+Stephen Posted April 16 Share Posted April 16 That looks amazing. I am interested in one. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 17 Share Posted April 17 Looks like someone really cares about their work, I'd definitely give it a thumbs up. Get one if you can guys! Quote Link to comment Share on other sites More sharing options...
macsonny Posted April 17 Share Posted April 17 20 hours ago, GALTRON said: The prints I order from the factory are, in addition to 3D printing, sandblasted, smoothed and hardened, so they look like they came from an injection molding machine (original). It is not a cheap operation, but it is worth the price. It looks amazing as you can see in the photo. Indeed, when I received the finished print, the lower bevels did not fit slightly, but I solved this problem by manually adjusting it to the floppy drive and it fit every one I had, and there were about 20 of them. I can order more from the factory and fit and sell. If anyone wants, I also attach an STL file so they can print it themselves. But I printed on one of the more expensive home 3D printers and there is nothing to compare it to. The one from the factory looks like the original, and the one made at home looks terrible and unsightly. ATARI 1050 MegaSpeedy panel.stl 2.49 MB · 10 downloads I've ordered 10 each of your MegaSpeedy and display PCB's which are due to arrive this Friday. Looks like I have a busy weekend ahead 🙂 I'm hoping you've ironed out a few of the issues I had in your design. Will let you know how I go. Quote Link to comment Share on other sites More sharing options...
GALTRON Posted April 17 Share Posted April 17 I changed a few things in the Mega Speedy board and in the display. In the original version it didn't want to work. I also slightly changed the front panel, but I forgot about the lower bevels and they need to be slightly adjusted, but it takes literally 5 minutes of work. Quote Link to comment Share on other sites More sharing options...
macsonny Posted April 17 Share Posted April 17 (edited) 1 hour ago, GALTRON said: I changed a few things in the Mega Speedy board and in the display. In the original version it didn't want to work. I also slightly changed the front panel, but I forgot about the lower bevels and they need to be slightly adjusted, but it takes literally 5 minutes of work. I got the boards made from the files you posted a week or so ago. Are they ok? Two source files were: Gerber_Mega-Speedy_Mega-Speedy_2024-03-31_Y2 Gerber_Mega-Speedy_display-bez_2024-04-05_Y1 Edited April 17 by macsonny Quote Link to comment Share on other sites More sharing options...
GALTRON Posted April 21 Share Posted April 21 Yes, the files I sent you are 100% OK. These are the files after my changes and already tested ;) Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted April 21 Share Posted April 21 There should only be two main 1050 bezel types, as there are two different 1050 cases: tandon vs world storage mechs. Quote Link to comment Share on other sites More sharing options...
GALTRON Posted April 24 Share Posted April 24 I had 3 types of Atari 1050 stations. The first ones had a different mechanism, but the front panel fits all 3 models. I checked on 3 different ones. The hole for the drive is in the same place, the lower frame differs in thickness by 1-2 mm. It doesn't make much difference. Quote Link to comment Share on other sites More sharing options...
macsonny Posted April 27 Share Posted April 27 On 4/25/2024 at 5:20 AM, GALTRON said: I had 3 types of Atari 1050 stations. The first ones had a different mechanism, but the front panel fits all 3 models. I checked on 3 different ones. The hole for the drive is in the same place, the lower frame differs in thickness by 1-2 mm. It doesn't make much difference. Which STL file are you using for the bezel? Quote Link to comment Share on other sites More sharing options...
GALTRON Posted May 8 Share Posted May 8 The main file on which I based my version was the file attached here. But I had to make a few corrections and then put it into production. ATARI 1050 MegaSpeedy panel.stl 1 1 Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 9 Share Posted May 9 9 hours ago, GALTRON said: The main file on which I based my version was the file attached here. But I had to make a few corrections and then put it into production. ATARI 1050 MegaSpeedy panel.stl 2.49 MB · 3 downloads Thanks for sharing! Quote Link to comment Share on other sites More sharing options...
