youki Posted August 25, 2015 Share Posted August 25, 2015 (edited) Hi All, Does all of you tested the last collectorvision cartridges you bought? I ask that because some of my friends got some cartridges recently and we tested them in a gaming session last week end , and it does not work. We had problem with Nibbly and Bagman the games won't start. The cartridge is not detected. Looking at the cartridges we have seen that on a track on the right of the connector the contact zone seems cut in two part. Not sure it the source of the problem , but on all other cartridges that works it is not the case. I suspect a set a PCB used by collectorvision has this problem. I did not test yet my own version of bagman , but it seems the track on the PCB has the same issue.. As soon as, i will have access to my console i will test. But i strongly recommend to test your games. Don't do just like me , put them on shelve waiting to have time to test... My friends will contact collectorvision , i'm sure they will find a solution for them. Edited August 25, 2015 by youki Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted August 25, 2015 Share Posted August 25, 2015 I play tested all of mine the day after I received them and they all worked fine. I'll give them another play on Friday to double-check. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 25, 2015 Share Posted August 25, 2015 All of mine work fine also: Bagman, Zanac, So You Want To Be a Knight and Starship Defence Force. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 25, 2015 Share Posted August 25, 2015 Are they using a PAL ColecoVision console to play the games? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted August 25, 2015 Share Posted August 25, 2015 There are one or two connectors that are split in half... one half goes to a logic chip, and the other half goes to the EPROM. This allows for easy programming (otherwise the logic chip interferes with the EPROM during programming). It should work well, if the contacts on the console are in good shape. When in the console, the two halves of the connector become connected, and life is good. If there's a problem with the console connector, then this could happen. In the next revision of the PCB, I'll add a jumper that can be soldered after programming to make sure the games work the same as any old ColecoVision game. Quote Link to comment Share on other sites More sharing options...
AtariBrian Posted August 26, 2015 Share Posted August 26, 2015 I have issues with one or two games also . One of them is Pippols . It acts like it is broken and I have to reset a few times if I remember correctly . Quote Link to comment Share on other sites More sharing options...
youki Posted August 27, 2015 Author Share Posted August 27, 2015 (edited) Are they using a PAL ColecoVision console to play the games? Not PAL, we uses SECAM colecovision with Scart cable in France. But i don't think it is related to that, because Nibbly and Bagman have been developped by Frenchies... and their cartridge works as far i know. Edited August 27, 2015 by youki Quote Link to comment Share on other sites More sharing options...
youki Posted August 27, 2015 Author Share Posted August 27, 2015 There are one or two connectors that are split in half... one half goes to a logic chip, and the other half goes to the EPROM. This allows for easy programming (otherwise the logic chip interferes with the EPROM during programming). It should work well, if the contacts on the console are in good shape. When in the console, the two halves of the connector become connected, and life is good. If there's a problem with the console connector, then this could happen. In the next revision of the PCB, I'll add a jumper that can be soldered after programming to make sure the games work the same as any old ColecoVision game. Interresting, it explains the split we see. . I don't know if it is an issue with the console connector (unfortunaly we had only one colecovision available)... but the problem occured only with Nibbly and Bagman all others games worked well on the same console. Quote Link to comment Share on other sites More sharing options...
