Atari 8-bit Software Preservation Initiative
Farb
16 hours ago, gnusto said:
Despite the file name instructions, it is not a CLOAD/RUN program, but the more rare "RUN C:" approach.
Boot Altirra as an 800/48K/OSB/Basic (probably other configs work). Do NOT have auto load casette set on (System menu/Auto Boot tape should be off). At READY prompt, type RUN "C and hit return twice.
Command line flags for above are:
/tempprofile /burstio /siopatch /fastboot /noaccuratedisk /hardware:800 /kernel:osb /memsize:48K /ntsc /artifact:none /basic /cart "<your path here>\Atari BASIC Revision A (1979)(Atari)(US)(400-800).bin" /cartmapper 8 /nocasautoboot /type "RUN `C~~"
Huh...yeah, never would have know that one! It surely works. Added to my Atari 8bit cheat sheet for future reference. Thank you!
Check the entry "Carrier Force (1983)(SSI)(US)[disk]". I believe it's missing the back side of the disk [Game Program]. Boot the single included and press space bar at main menu. Program will ask for the Game Disk.
Entry "Carrier Force v3 (1983)(SSI)(US)[disk]" does include 2x images (front and back) and have confirmed from viewing pictures from mobygames.com that the disk is a flippy with a front (Scenario) and back (Game) sides.
1 hour ago, mikic said:
Check entry "Colonial Conquest v1.0 (1985)(SSI)(US)[disk]". It hangs at boot. Have an .ATR image I picked up from another source that boots fine. Attached for comparison.
Unless noted otherwise I use Altirra 3.90 and have tried every system combo I know of.
It works with Altirra 4.00-36, just requires accurate disk timing (3.90 is likely fine). Altirra command line would be:
/tempprofile /burstio /siopatch /fastboot /accuratedisk /hardware:130xe /kernel:xl /memsize:128K /ntsc /artifact:none
or you can check on "Accurate Sector Timing" in Altirra System/Configure/Disk.
Incidentally as part of my Launchbox front end work I've written a little utility that uses a hash of the disk image to index into a DB to detect any tricky flags like this. It can be translated into Altirra compatibility database (and will be, when done). I wrote it as a separate command line utility so it would also work with atari800 for most cases - atari800 doesn't have all the same configuration choices as Altirra, so sometimes it's a no go.
Correct. We do not have a good dump of the Game Program side.
Interesting. It seems to require the siopatch checked on to boot fully. Won't run boot without it. I keep it checked off by default (along with accurate sector timing checked on), because I've had some that won't run with the siopatch checked on and/or without accurate sector timing. Another trick added to the cheat sheet!
Lode Runner's Rescue has 2 disks not just one.
The entry incorrectly shows:
Disk 1 of 1, Side A
Disk 1 of 1, Side B (Screen Disk)
Should be:
Disk 1 of 2, Side A (Atari Game Editor)
Disk 1 of 2, Side B (Commodore Games Editor and Game Screens)
Disk 2 of 2, Side A (Atari Game Screens)
Disk 2 of 2, Side B (Blank)
Noticed entry "Kampfgruppe v1.2 (1985)(SSI)(US)[disk]" is not a compete ATX set (has an ATX and an ATR). I think I had submitted a full ATX set a couple of years ago, but maybe I missed this one. I had a couple of dozen Atari 800/400 boxed titles in my mostly PC IBM collection that Pete Rittwage, from the C64 Preservation Society, imaged and preserved from the original disks. It's attached for inclusion in your collection.
Kampfgruppe v1.2 (1985)(SSI)[ATX][SM].rar
Check entry "Panzer Grenadier (1985)(SSI)(US)[disk]". Can't get it to boot in Altirra 3.90. I'm sure there's a trick I'm missing. Anyone get it to boot?
I actually own this one in my boxed collection and it was preserved by Pete Rittwage. It's attached. Not sure if the one in this collection is mine. Regardless I can't get mine to boot either! Anyone?
Panzer Grenadier (1985)(SSI)[ATX][SM].rar
Loads in multiple configs I threw at it, including sio patched and no accurate disk, so basically insta load.
Altirra command line:
/tempprofile /burstio /siopatch /fastboot /noaccuratedisk /hardware:130xe /kernel:xl /memsize:128K /ntsc /artifact:none /nobasic
I also tried sio patch off, accurate disk, loaded fine.
Edited by gnusto
twitchy enter
I reset all setting and it works. I must have messed something up playing around with settings earlier. All good!
Thanks for pointing this out. In the past, we only included ATRs in the collection for unprotected disks. Now that ATX is a more commonly supported format, I have been slowly replacing the ATRs with ATXs where possible. From the dumps that Pete submitted to us, Kampfgruppe, Panzer Grenadier and Computer Quarterback Teams Disk 1985 still had ATRs. I've updated the first two in the database but we don't have a good ATX for the latter due to disk corruption. I've also updated the database with you as the contributor for Pete's dumps. Thanks again for your contribution!
It's my pleasure. Pete did all the heavy lifting! I sent him hundreds of disks...I almost felt bad :)
I figured out how to get a single sided double density flux image using a8rawconv
a8rawconv scp1:96tpi -d mfm "Some Disk.scp"
How do you convert the .SCP to single sided double density .ATX or .ATR.  I get errors stating long sectors of 256 bytes.
I can go into APE and get an .ATR, but would still like to know how to get .ATX.
Paging @ijor and @phaeron
You'll have to wait for another release of a8rawconv, version 0.94 was released in August 2020 and the ATX specification wasn't updated to include double density support until October 2020.
  • 3 weeks later...
I am going through my non-original software and found this copy of Snokie.  I noticed that the archive has a non-original source also so I do not know if another non-original helps.
  It seems to have copy protection, but I do not know what it was copied from.
Snokie.zip
I thought that I posted this before, but I guess I did not.  The dumping hardware I am using is a Panasonic JU-475 and using the 0.94 of a8rawconv.  I noticed that the Alt Match Racer was updated 8 days ago with unknown hardware and software and was attributed to me for dump and contribution.
Everything I dumped from disk used the above hardware and software.
Thanks for the Snokie dump and the clarification on the drive hardware that was used. Non-originals are always helpful for verification.
I have updated the information in the database (although I used a8rawconv 0.92 to create ATXs from your SCPs).
