Bill Lange Posted July 1, 2015 Share Posted July 1, 2015 I recently added a nice looking 1200XL to my collection. Unfortunately, the keyboard doesn't seem to work. I testing it with just the BASIC cartridge installed. I then tested it with a couple of game cartridges (Galaxian, Jungle Hunt). I then tested with no cartridge, attempting to press the HELP key to enter the self-test mode. The only keys/function keys that appear to work are the "2" and the "Tab". Both of these keys work with BASIC installed. No other keys or function keys appear to work. I did disconnect the keyboard connector and the LED connector and reseat them. Any suggestions before I take it apart further. Regards, Bill Quote Link to comment Share on other sites More sharing options...
Tempest Posted July 1, 2015 Share Posted July 1, 2015 Your keyboard contacts probably need repair. I had a similar issue with mine. Check this guide out: http://www.retrobits.net/atari/keyboard.shtml Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted July 1, 2015 Author Share Posted July 1, 2015 Ok. Thanks. I will check that out. I'll try to short some of the keyboard pins together to see if I can get some characters to appear on the screen to see if I can narrow it down to the keyboard and not the Pokey chip. Regards, Bill Quote Link to comment Share on other sites More sharing options...
Tempest Posted July 1, 2015 Share Posted July 1, 2015 It's probably the keyboard traces. Almost all 1200XL keyboards seem to have this problem eventually. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted July 1, 2015 Share Posted July 1, 2015 Follow the Retrobits text and you will be OK. Currently, I use Bare Paint, a conductive, water-based coating. I also run 1/32" map tape between the fingers so I don't get shorts. You don't want the paint too smooth. Peel off the map tape after the paint dries some. You can remove the key frame and press keys with your fingers, if you want to see POKEY respond. Just press one finger across the connector and another on a key. Bob All 1200XL keyboards fail like this, for the most part. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 1, 2015 Share Posted July 1, 2015 I followed that repair guide last summer for the keyboards on both my 1200XL's and was very pleased. I also used the Bare paint, though I simply used a fine paintbrush and fixed the connector traces by hand. Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted July 1, 2015 Author Share Posted July 1, 2015 I removed the the keyboard and pressed directly on the Mylar and the keys seem to work fine. Now to that repair guide ... Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted July 1, 2015 Share Posted July 1, 2015 Silver conductive paint, gently ' paint ' the main traces on the keyboard Mylar. Carefully clean the board contacts, and the Mylar ones. Quote Link to comment Share on other sites More sharing options...
oracle_jedi Posted July 2, 2015 Share Posted July 2, 2015 (edited) I've done a few of these now and I am unconvinced that the problem in most cases is the carbon trace contact array that is shown in Figure 3 and 4 of the Retrobits article. In the last two machines I have restored, I have unpeeled the mylar key matrix from the circuit board, but not enough to break the contact array, and then essentially re-seated it by using electrical tape on the edges to get as tight a fit as I can. My best guess is that the key contact points on the mylar wear out, but in a highly focused area. The tiny adjustment made by un-peelign and re-seating the mylar moves the point of contact just enough to allow the keyboard to work again. Has anyone else experienced this? Edited July 2, 2015 by oracle_jedi Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted July 2, 2015 Author Share Posted July 2, 2015 I removed the mylar, clean the board with windex. I then cleaned the suspect area with Goo-gone and then windex. I taped the suspect area with scotch tape. Once all the screws were reinserted and tightened (especially the two on either side of the suspect area), it seems to work fine. I ordered the silver paint and will probably apply that as well next week. Thanks for the help. Now on to fixing the sio port and the monitor output. Bill Quote Link to comment Share on other sites More sharing options...
+mytek Posted July 2, 2015 Share Posted July 2, 2015 (edited) I was always impressed with the look and feel of the 1200XL keyboard, and it seemed to be quite robust. Never realized that underneath it was just mylar and flexible circuit traces. But it does make sense considering the very reasonable pricing compared to the 800 that preceeded it. However good thing there is a fix, since I would imagine these things are getting rather scarce (how many 1200XLs were built?). BTW; you did a great, or should I say fantastic job with that repair tutorial Bob. Edited July 2, 2015 by mytekcontrols Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 2, 2015 Share Posted July 2, 2015 Bob's is the definitive solution to a universal, inevitable problem. Every 1200XL keyboard I saw had the issue, and Bob's fix, followed to the letter, solved the issue every time. One thing I found useful is a couple of bits of electrician tape of the back side of the Mylar where the plastic lip between the two retaining screws presses it into place. The tape increases compression a bit and makes for good contact. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted July 2, 2015 Share Posted July 2, 2015 I have had some success with just repositioning the mylar on the PCB or cleaning the contacts or adding pressure to the connector with tape. But, none of these 'fixes' will work consistently or permanently, in my experience. Clean the gold contacts with 98% alcohol and paint the connector fingers. Bare paint seems to be superior to silver paint. Bob Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 2, 2015 Share Posted July 2, 2015 Bob, I think the conductive paint I've been using (in a little phial, requiring much shaking before use) is a little thin and had occasional trouble even after the contacts had been cleaned until I added the tape on the back. But I should imagine better quality paint would be a superior solution, exactly as you say. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted July 2, 2015 Share Posted July 2, 2015 There is a bar molded into the key frame that compresses the connector when you screw it together. If you add tape to this bar and close up the keyboard, it may work for a while, but the tape will expand/compress to the shape of the fingers leaving you with poorly compressed contacts. I even tried 1/32" map tape, applied only on the contact surface - didn't hold up. It seems that anything 'soft' just creeps away and anything 'hard' is inherently uneven. The idea behind the paint is to produce a 'lumpy' surface that will contact the mylar outside the circumference of the bar. This turns the mylar itself into a 'spring' that holds the contact in place. Lumpy is good... Bob Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 3, 2015 Share Posted July 3, 2015 Makes perfect sense. The tape backing has been fine for three years, but the paint was obviously a little thin in the first place. I'll dismantle it and re-do it some day. Quote Link to comment Share on other sites More sharing options...
