cannot for the LIFE of me, figure out how to burn the RAW files I have found. cdrecord just does not work under windows 8.1 even with the ASPI driver installed. Any thoughts of how to burn, for example, this? Thanks Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 25, 2015 Share Posted February 25, 2015 Any thoughts of how to burn, for example, this? yeah, grab the ULS cdi image from here: ftp://ftp.untergrund.net/users/ggn/Jag%20PD%20collection/ Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted February 25, 2015 Share Posted February 25, 2015 yeah, grab the ULS cdi image from here: ftp://ftp.untergrund.net/users/ggn/Jag%20PD%20collection/ My god! It's full of stars! Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted February 25, 2015 Share Posted February 25, 2015 BURN IT! BURN IT ALL! 3 Quote Link to comment Share on other sites More sharing options...
jericho_21 Posted August 9, 2016 Share Posted August 9, 2016 B & C Computervisions sells encryption bypass carts for the Jaguar CD player. They're great. Kind of expensive, though. I think that they still run for approximately $40.00, if I recall correctly. They should still be on their site. 1 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted August 9, 2016 Share Posted August 9, 2016 B & C Computervisions sells encryption bypass carts for the Jaguar CD player. They're great. Kind of expensive, though. I think that they still run for approximately $40.00, if I recall correctly. They should still be on their site. And Jagtopia is free, *and* lets you use a Memory Track. 3 Quote Link to comment Share on other sites More sharing options...
jericho_21 Posted August 9, 2016 Share Posted August 9, 2016 Truth. Quote Link to comment Share on other sites More sharing options...
