phaeron Posted April 11, 2015 Author Share Posted April 11, 2015 test 6 has something wrong with the disk emulation for copy and possibly other problems. "Something"? 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 11, 2015 Share Posted April 11, 2015 As started to play around with Amiga OCS coding with a dev chain consisting of VAsm, notepad++ and Winuae I have to say (and I told everybody at Revisiob party) that the combination of MADS, WUDSN IDE plus Altirra is unbeaten in retro coding scene. Try to code for other machines (except PC) and you realise that the Atari 8bitbscene is far away of the pack since peter dell and Avery and tebe combined strength! Thx Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 11, 2015 Share Posted April 11, 2015 I found a post that describes a possible Altirra (and Atari800Win) bug. It is here: http://atariage.com/forums/topic/237140-bug-with-h-device-when-putting-data-and-print-to-screen/?do=findComment&comment=3216234 I suggested to him that he post it here. Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 11, 2015 Author Share Posted April 11, 2015 It's not really necessary to cross-link threads like this -- I read the rest of the forum too. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted April 11, 2015 Share Posted April 11, 2015 (edited) "Something"? This is a screen shot of the failed copy to drive D2: (B:). Both from a partition to drive and PCLINK to drive. Copies from partition to partition do copy okay. Test 5 works okay. Edited April 11, 2015 by rdea6 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 11, 2015 Share Posted April 11, 2015 Where's drive I:? 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted April 11, 2015 Share Posted April 11, 2015 Drive I: is D9: on my ultimate 1mb setup. Also SORTDIR fails also on the mounted ATR, and also CHTD *.*, and any copy to the emulated drive fails. using SDX447 and the same setup Test 5 doesn't have this problem.. Saving a BASIC or LISTED file to emulated drive fails also..on Test 6.. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 11, 2015 Share Posted April 11, 2015 Drive I: is D9: on my ultimate 1mb setup. Also SORTDIR fails also on the mounted ATR, and also CHTD *.*, and any copy to the emulated drive fails. using SDX447 and the same setup Test 5 doesn't have this problem.. Saving a BASIC or LISTED file to emulated drive fails also..on Test 6.. OK. Reproducible here. File is actually copied, but the emulated floppy makes a lot of burps and spits out error 138 at the end of the copy. Quote Link to comment Share on other sites More sharing options...
kazan21 Posted April 11, 2015 Share Posted April 11, 2015 thanks Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 11, 2015 Author Share Posted April 11, 2015 Fixed -- accidentally broke one of the write commands while implementing write-verify timing: http://www.virtualdub.org/beta/Altirra-2.70-test7.zip http://www.virtualdub.org/beta/Altirra-2.70-test7-src.zip Took a bit longer than expected because I had to track down an intermittent write command retry issue that turned out to be an old Atari OS bug: 8297:247:107 | A=A0 X=FE Y=31 (N ) | EA8F: A0 00 LDY #$00 8297:247:109 | A=A0 X=FE Y=00 ( Z ) | EA91: 84 31 STY CHKSUM 8297:247:112 | A=A0 X=FE Y=00 ( Z ) | EA93: 84 3B STY CHKSNT 8297:248: 1 | A=A0 X=FE Y=00 ( Z ) | EA95: 84 3A STY $3A 8297:248: 4 | A=A0 X=FE Y=00 ( Z ) | EA97: B1 32 LDA (BUFRLO),Y ;$1BFC 8297:248: 9 | A=0E X=FE Y=00 ( ) | EA99: 8D 0D D2 STA SEROUT - NMI interrupt (VBI) .. 8297:249: 79 | A=0E X=FE Y=00 ( I ) | C02C: D8 CLD 8297:249: 81 | A=0E X=FE Y=00 ( I ) | C02D: 6C 16 02 JMP (VIMIRQ) ... 8297:250:107 | A=FF X=FE Y=00 (N I ) | 1A12: A0 00 LDY #$00 8297:250:109 | A=FF X=FE Y=00 ( IZ ) | 1A14: B1 32 LDA (BUFRLO),Y ;$1BFD 8297:251: 0 | A=40 X=FE Y=00 ( I ) | 1A16: 8D 0D D2 STA SEROUT 8297:251: 4 | A=40 X=FE Y=00 ( I ) | 1A19: 18 CLC 8297:251: 6 | A=40 X=FE Y=00 ( I ) | 1A1A: 65 31 ADC CHKSUM 8297:251: 9 | A=40 X=FE Y=00 ( I ) | 1A1C: 69 00 ADC #$00 8297:251: 11 | A=40 X=FE Y=00 ( I ) | 1A1E: 85 31 STA CHKSUM 8297:251: 14 | A=40 X=FE Y=00 ( I ) | 1A20: 4C 0E 1A JMP $1A0E 8297:251: 17 | A=40 X=FE Y=00 ( I ) | 1A0E: 68 PLA 8297:251: 21 | A=00 X=FE Y=00 ( IZ ) | 1A0F: A8 TAY 8297:251: 23 | A=00 X=FE Y=00 ( IZ ) | 1A10: 68 PLA 8297:251: 28 | A=0E X=FE Y=00 ( I ) | 1A11: 40 RTI 8297:251: 36 | A=0E X=FE Y=00 ( ) | EA9C: 85 31 STA CHKSUM 8297:251: 40 | A=0E X=FE Y=00 ( ) | EA9E: A5 11 LDA BRKKEY 8297:251: 44 | A=80 X=FE Y=00 (N ) | EAA0: D0 03 BNE $EAA5 8297:251: 48 | A=80 X=FE Y=00 (N ) | EAA5: A5 3A LDA $3A 7 Quote Link to comment Share on other sites More sharing options...
CrazyChris Posted April 12, 2015 Share Posted April 12, 2015 You have let her have a computer in the kitchen? And what is the first rule of IT!!! Reboot? 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted April 12, 2015 Share Posted April 12, 2015 Reboot? Nope, nor is it drop it from 3 inches (although that used to work before non socketed chips..) Quote Link to comment Share on other sites More sharing options...
CrazyChris Posted April 12, 2015 Share Posted April 12, 2015 Nope, nor is it drop it from 3 inches (although that used to work before non socketed chips..) What is the first rule of IT? Quote Link to comment Share on other sites More sharing options...
fujidude Posted April 12, 2015 Share Posted April 12, 2015 (edited) What is the 1st rule of fight club? Crap, I just broke it. Edited April 12, 2015 by fujidude Quote Link to comment Share on other sites More sharing options...
Keatah Posted April 12, 2015 Share Posted April 12, 2015 I have a serious problem with this 2.70 release. It takes up too much of my time!! Whatta'ya gonna do about it? Quote Link to comment Share on other sites More sharing options...
Keatah Posted April 12, 2015 Share Posted April 12, 2015 fail Actions like w1k's also affects the community as a whole. I know I'm more apprehensive to ask questions because I don't want to come across negative or disrespectful. Yes. I want it to be understood that whatever my apparent tone is; it is always supposed to be viewed as one of a suggestive nature like when asking for new features or changes. Never a demanding one. So forgive me if I get carried away. Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 13, 2015 Author Share Posted April 13, 2015 I have a serious problem with this 2.70 release. It takes up too much of my time!! Whatta'ya gonna do about it? Make it worse. http://www.virtualdub.org/beta/Altirra-2.70-test8.zip http://www.virtualdub.org/beta/Altirra-2.70-test8-src.zip Tweaks to ATOS S: driver for better compatibility with the XL/XE OS when drawing lines in GR.0 (which people actually do, and which has really weird behavior). Fix for recent regression in debugger that screwed up symbol lookups in the expression evaluator. Fix for a crash in the cartridge code with the MegaCart 1MB (2) mapper that I found by accident. Fix for not being able to drag and drop from the 7-Zip File Manager, which rejects drag requests that use the move cursor. 7zFM always uses a temp file, though, which is not great -- I may need to detect this and force virtual disk mode in that case. 6 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted April 13, 2015 Share Posted April 13, 2015 Make it worse. Very nice poison! Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted April 15, 2015 Share Posted April 15, 2015 (edited) Sorry, not interested. No problem. I have realized, that the "direct" layout in Altirra does exactly want I need However the keyboard layout in Windows has to be set to "US" (before I tested with german layout "DE" and the kay mapping didn't have much sense). I wondered about "Enable Function Keys". How can I access the keys: "HELP","SELECT","START","OPTION" if this feature is enabled? Thanks Edited April 15, 2015 by TheMontezuma Quote Link to comment Share on other sites More sharing options...
morelenmir Posted April 17, 2015 Share Posted April 17, 2015 (edited) MANY thanks for this Avery!!! I keep meaning to get back in to A8 and assembler and this might just give me the excuse As yet I have not looked at the v2.7 betas. However I will give this stable release a good going over and report anything I find not working or a bit flaky. One thing I really do want to thank you for specifically is the addition of the "DSDD" preset category in the blank disk creator wizard. That is very nice indeed. I may have more to say about that later along with a feature suggestion. For now I am going to run Altirra through its paces making virtual cartridges with the new Spartados v4.47 and so on. On an interesting note, it could be a random thing; just as I am writing this I have the SDX cartridge-writer working in Altirra to flash an 8mbit maxflash virtual cartridge. I am running without the SIO speed-up patch, so it is reading the disk *.ATR at the speed it would in reality and I have the 'disk sound' option selected for ultimate authenticity! However, the disk sound has suddenly stopped. Yet the beeping and the counters show Altirra is still reading and flashing... Perhaps something to look at or maybe a one off? I will try with the different flashers/disk images and report back. Edited April 17, 2015 by morelenmir Quote Link to comment Share on other sites More sharing options...
morelenmir Posted April 17, 2015 Share Posted April 17, 2015 (edited) I am going to post this separately as it may well be a genuine bug. I have 'R-Time 8' selected in the swish new 'Devices' dialogue interface. However my newly flashed "1M (8mbit) MaxFlash Cartridge (newer - bank 0)" version of "SDX 4.47 reports "R-Time 8 Not Present" on boot-up. This is not a problem only present with v4.47 as the same thing happens with versions 4.46 and 4.45. Another update to this. If I then go on to create a new virtual cartridge of the "Empty SIC! Flash Cartridge" type with "SSF39SF040" selected as the flash chip type and flash it with the appropriate SDX 4.47 flasher; no warning about "R-Time 8" being missing is given. Edited April 17, 2015 by morelenmir Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 17, 2015 Share Posted April 17, 2015 (edited) Do you have an emulated 8Mbit MaxFlash cart attached? It interferes with R-Time 8 (address conflicts). Edited April 17, 2015 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
morelenmir Posted April 17, 2015 Share Posted April 17, 2015 (edited) Hey FJC! I'm glad to see you are still hanging out here! Yep - I do indeed... I wonder why I never encountered that in the past when I have been playing with SDX? Weird! I am pretty sure that will be problem solved, but I will test it out by writing the SIDE1 firmware from the SDX 4.47 flashers and report back. Edited April 17, 2015 by morelenmir Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 17, 2015 Share Posted April 17, 2015 Are there any special steps required to set up MIO, other than attaching the MIO device, then a hard disk, then setting up the firmware? Select+Reset isn't doing anything. Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 18, 2015 Author Share Posted April 18, 2015 This is my recreation in Blender of what having an R-Time 8 and a MaxFlash cartridge in an Atari would look like: There's only one standard slot in an Atari -- you can't have two left carts in it if neither has a pass-through without a hardware mod involving either a soldering iron or a hammer. Are there any special steps required to set up MIO, other than attaching the MIO device, then a hard disk, then setting up the firmware? Select+Reset isn't doing anything. Nope, that should do it. One possibility is that the dump you have isn't in the order that Altirra is expecting -- attached is a dump that I use. MIO-V141-27256.ROM Quote Link to comment Share on other sites More sharing options...
