phaeron Posted May 3, 2016 Author Share Posted May 3, 2016 Is it possible to use the mouse as input for PADDLE(0) and PADDLE(1)? I can only seem to get PADDLE(0) response: 10 ? PADDLE(0),PADDLE(1) 20 GOTO 10 Only the first column of numbers changes. Yes, but you need to customize the input maps. You want a second input map, or another controller within the same input map, that has Paddle B with the paddle knob mapped to one of the vertical mouse inputs. The exact input depends on what kind of mapping you want. Both absolute (screen position -> paddle value) and relative (movement -> paddle rotation) are possible. 1 Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 4, 2016 Share Posted May 4, 2016 PCLink fixes. Renaming should now return the correct status code and directories should be readable as byte streams instead of just FFIRST/FNEXT. It is much better now, thank you. But, eventhough the documentation suggests to pass a file mask to the OPEN call, the contents of the data stream should not be filtered. In other words, the mask passed to the OPEN call should be ignored, and the data stream should provide all the contents of the directory file. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 4, 2016 Author Share Posted May 4, 2016 Oops. Had to rewrite the way FNEXT works to fix it, but try now: http://www.virtualdub.org/beta/Altirra-2.80-test34.zip http://www.virtualdub.org/beta/Altirra-2.80-test34-src.zip Should give unfiltered byte access and filtered FNEXT access on the same handle. 1 Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted May 4, 2016 Share Posted May 4, 2016 Is it possible to use the mouse as input for PADDLE(0) and PADDLE(1)? I can only seem to get PADDLE(0) response: see http://atariage.com/forums/topic/246591-wilmunders-star-raiders-ii-released/?view=findpost&p=3391216 (and the link it contains) Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted May 4, 2016 Share Posted May 4, 2016 (edited) I'm using the switchable XEGS cart version of Turbo Basic found here (at the bottom of the page). However these step work OK in Altirra Basic so I unsure as to what the issue maybe. System / Devices menu and "Host Device ( H: )" dialog 1) If "Also install as D:" is checked and the system is booted then D: isn't mapped. Turbo Basic "DIR" command returns Err. 160 2) Bring up the dialog and uncheck "Also install as D:". Turbo Basic "DIR" command returns Err. 130 3) Bring up the dialog and check "Also install as D:" again. Turbo Basic "DIR" command now correctly displays the directory listing. Another clue: a) If launching a MyDos disk menu but then detaching D1: a 163 error is given when trying to read the directory. b) Uncheck "Also install as D:" / OK / Check / OK then permits the directory to be read again. c) If you re-attach the MyDos disk, the H: drive content is still listed rather than that of the inserted drive. Thanks, Mark Edited May 4, 2016 by Wrathchild Quote Link to comment Share on other sites More sharing options...
Atari_Force Posted May 4, 2016 Share Posted May 4, 2016 Some games, like "GETAWAY" in full screen mode: If I move to the left or right, the graphics are not nice (sync?). dumpsnap.rar 1 Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted May 4, 2016 Share Posted May 4, 2016 Yes, but you need to customize the input maps. You want a second input map, or another controller within the same input map, that has Paddle B with the paddle knob mapped to one of the vertical mouse inputs. The exact input depends on what kind of mapping you want. Both absolute (screen position -> paddle value) and relative (movement -> paddle rotation) are possible. Go it! Thanks. Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 5, 2016 Share Posted May 5, 2016 Oops. Had to rewrite the way FNEXT works to fix it, but try now: Yes, it seems to work now as expected, thank you. Some other thing: the debugger does not seem to react properly on breakpoints-on-access set for the addresses past the first 64k. Example: ba w $02c000 g From SDX prompt: POKE $02C000,$FF - no reaction. Same problem with ba r $02c000, later PEEK $02C000 - no reaction. Also the memory windows (Debug->Window->Memory) do not seem to allow peeking into the addresses higher than $FFFF. All in the 65C816 mode, 4 MB extra RAM enabled. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 5, 2016 Author Share Posted May 5, 2016 I'm using the switchable XEGS cart version of Turbo Basic found here (at the bottom of the page). However these step work OK in Altirra Basic so I unsure as to what the issue maybe. System / Devices menu and "Host Device ( H: )" dialog 1) If "Also install as D:" is checked and the system is booted then D: isn't mapped. Turbo Basic "DIR" command returns Err. 160 This cartridge installs its own DOS D: handler, which conflicts with the emulator's. You can't use both at the same time. Some games, like "GETAWAY" in full screen mode: If I move to the left or right, the graphics are not nice (sync?). Uh, "not nice"? I need a better description than that. Not seeing a problem here. Some other thing: the debugger does not seem to react properly on breakpoints-on-access set for the addresses past the first 64k. Example: Yes, apologies, some parts of the emulator are still not '816 aware and the breakpoint system is one of them. I've been fixing that slowly. 2 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 6, 2016 Share Posted May 6, 2016 Phaeron, there are some atr's posted in the Jumpman hacking thread located here http://atariage.com/forums/topic/252267-jumpman-hacking/?do=findComment&comment=3504131 They use a K loader and don't load on Altirra but do work on Atariwin 800 Plus, I've tried as much as I can to make them work. Am I correct in thinking these images would not work on a real machine? (my hardware isn't hooked up at the mo) Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 6, 2016 Share Posted May 6, 2016 Some games, like "GETAWAY" in full screen mode: If I move to the left or right, the graphics are not nice (sync?). Just tried your atr and I'm not seeing what you mean? You said sync so I'm presuming there's tearing, I'd suggest under View that you turn on Vsync but the chances are its an issue your end, even with Vsync its smooth as silk here.. Quote Link to comment Share on other sites More sharing options...
morelenmir Posted May 6, 2016 Share Posted May 6, 2016 Very small gripe/maybe bug. I am using the newest Altirra release, the PCL: emulator, SDX and its PCLink driver. Under BASIC I issue this command after typing in a programme: SAVE "DPCL:FILENAME.BAS" In return I get a high-pitched and extremely annoying whistle during the writing process. I next enter: LIST "DPCL:FILENAME.LST" Interestingly, this time I get no whistle at all. I have not experimented with PCLink before so do not know if this is normal. However it is quite painful!!! Quote Link to comment Share on other sites More sharing options...
Xuel Posted May 6, 2016 Share Posted May 6, 2016 Phaeron, there are some atr's posted in the Jumpman hacking thread located here http://atariage.com/forums/topic/252267-jumpman-hacking/?do=findComment&comment=3504131 They use a K loader and don't load on Altirra but do work on Atariwin 800 Plus, I've tried as much as I can to make them work. Am I correct in thinking these images would not work on a real machine? (my hardware isn't hooked up at the mo) I was able to boot the "less mysterious.atr" ATR in that post by adding exactly 99 bytes of zero to the end of it. Any less and it crashes. It's failing on a SIOV call with error 139 ($8B) Device NAK with the short ATR: 31) T=07673| 65,108 A=31 X=FE Y=80 S=F9 P=30 ( ) 0808: A9 01 LDA #$01 30) T=07673| 65,110 A=01 X=FE Y=80 S=F9 P=30 ( ) 080A: 8D 01 03 STA DUNIT [$0301] 29) T=07673| 66, 0 A=01 X=FE Y=80 S=F9 P=30 ( ) 080D: A9 52 LDA #$52 28) T=07673| 66, 2 A=52 X=FE Y=80 S=F9 P=30 ( ) 080F: 8D 02 03 STA DCOMND [$0302] 27) T=07673| 66, 6 A=52 X=FE Y=80 S=F9 P=30 ( ) 0812: A9 40 LDA #$40 26) T=07673| 66, 8 A=40 X=FE Y=80 S=F9 P=30 ( ) 0814: 8D 03 03 STA DSTATS [$0303] 25) T=07673| 66, 12 A=40 X=FE Y=80 S=F9 P=30 ( ) 0817: A9 80 LDA #$80 24) T=07673| 66, 14 A=80 X=FE Y=80 S=F9 P=B0 (N ) 0819: 8D 04 03 STA DBUFLO [$0304] 23) T=07673| 66, 18 A=80 X=FE Y=80 S=F9 P=B0 (N ) 081C: A9 08 LDA #$08 22) T=07673| 66, 20 A=08 X=FE Y=80 S=F9 P=30 ( ) 081E: 8D 05 03 STA DBUFHI [$0305] 21) T=07673| 66, 32 A=08 X=FE Y=80 S=F9 P=30 ( ) 0821: A9 1F LDA #$1F 20) T=07673| 66, 40 A=1F X=FE Y=80 S=F9 P=30 ( ) 0823: 8D 06 03 STA DTIMLO [$0306] 19) T=07673| 66, 56 A=1F X=FE Y=80 S=F9 P=30 ( ) 0826: A9 80 LDA #$80 18) T=07673| 66, 62 A=80 X=FE Y=80 S=F9 P=B0 (N ) 0828: 8D 08 03 STA DBYTLO [$0308] 17) T=07673| 66, 70 A=80 X=FE Y=80 S=F9 P=B0 (N ) 082B: A9 00 LDA #$00 16) T=07673| 66, 74 A=00 X=FE Y=80 S=F9 P=32 ( Z ) 082D: 8D 09 03 STA DBYTHI [$0309] 15) T=07673| 66, 82 A=00 X=FE Y=80 S=F9 P=32 ( Z ) 0830: AD 77 08 LDA $0877 [$0877] = $BA 14) T=07673| 66, 90 A=BA X=FE Y=80 S=F9 P=B0 (N ) 0833: 8D 0A 03 STA DAUX1 [$030A] 13) T=07673| 66, 98 A=BA X=FE Y=80 S=F9 P=B0 (N ) 0836: AD 78 08 LDA $0878 [$0878] = $00 12) T=07673| 66,103 A=00 X=FE Y=80 S=F9 P=32 ( Z ) 0839: 8D 0B 03 STA DAUX2 [$030B] 11) T=07673| 66,107 A=00 X=FE Y=80 S=F9 P=32 ( Z ) 083C: 20 59 E4 JSR SIOV [$E459] = $4C 10) T=07673| 66,113 A=00 X=FE Y=8B S=F7 P=B1 (N C) E459: -- High level emulation -- 9) T=07673| 67, 5 A=00 X=FE Y=8B S=F9 P=B1 (N C) 083F: AD 03 03 LDA DSTATS [$0303] = $8B T=07673| 67, 9 A=8B X=FE Y=8B S=F9 P=B1 (N C) 0842: C9 02 CMP #$02 7) T=07673| 67, 11 A=8B X=FE Y=8B S=F9 P=B1 (N C) 0844: B0 22 BCS $0868 6) T=07673| 67, 14 A=8B X=FE Y=8B S=F9 P=B1 (N C) 0868: A0 01 L0868 LDY #$01 5) T=07673| 67, 16 A=8B X=FE Y=01 S=F9 P=31 ( C) 086A: 8C 76 08 STY $0876 [$0876] 4) T=07673| 67, 20 A=8B X=FE Y=01 S=F9 P=31 ( C) 086D: 38 SEC 3) T=07673| 67, 24 A=8B X=FE Y=01 S=F9 P=31 ( C) 086E: 60 RTS 2) T=07673| 67, 48 A=8B X=FE Y=01 S=FB P=31 ( C) 073F: B0 CC BCS $070D 1) T=07673| 67, 60 A=8B X=FE Y=01 S=FB P=31 ( C) 070D: A9 46 L070D LDA #$46 0) T=07673| 67, 64 A=46 X=FE Y=01 S=FB P=31 ( C) 070F: 8D C6 02 STA COLOR2 [$02C6] Quote Link to comment Share on other sites More sharing options...
Atari_Ace Posted May 6, 2016 Share Posted May 6, 2016 The last sector is short 100 bytes, so I'm surprised 99 bytes worked, but you're right, the last sector needs to be padded out. Quote Link to comment Share on other sites More sharing options...
greatxerox Posted May 6, 2016 Share Posted May 6, 2016 (edited) hello is there a tutorial for newbies to use Altirra ? i never got an atari 800 so i don't know how to use it. my keyboard doesn't respond. oO Edited May 6, 2016 by greatxerox Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 6, 2016 Share Posted May 6, 2016 Thanks for the info Xuel and Atari Ace... Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 6, 2016 Share Posted May 6, 2016 Not sure what the cause is, but in Altirra, cold power-on goes to Self Test with this Ultimate 1MB BIOS with basically everything turned off (including SDX) and the BASIC slot set to Atari BASIC (with stock XL/XE OS): Ultimate1MBNew.rom On real hardware using the same config, the machine powers on direct to BASIC as hoped. Something to do with the default state of PORTB? Unsure. Quote Link to comment Share on other sites More sharing options...
Suppawer Posted May 6, 2016 Share Posted May 6, 2016 Some games, like "GETAWAY" in full screen mode: If I move to the left or right, the graphics are not nice (sync?). A friend has another PC with Windows XP. when the cars moves, the buildings (and other objects) look like this: I don't know if this always happens. With Win 7 (my Pc), works well. Quote Link to comment Share on other sites More sharing options...
greatxerox Posted May 6, 2016 Share Posted May 6, 2016 is there a little tutorial to use Altirra please ? Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 6, 2016 Share Posted May 6, 2016 Yes there is. This forum and the "How To Use" section in the help file should be able to answer all your questions. Quote Link to comment Share on other sites More sharing options...
greatxerox Posted May 6, 2016 Share Posted May 6, 2016 (edited) thx but i don't find the right topic Edited May 6, 2016 by greatxerox Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 6, 2016 Share Posted May 6, 2016 HELP contents Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 6, 2016 Share Posted May 6, 2016 Well, what's the question? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 6, 2016 Share Posted May 6, 2016 Not sure what the cause is, but in Altirra, cold power-on goes to Self Test with this Ultimate 1MB BIOS with basically everything turned off (including SDX) and the BASIC slot set to Atari BASIC (with stock XL/XE OS): Ultimate1MBNew.rom On real hardware using the same config, the machine powers on direct to BASIC as hoped. Something to do with the default state of PORTB? Unsure. D'Oh... ignore that. I had BASIC disabled in Firmware options. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 7, 2016 Author Share Posted May 7, 2016 Very small gripe/maybe bug. I am using the newest Altirra release, the PCL: emulator, SDX and its PCLink driver. Under BASIC I issue this command after typing in a programme: SAVE "DPCL:FILENAME.BAS" In return I get a high-pitched and extremely annoying whistle during the writing process. I next enter: LIST "DPCL:FILENAME.LST" Interestingly, this time I get no whistle at all. I have not experimented with PCLink before so do not know if this is normal. However it is quite painful!!! PCLink is a serial I/O bus device and therefore the usual SIO tones apply. The read tone is ~960Hz at standard speed, while the write tone is inaudible. PCLink is also capable of much longer transfers than a disk drive, which is why it's a single continuous tone. There are two ways around this problem. The first is to use /S when loading PCLINK.SYS, which will cause the PCLink driver to use regular SIO routines in a way that the emulator can accelerate. The downside to this is that there have been issues in the past with data corruption when the driver attempts to transfer in the banking window in this mode. The other way is to enable SIO burst transfers for the "Other" category, which will allow the PCLink driver to transfer as fast as possible and push the tone up out of the audible range. The last sector is short 100 bytes, so I'm surprised 99 bytes worked, but you're right, the last sector needs to be padded out. Ugh. Well, I suppose I can just pad out the disk image on load. A friend has another PC with Windows XP. when the cars moves, the buildings (and other objects) look like this: I don't know if this always happens. With Win 7 (my Pc), works well. 'This'? Are you referring to the one pixel shift near the top? Please be specific when referring to issues. Vertical sync (VSYNC) is required to avoid tearing. In Windows XP, this is only reliable in full screen mode and with a 3D capable video card. Altirra does not support true full screen mode with DirectDraw and so you will get tearing without a 3D accelerator. Quote Link to comment Share on other sites More sharing options...
