dwmcqueen Posted August 7, 2016 Share Posted August 7, 2016 My wife has banish my XEGS to my bedroom LED TV which only has HDMI and YPbPr inputs (no internal converter). After a failed attempt at using this - https://www.amazon.com/gp/product/B01EHL1JXE/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=ll1&tag=atariage&linkId=05e4ff056d97af9f74570ca233e5c65a, I am curious if I have any other options to get output into either of those formats? Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 7, 2016 Share Posted August 7, 2016 The XEGS (composite) video output should work just fine plugged into the YPbPr (aka Component) green input of the television. Component video input for Composite output: Green --> Yellow Blue --> None Red --> None Respecting the audio output of the XEGS, you can connect to either the white (Left) or red (Right) audio input of the TV, or have it sent to both sides utilizing something like this adapter to the television first. Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 7, 2016 Share Posted August 7, 2016 What about the antenna input? Though it'd need an analog tuner, and RF output isn't the best option. Alternate option is a converter. To HDMI, preferably from S-Video. Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted August 7, 2016 Share Posted August 7, 2016 Wives just don't understand--coolness. They want everything neat and clean, like Apple Computers. Sometimes I think Apples are chick computers (no unsightly wires or other things). Anyway, there has to be a mod out there. Too bad, cause I like my XEGS on a plain old CRT. I still keep a few for that purpose. It also sucks that a lot of newer TVs are skipping the composite inputs. Butts! Glad to know those up converter things don't work, eventually I too will have to find a solution to the problem. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 7, 2016 Author Share Posted August 7, 2016 It 'works" when connected to Green - BUT it is black and white only (no color). The XEGS (composite) video output should work just fine plugged into the YPbPr (aka Component) green input of the television. Component video input for Composite output: Green --> Yellow Blue --> None Red --> None Respecting the audio output of the XEGS, you can connect to either the white (Left) or red (Right) audio input of the TV, or have it sent to both sides utilizing something like this adapter to the television first. Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 7, 2016 Share Posted August 7, 2016 I use one of these on my XEGS (eBay LINK) fed via S-Video from one of Bryan's UAV boards. The resulting HDMI video quality is fantastic when using S-Video as the source, and better than anything else close to this price range (and believe me, I've tried a bunch of different up-converters). You can also feed this with composite video, but it won't be anywhere near as nice. Goes for about $40. The link I provided will get you the right model, but be careful if you buy it somewhere else, since they make one that's VGA input instead, and I believe another that is only composite. This one has both composite and S-Video inputs. - Michael Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 7, 2016 Author Share Posted August 7, 2016 What about the antenna input? Though it'd need an analog tuner, and RF output isn't the best option. Alternate option is a converter. To HDMI, preferably from S-Video. I thought antenna - but was worried about the quality (and I do have OTA antenna on this already).... Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 7, 2016 Author Share Posted August 7, 2016 Good idea - now just have to wait for UAV boards to be produced again I use one of these on my XEGS (eBay LINK) fed via S-Video from one of Bryan's UAV boards. The resulting HDMI video quality is fantastic when using S-Video as the source, and better than anything else close to this price range (and believe me, I've tried a bunch of different up-converters). You can also feed this with composite video, but it won't be anywhere near as nice. Goes for about $40. The link I provided will get you the right model, but be careful if you buy it somewhere else, since they make one that's VGA input instead, and I believe another that is only composite. This one has both composite and S-Video inputs. - Michael Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 7, 2016 Share Posted August 7, 2016 Here's a look at the video quality I get. And this picture really doesn't do it justice. - Michael Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 7, 2016 Author Share Posted August 7, 2016 Envy....that seems to be the way to go. In the interim, is there anything to do about the black and white output? Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted August 7, 2016 Share Posted August 7, 2016 The TV might be trying to sync to PAL instead of NTSC or vice versa. Check to see it the TV has a setting for PAL or NTSC.. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 7, 2016 Author Share Posted August 7, 2016 The TV might be trying to sync to PAL instead of NTSC or vice versa. Check to see it the TV has a setting for PAL or NTSC.. Good thought, but I don't see the setting. Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted August 7, 2016 Share Posted August 7, 2016 Is there a way to get the converter box to force a 4:3 aspect ratio to the TV? Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 8, 2016 Share Posted August 8, 2016 Is there a way to get the converter box to force a 4:3 aspect ratio to the TV? Not that I can see. If I push the resolution button, it cycles through 720 and 1080P at 50 or 60 Hz. - Michael Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 8, 2016 Share Posted August 8, 2016 It 'works" when connected to Green - BUT it is black and white only (no color). Unfortunately then, your component television input may not be able to handle a composite signal fed to it (I've had good luck with Panasonic, LG, Vizio, and Sumsung Flat panel TVs handling it just fine). If you have another set of component inputs try them. If not, you're back to needing a converter box; myteksolution seems to have provided a good solution in that scenario. Quote Link to comment Share on other sites More sharing options...
dwmcqueen Posted August 8, 2016 Author Share Posted August 8, 2016 Yep, if only the UAV was easily orderable, but I think that is the way. Unfortunately then, your component television input may not be able to handle a composite signal fed to it (I've had good luck with Panasonic, LG, Vizio, and Sumsung Flat panel TVs handling it just fine). If you have another set of component inputs try them. If not, you're back to needing a converter box; myteksolution seems to have provided a good solution in that scenario. Quote Link to comment Share on other sites More sharing options...
