drummer4261900 Posted February 12, 2016 Share Posted February 12, 2016 (edited) I just got my Neo Geo AES in the mail and its only playing sound and the text on the screen. When I pull up any game. I did have the Yellow and White AV cable reversed when I first plugged it in... What's going on? Below is a picture: Thanks for any help. Edited February 12, 2016 by drummer4261900 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted February 12, 2016 Share Posted February 12, 2016 Maybe bad av cable. Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 Is there another sytem that has a AV cable that would work? Quote Link to comment Share on other sites More sharing options...
+madman Posted February 12, 2016 Share Posted February 12, 2016 Sounds like a VRAM problem. If you turn the Neo on without a cart in it, what color screen do you get? It's not a problem with the cable. Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 yellow Quote Link to comment Share on other sites More sharing options...
+madman Posted February 12, 2016 Share Posted February 12, 2016 Yep, yellow screen = VRAM error. Could be a bad chip or broken or corroded traces leading to the VRAM. Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 I got it from Japan I really hate to return it how hard would it be to fix. I did notice there is something rattling around inside do you think that could be it? Thanks! Quote Link to comment Share on other sites More sharing options...
+madman Posted February 12, 2016 Share Posted February 12, 2016 Well it depends on what the problem is. If it's a broken trace, you have to find it and repair it. If it's a bad VRAM chip, you need to replace it. Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 (edited) I also looked on the board and noticed there is a big blob of hot glue cover 4 pins on one chip. Is it possible the hot glue is shorting it out? Is there any one who can fix it? Thanks! Edited February 12, 2016 by drummer4261900 Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 Here is a couple photos I don't see any issues maybe someone else can: Back of the board: Front of the board: Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 (edited) After examining it more I think I found the issue. There is a bunch of empty holes with no solder in them keep in mind the photo below doesn't show its just a small example. I put a red mark around one so you can see what I am talking about. After cross referencing it with a board photo I found online I think that the problem: Edited February 12, 2016 by drummer4261900 Quote Link to comment Share on other sites More sharing options...
+madman Posted February 12, 2016 Share Posted February 12, 2016 There are multiple versions of the Neo Geo board. Filling those holes w solder will do nothing. I already told you what the issue is, why did you ask for help if you plan on ignoring the answer? The yellow screen signifies a VRAM error. Go fill in random holes w solder if you really think that'll help, I'm done offering advice. 1 Quote Link to comment Share on other sites More sharing options...
drummer4261900 Posted February 12, 2016 Author Share Posted February 12, 2016 You said broken trace. I thought that may be what those are. Not sure what traces are. Quote Link to comment Share on other sites More sharing options...
HoshiChiri Posted February 13, 2016 Share Posted February 13, 2016 (edited) You said broken trace. I thought that may be what those are. Not sure what traces are. Traces are those little lines running all over the board. They move the current around. Since you know the problem is the VRAM, start by finding that and seeing if it's broken. Then look at the traces. Edited February 13, 2016 by HoshiChiri Quote Link to comment Share on other sites More sharing options...
