hizzy Posted February 2, 2016 Share Posted February 2, 2016 Hi, Are these still out there? I would like to get a couple extras to have for Atari repairs. Thanks!! Quote Link to comment Share on other sites More sharing options...
toiletunes Posted February 2, 2016 Share Posted February 2, 2016 (edited) 2600 is way more than just a couple... (runs away) Edited February 2, 2016 by toiletunes 1 Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 2, 2016 Author Share Posted February 2, 2016 Is this also known as a RF cable? Thanks! Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted February 3, 2016 Share Posted February 3, 2016 I'm not sure what you want. The 2600 uses a simple single rca cable. Any yellow video cable will work. Actually red and whites will work as well. There are some opinions that yellow work better but not from my experiences. Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2016 Share Posted February 3, 2016 I'm not sure what you want. The 2600 uses a simple single rca cable. Any yellow video cable will work. Actually red and whites will work as well. There are some opinions that yellow work better but not from my experiences. That would only be if the yellow cord was made with a thicker copper center wire and perhaps stronger shielding from the outer ground of the cord compared to the white and red audio cables from the same set. Sometimes all 3 are just interwoven threads of wire instead of a solid core. Solid core giving much stronger results than the former of course. Quote Link to comment Share on other sites More sharing options...
Schizophretard Posted February 3, 2016 Share Posted February 3, 2016 Is this also known as a RF cable? Thanks! It is only known as an RF cable. 2 Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 3, 2016 Author Share Posted February 3, 2016 I find that people use RF & RCA interchangeably. On the Atari age site, they refer to it as an RCA cable: https://atariage.com/howto/connect.html Best calls it RF: http://www.best-electronics-ca.com/2600_Tech_Tips.htm Is one term more popular than the other? To be specific, I'm looking for the stock RF/RCA cable. It's for a 4 switch woody Thanks! Quote Link to comment Share on other sites More sharing options...
Schizophretard Posted February 3, 2016 Share Posted February 3, 2016 I find that people use RF & RCA interchangeably. On the Atari age site, they refer to it as an RCA cable: https://atariage.com/howto/connect.html Best calls it RF: http://www.best-electronics-ca.com/2600_Tech_Tips.htm Is one term more popular than the other? To be specific, I'm looking for the stock RF/RCA cable. It's for a 4 switch woody Thanks! Fair enough. I just usually hear and refer to them as RF cables in contrast to composite cables being called RCA cables to make it clear that RF is what goes through the cable. Anyway, I think it may be somewhat harder to find them by themselves compared to other consoles since they are built into the Atari and usually sold together. Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 3, 2016 Author Share Posted February 3, 2016 Fair enough. I just usually hear and refer to them as RF cables in contrast to composite cables being called RCA cables to make it clear that RF is what goes through the cable. Anyway, I think it may be somewhat harder to find them by themselves compared to other consoles since they are built into the Atari and usually sold together. Best Electronics used to have them, but it looks like they are sold out One reason I like the stock cables is because the the plug inside is smaller than usual. The plug of yellow/red/white cables are too big for the 2600 case. The case doesn't close with those inside. Hopefully, Best will get more. Thanks! Quote Link to comment Share on other sites More sharing options...
+SabertoothRetro Posted February 3, 2016 Share Posted February 3, 2016 (edited) Any RCA cable will work. As you mentioned, the Atari plugs were a bit shorter so if case clearance is an issue for the replacement cable, get a right angle female to male rca connector. Better yet, get a right angle F-type female to rca male adapter and use a coax cable. Edited February 3, 2016 by atariLBC 2 Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2016 Share Posted February 3, 2016 I find that people use RF & RCA interchangeably. On the Atari age site, they refer to it as an RCA cable: "RCA" in this situation refers to a composite connection. RCA the company popularized this type of output and got their brand name associated with it because of that. Same as Kleenex is a brand of tissue but the name is so synonymous with that tissue they get called Kleenex no matter the brand. 1 single cord from an "RCA" composite set of 3 cables can be used in place of the "RF" cable common on older electronics but that is as far as their likeness goes. Confusing the 2 would only be out of ignorance. Also, the depth of the male connection of the RCA cables comes in many flavors depending what quality or brand of composite cables you have purchased. There is no standard depth. Try a local dollar store to find some composite cables to take one for your RF. If you want really nice ones go to an electronics store. The later should have various cables with a range of depths to the connectors. Probably get gold plated ones for a cleaner connection (and picture on the tv) there as well. 1 Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 3, 2016 Author Share Posted February 3, 2016 "RF" refers to a Rodan + Feilds connection. "RCA" in this situation refers to a composite connection. RCA the company popularized this type of output and got their brand name associated with it because of that. Same as Kleenex is a brand of tissue but the name is so synonymous with that tissue they get called Kleenex no matter the brand. 1 single cord from an "RCA" composite set of 3 cables can be used in place of the "RF" cable common on older electronics but that is as far as their likeness goes. Confusing the 2 would only be out of ignorance. Also, the depth of the male connection of the RCA cables comes in many flavors depending what quality or brand of composite cables you have purchased. There is no standard depth. Try a local dollar store to find some composite cables to take one for your RF. If you want really nice ones go to an electronics store. The later should have various cables with a range of depths to the connectors. Probably get gold plated ones for a cleaner connection (and picture on the tv) there as well. Thanks for the clarification! Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 3, 2016 Author Share Posted February 3, 2016 Any RCA cable will work. As you mentioned, the Atari plugs were a bit shorter so if case clearance is an issue for the replacement cable, get a right angle female to male rca connector. Better yet, get a right angle F-type female to rca male adapter and use a coax cable. image.jpeg image.jpeg Great suggestion! 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted February 3, 2016 Share Posted February 3, 2016 BTW, RF = Radio Frequency Quote Link to comment Share on other sites More sharing options...
toiletunes Posted February 3, 2016 Share Posted February 3, 2016 not Ralph Furley (from Three's Company) Quote Link to comment Share on other sites More sharing options...
hizzy Posted February 4, 2016 Author Share Posted February 4, 2016 Although there are other options, I'd be happy to buy any RF cables from scrapped 2600's. Should you have any, just let me know Quote Link to comment Share on other sites More sharing options...
AdamCB Posted April 2, 2016 Share Posted April 2, 2016 I have one from a 2600 I did an AV mod to. It's somewhere among my box of cables. I can dig it out if you want. Sent from my SM-G925V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tombstone Posted April 3, 2016 Share Posted April 3, 2016 I have quite a few of these, original ones. PM me if u are still looking. Sean Quote Link to comment Share on other sites More sharing options...
