ATARI TROLL Posted April 14, 2003 Share Posted April 14, 2003 I'm currently working on a pitfall hack. So far I've given the guy and idiana jones look. Does anyone have any other suggestions? Quote Link to comment Share on other sites More sharing options...
Greg Zumwalt Posted April 14, 2003 Share Posted April 14, 2003 Give him that Lara Croft look That's what I started to do... sort of a Tomb Raider feel. Got side tracked however. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 14, 2003 Author Share Posted April 14, 2003 Will do Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 14, 2003 Author Share Posted April 14, 2003 HERE IT IS... Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 14, 2003 Author Share Posted April 14, 2003 FORGOT THE GAME SORRY Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 14, 2003 Share Posted April 14, 2003 If you really want to make it interesting, change some of the colors around. It's pretty easy with Thomas J's disassembly of the game, just look through the code, make the changes, and recompile it with dasm. Here's what you should look for in the code: ; color constants: IF NTSC BROWN = $12 YELLOW = $1e ORANGE = $3e RED = $48 GREEN = $d6 BLUE = $a4 YELLOW_GREEN = $c8 PINK = $4a ELSE BROWN = $22 YELLOW = $2e ORANGE = $4e RED = $68 GREEN = $56 BLUE = $b4 YELLOW_GREEN = $78 PINK = $4a ENDIF BLACK = $00 GREY = $06 WHITE = $0e DARK_GREEN = GREEN - $04 DARK_RED = RED - $06 ; Harry's colors while climbing: ClimbColTab: .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte PINK .byte PINK .byte PINK .byte BROWN ; Harry's colors while running: RunColTab: .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte DARK_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte YELLOW_GREEN .byte PINK .byte PINK .byte PINK .byte BROWN You can experiment with the color codes, but if you search the forums you can find a color chart to help out. Make your changes, download a copy of dasm, type "dasm pitfall.txt -f3 -opitfall.bin" and you're all set. I've attached a copy of the disassembly to this post, however it's freely available at the Dig. Have Fun! AM pitfall__asm.zip Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 14, 2003 Author Share Posted April 14, 2003 THANKS....WILL GIVE IT A SHOT! Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 15, 2003 Author Share Posted April 15, 2003 Here is another modified version Quote Link to comment Share on other sites More sharing options...
Greg Zumwalt Posted April 15, 2003 Share Posted April 15, 2003 z26 vr 2.07 and 1.57 crashes instruction 12 at F000 The version 1 hack was okay. Hope this is resolved soon Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 15, 2003 Author Share Posted April 15, 2003 Wasn't quite sure if you meant the second hack I put out crashes? Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 15, 2003 Share Posted April 15, 2003 Wasn't quite sure if you meant the second hack I put out crashes? Yes, unfortunately, it does. The "indiana Pitfall2.bin" file crashes z26. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 15, 2003 Author Share Posted April 15, 2003 seems ok on stella, but I will try and work the kinks out! thanks for the headsup! Quote Link to comment Share on other sites More sharing options...
Keir Posted September 5, 2003 Share Posted September 5, 2003 Make your changes, download a copy of dasm, type "dasm pitfall.txt -f3 -opitfall.bin" and you're all set. I've attached a copy of the disassembly to this post, however it's freely available at the Dig. I've been working on a Pitfall hack using Thomas' dissassembly. After compiling it, I tried using Z26 and it was all funky. Invisible vines, no collision with logs, etc. So I tried compiling the unhacked file, and it did the same thing (should have checked that before I started working!) I found this old thread while looking for some help. I did everything you said, even using the file you posted but it doesn't work. I can compile other files so I just don't know what's wrong. Any ideas? Thanks, Keir Quote Link to comment Share on other sites More sharing options...
StanJr Posted September 6, 2003 Share Posted September 6, 2003 ; color constants: IF NTSC BROWN = $12 YELLOW = $1e ORANGE = $3e RED = $48 GREEN = $d6 BLUE = $a4 YELLOW_GREEN = $c8 PINK = $4a ELSE BROWN = $22 YELLOW = $2e ORANGE = $4e RED = $68 GREEN = $56 BLUE = $b4 YELLOW_GREEN = $78 PINK = $4a ENDIF BLACK = $00 GREY = $06 WHITE = $0e DARK_GREEN = GREEN - $04 DARK_RED = RED - $06 ; Question. Is this color chart for Pitfall ONLY, or is it universal for colors in ALL VCS games? Quote Link to comment Share on other sites More sharing options...
Lost Monkey Posted September 7, 2003 Share Posted September 7, 2003 Here is a link to the TIA Colour Chart posted to the Stella List by Glenn Saunders: http://www.biglist.com/lists/stella/archiv...9/msg00285.html All the values for the various colours are there. Quote Link to comment Share on other sites More sharing options...
StanJr Posted November 28, 2003 Share Posted November 28, 2003 Is there a final version of this hack? Awarding Stans want to know..... Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted November 29, 2003 Author Share Posted November 29, 2003 Still not finished but I am going to put some attention back into it. Since I am using a mac. I want to strictly use a hex editor this time instead of HOM. will the charts above work?? Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted November 30, 2003 Author Share Posted November 30, 2003 Getting closer.. Quote Link to comment Share on other sites More sharing options...
Csonicgo Posted November 30, 2003 Share Posted November 30, 2003 113,156 bay bee Quote Link to comment Share on other sites More sharing options...
StanJr Posted December 1, 2003 Share Posted December 1, 2003 so can we consider this done or still in progress. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted December 1, 2003 Author Share Posted December 1, 2003 Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted December 1, 2003 Author Share Posted December 1, 2003 Here are a few Quote Link to comment Share on other sites More sharing options...
StanJr Posted December 2, 2003 Share Posted December 2, 2003 Looks AWESOME! Well well done! Can't wait to play it! Wish the timer and lives were still there though. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted December 2, 2003 Author Share Posted December 2, 2003 Thanks again Stan. Your replying is what motivated me to finish what I started back in April-LOL. I was thinking maybe a label and instruction guied contest?? Im in the mood to send out a few carts here and there!! Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted December 2, 2003 Author Share Posted December 2, 2003 Thought I would add to this....Indiana Pitfall v.7 is a hack to the extreme 7th power. Meaning, It was Atari Maximus's Pitfall Trainer that I started hacking on way back when. Credit should be given to him where I failed to mention it above. So my Hats off to Atari Maximus. I like the unlimited lives and no timer. Gives my 2 1/2 year old a chance to play a game without the difficulty! Cheers Quote Link to comment Share on other sites More sharing options...
