VisualbB on windows 10
mehguy
4 minutes ago, kisrael said:
Yeah, I know it's a different approach to thinking about code that I don't quite "get".
Just remember that VbB has more than one way to do something. For example, if you draw a sprite frame, you can drag and drop it where you want it in the code or you can simply copy the sprite data and paste it into the code that way.
When you drag and drop, if you make changes to the graphic, do those update where you put it in the code?
No, you have to remove the old data from the code and drag and drop again.
If the sprite is the kind that has upside down data, you can also flip the rows in the code using Flip Text and edit the sprite right there in the code.
Quote
Highlight some lines of code, select Flip Text and the order of the lines will be reversed. One use for this would be to temporarily flip sprite data so it's no longer upside down so you can do some quick editing right there in the Code Editor. When you're finished, you can highlight the sprite data again, select Flip Text and the sprite data will be upside down again.
yeah. that's the kind of thing that my mind has trouble with. the drag and drop is mildly convenient shorthand for a copy and paste one-way trip, not an actual live connection to an asset and the code like it is in other tools
Sometimes, in the interests of simplicity and transparency (making sure the programmer knows what's going on) - having more than one way to do it is actually a disadvantage!
But again, different strokes for different folks.
