RMAC/RLN
Orion_
1 hour ago, dilinger said:
Hi,
I think I've found an issue with RLN V1.6.1.
If the options related to symbols are not used, the PSymbolTable and NumberOfSymbols fields in the coff will still be set.
It will create a problem if the fields are used by a tool or a debugger, because no symbols will be found in the file.
Could it be possible to fix this problem?
If the source code is available on Git, please let me know, I will try to have a look at the issue.
http://rmac.is-slick.com/ is actually the home page for both rmac and rln. If you want to take a look at the issue yourself, you'we more than welcome! You can also open a bug report at the rln bug tracker, if you have a repro case we could also have a look at it too.
Edited by ggn
Thank you for the information. I have open a bug about it with repro steps. Please let me know if you need more information.
Using the RLN -s option will add the symbols in the file but the offsets / values seem to not make sense. I will try to dig up before to open a different bug report.
After some days off (maybe two weeks?), I've updated rmac to 2.0.12 and now I get an error when I try to compile my projects, I've this definition in the makefile:
RMAC = rmac -fe -i/opt/local/bin/gcc68k/include;/Users/Shared/apps/Jaguar/projects/lib
When I call make I get
rmac -fe -i/opt/local/bin/gcc68k/include;/Users/Shared/apps/Jaguar/projects/lib -o obj/gpu.o gpu.s
/bin/sh: /Users/Shared/apps/Jaguar/projects/lib: is a directory
make: *** [obj/gpu.o] Error 126
Of course that it's a directory...
";" is a command separator in *nix like OSes.
You might either repeat "-i" or use ":" (guess)
Or use " around your path.
Edited by 42bs
Nope, I'm looking at rmac code and you can use -I option only one time, I've also tried with ':' but the code looks for a ";"
Ok, but now I've "invalid include path" error, and I've tested that both path exists... weird, I'll run rmac with the debugger.
Use the source, Luke: rmac supports only _one_ include path.
 411  case 'I':
 412                         {
 413                                 searchpath = argv[argno] + 2;
 414
 415                                 // Check to see if include paths actually exist
 416                                 if (strlen(searchpath) > 0)
 417                                 {
 418                                         DIR * test = opendir(searchpath);
 419
 420                                         if (test == NULL)
 421                                         {
 422                                                 printf("Invalid include path: %s\n", searchpath);
 423                                                 errcnt++;
 424                                                 return errcnt;
 425                                         }
 426
 427                                         closedir(test);
 428                                 }
 429
 430                                 break;
 431                         }
 411  case 'I':
 412                         {
 414
 417                                 {
 419
 421                                         {
 423                                                 errcnt++;
 424                                                 return errcnt;
 425                                         }
 426
 427                                         closedir(test);
 428                                 }
 429
 430                                 break;
 431                         }
Yes, I've just seen it... f*ck because they have changed the way it works, but there's a function called nthpath that looks for ';' to get multiple paths from a single argument.
It looks that there are more changes, for example I've in a source file a label defined with two colons at the end, so it's supposed that the label it's global, this label it's referenced from a second file and I've an .extern directive at the beginning but I get a linker error of an undefined reference even if I put a .globl label in the first file. :(
Nope, no we haven't changed the way it works. We just added code that validates the paths entered. But sadly there were issues in the routine that validates the paths. A patch has been submitted, but not yet applied to main. If you like you can apply it and recompile.
Also, I do appreciate the obscene language, makes it feel worth the trouble :)
(Seriously, we try to never change functionality because it might break stuff for people. We're really concerned about this every time we extend the assembler to support more things)
Repro case please, and we'll look into it. What is the problematic symbol's name?
(asking because there is a known issue of symbols clashing with register names, especially now since we added DSP56001 mode. It's something that I hope will be resolved soon)
Edited by ggn
Sorry
The symbol name are _gpu_events_list, _GPU_SPRITE_OFFSET_X, _GPU_SPRITE_OFFSET_Y, and a few more, by the way the symbols are defined into a GPU chunk but referenced from 68000 code.
I've also seen that I can't create a label name like "x" or "y" (it was a register equate), anyway I've changed them to cx or cy. No problem.
So, a small test case which we could try without doing (perhaps wrong) stuff at random and declaring it works is....?
working on it.
edited:
by the way I'm using gcc linker, not rln but it worked with the older version of rmac.
Edited by swapd0
Any interest in a small patch to accept ":" as a command separator in addition to ";"?  I've run into this as well.  I also wish I could specify paths using the env variable and the command line and have rmac use the union of the two, kind of like you can do with spec files and "-I" in gcc.  Any opposition to that?  I could work up a patch.
If it's useful to your workflow, we wouldn't object.  It will have to pass review though.  ;)
EDIT: I believe this is addressed in bug#167.  If it isn't, feel free to submit a patch.  RMAC is now up to version 2.0.20.  :)
Edited by Shamus
Should have checked the bug tracker first :-P
It's not easy to write a small example, here it's what I have.
- C/Asm library where I got some references to a GPU symbols that it's not compiled with the library, all GPU code files are copied into the include directory.
- The game includes the library code
- I have a gpu.s file like this:
    .include "jaguar/jaguar.inc"
_gpu_code_start::
    .gpu
    .org G_RAM
    movei #G_ENDRAM,r31
    moveta r31,r31
    .include "katu/gpu_event.s"
    .include "katu/gpu_sprite.s"
This way I can include more files with gpu code specific to that game. These two files must be included, and gpu_event.s must be first.
The game complies with no problem but I have linker errors for all symbols defined in gpu_event.s and gpu_sprite.s that are referenced from the library.
edit: I've tried with .globl directive or with -u option but it have the same error, undefined reference.
Edited by swapd0
I've compiled the just game (not the library) with the old version of rmac, and this is the output of nm with the gpu.o:
swapd0$ nm obj/gpu.o
00f02200 a A1_BASE
00f02208 a A1_CLIP
00f02220 a A1_FINC
00f00000 a _BASE
00f0323c A _GPU_MAX_VIDEO_X
00f03240 A _GPU_MAX_VIDEO_Y
00f03234 a _GPU_SPRITE_OFFSETS
00f03234 A _GPU_SPRITE_OFFSET_X
00f03238 A _GPU_SPRITE_OFFSET_Y
00f03048 A _gpu_build_sprite_list
00000000 T _gpu_code_start
00f03008 A _gpu_events
00f03044 A _gpu_events_list
00f0322c A _gpu_sprite_dst
00f03096 a align_last_sprite
00f030bc a build_sprite
00f030ee a continue_build_sprite
00000011 A event_fn
00000012 A events
00000013 A list_ptr
00000010 A return
The same thing with the new version of rmac, there are some labels without an address.
00f02200 a A1_BASE
00f02208 a A1_CLIP
00f02220 a A1_FINC
00f02204 a A1_FLAGS
00f00000 a _BASE
         U _GPU_MAX_VIDEO_X
         U _GPU_MAX_VIDEO_Y
         U _GPU_SPRITE_OFFSET_X
         U _GPU_SPRITE_OFFSET_Y
         U _gpu_build_sprite_list
         U _gpu_events
         U _gpu_events_list
         U _gpu_sprite_dst
         U event_fn
         U events
         U list_ptr
         U return
swapd0$
Right, after getting a good night's sleep the letters typed above start making sense :).
We're still lacking more info about the symbols themselves. Can you give an example of how they're defined? The last thing we fixed in symbol exporting had to do with symbols that were EQUd and GLOBALd at the same time. Seems like here we've stepped into a edge case we haven't considered.
I think that it mess around with .globl or :: directives to define a global symbol into GPU sections.
    .68000
    nop
    lea m68k_foo,a0
    nop
    .long
m68k_foo:
    dc.l 0
m68k_bar:
    dc.l 0
    .GPU
    .org $f03000
    nop
    movei #gpu_foo,r0
    nop
    .long
gpu_foo:
    dc.l 0
Output:
swapd0$ rmac -fe test.s -o out.elf
swapd0$ nm out.elf
00f0300c a gpu_foo
00000010 t m68k_bar
0000000c t m68k_foo
Now m68k_foo and gpu_foo are defined as global(::)
    .68000
    nop
    lea m68k_foo,a0
    nop
    .long
m68k_foo::
    dc.l 0
m68k_bar:
    dc.l 0
    .GPU
    .org $f03000
    nop
    movei #gpu_foo,r0
    nop
    .long
gpu_foo::
    dc.l 0
Output
swapd0$ nm out.elf
         U gpu_foo
00000010 t m68k_bar
0000000c T m68k_foo
swapd0$
Last code using old version of rmac:
swapd0$ rmac-old -fe test.s -o out.elf
swapd0$ nm out.elf
00f0300c A gpu_foo
00000010 t m68k_bar
0000000c T m68k_foo
Edited by swapd0
Right, I might have fixed it.
If you can compile your own rmac (I assume you can judging from the fact that you have patched it in the past), open object.c and go to lines 243 and 244 and comment them out. To be 100% clear, these should read:
    else if (globflag)
        st_shndx = 0;        // Global, not absolute
Then recompile and test. I checked and this code hasn't been touched since it was initially committed so when we added a fix for another issue (see above), the rmac listing reported your global/absolute symbol as:
           gpu_foo 0000000000F0300C  ag
(a=absolute, g=global)
However the exported symbol needed the magic value fff1 (at least according to https://docs.oracle.com/cd/E23824_01/html/819-0690/chapter6-94076.html#chapter6-tbl-16). Anyway, do try this out and tell us if it works so we can apply it to the main tree :).
    else if (globflag)
Done and it compiles the game, but I haven't tested it.
Edited by swapd0
