Bryan Posted January 2, 2015 Share Posted January 2, 2015 I can believe there are glitch issues with some 2600s after looking at a TIA I have here: Synertek C010444D-03 8114D The phi0 clock out of TIA has a ~60/40 duty cycle and phi2 is falling a little before the falling edge of OSC (although this will be 6507 dependent). This is out of spec according to the datasheet although I haven't seen any game issues. I think the main problem is skewed clocks causing a race condition where changes happen a cycle early. Anyway, I've been messing with interfacing some programmable logic to a 2600 and it wouldn't have worked if I'd relied on the original timing specs. I wonder how bad the "problem" TIAs are. 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 2, 2015 Share Posted January 2, 2015 Might that be the source of this TIA glitch where SCORE mode color is applied to the playfield one color clock cycle to soon? Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 2, 2015 Author Share Posted January 2, 2015 Yes. Normally, updates to registers take effect on the first pixel after the CPU write cycle (after R_W goes high), but if the duty cycle of the phi0 clock is off, the register update can take effect one pixel early. Atari was sloppy with their delays (or at least they needed better QC from their chip fabs). A small external circuit could generate a better phi0 and would probably fix the problem. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 4, 2015 Share Posted January 4, 2015 A part that falls out of spec? SAY IT A'INT SO! Quote Link to comment Share on other sites More sharing options...
