Flojomojo Posted September 6, 2016 Share Posted September 6, 2016 D) The HD WEGA on the curb is probably there for a reason! I doubt it makes much difference, you're still going to get scanlines. The newer HD set is more likely to have square corners, which I find more pleasing. It's completely subjective of course. This speaks to it a little: http://www.gamefaqs.com/boards/916396-super-nintendo/71038693 Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted September 6, 2016 Share Posted September 6, 2016 D) The HD WEGA on the curb is probably there for a reason! I doubt it makes much difference, you're still going to get scanlines. The newer HD set is more likely to have square corners, which I find more pleasing. It's completely subjective of course. This speaks to it a little: http://www.gamefaqs.com/boards/916396-super-nintendo/71038693 Well sure...they got a flatscreen! You shoulda seen the U-turn I did in front of Habitat for Humanity to make sure no one beat me to that 32 inch beauty. As if anyone but me for 50 miles would want it! 1 Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted September 6, 2016 Share Posted September 6, 2016 Well sure...they got a flatscreen! You shoulda seen the U-turn I did in front of Habitat for Humanity to make sure no one beat me to that 32 inch beauty. As if anyone but me for 50 miles would want it! How did you haul it away, muscles? It probably weighed 100 lbs! Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted September 6, 2016 Share Posted September 6, 2016 How did you haul it away, muscles? It probably weighed 100 lbs! I pulled my car right up to it on the grass, they had it outside getting rained on. Even lifting it into the car was reminding me of hernia surgery, and the crap I would get from my wife if I ripped a gut again picking up a damn near worthless (to anyone else) TV. Even balancing it on my leg doing a weak man's lift left me with a bruise the exact shape of the front edge of the TV! Quote Link to comment Share on other sites More sharing options...
+phoenixdownita Posted September 6, 2016 Share Posted September 6, 2016 It appears that HD CRT at a point started to have digital framebuffers .... so no point. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted September 6, 2016 Share Posted September 6, 2016 Dang! I hope it still works. And I hope it keeps on working ... sometimes these street finds power on just fine, and don't demonstrate why they were abandoned until they've warmed up for an hour. (source: the old 13" CRT I grabbed from my neighbor's curb a few weeks ago for a little ColecoVision Flashback pseudo-retro action) Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted September 6, 2016 Share Posted September 6, 2016 It appears that HD CRT at a point started to have digital framebuffers .... so no point. It's possible they could be turned off. I haven't touched one in a while but disabling some of their signature video features under the "Advanced menu" as seen on page 65 of this instruction manual would probably produce some nice results for retro gaming. https://docs.sony.com/release/KV34HS510.pdf These two things in particular: HD Detailer: Wideband video amplifier has a high bandwidth frequency rating, which allows it to send more video information to the screen, resulting in finer picture quality, especially for HD sources. CineMotion: Reverse 3-2 pulldown processing provides optimal picture quality for film-based sources (media originally shot in 24 frames-per-second format). Quote Link to comment Share on other sites More sharing options...
7800fan Posted September 6, 2016 Share Posted September 6, 2016 It is worth pointing out some TV that do have composite shares the ports with component. You had to physically unplug the component cable to use composite. switch box won't work, if the TV has one component ports you have to decide if it's worth giving up classic consoles and hook up component to DVD players or later game consoles, or give up component and go composite all the way. My 32" Vizio is only 720 but it has separate composite, separate S-Video (auto switching so no plug swapping!), 2 component, 2 HDMI, and RF that supported older NTSC signal. Paid $150 for it slightly used and still working about 5 years later. So far it only fails on some 2600 games, both RF and composite modded. How did you haul it away, muscles? It probably weighed 100 lbs! The 27" Wega I got was 120 pounds and it was at the upper limit of my lifting ability. Based on how my fart sounded like, another 5 pounds and I would have had prolapsed rectum and slipped discs. 2 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted September 6, 2016 Share Posted September 6, 2016 you can use a switch but not an off the shelf one, you have to disconnect both the signal lead and the ground, so it has the same effect as disconnecting it Quote Link to comment Share on other sites More sharing options...
Blazing Lazers Posted September 7, 2016 Share Posted September 7, 2016 I pulled my car right up to it on the grass, they had it outside getting rained on. Even lifting it into the car was reminding me of hernia surgery, and the crap I would get from my wife if I ripped a gut again picking up a damn near worthless (to anyone else) TV. Even balancing it on my leg doing a weak man's lift left me with a bruise the exact shape of the front edge of the TV! Just did this on Labor Day, of all days. I feel your pain It is worth pointing out some TV that do have composite shares the ports with component. You had to physically unplug the component cable to use composite. switch box won't work, if the TV has one component ports you have to decide if it's worth giving up classic consoles and hook up component to DVD players or later game consoles, or give up component and go composite all the way. My 32" Vizio is only 720 but it has separate composite, separate S-Video (auto switching so no plug swapping!), 2 component, 2 HDMI, and RF that supported older NTSC signal. Paid $150 for it slightly used and still working about 5 years later. So far it only fails on some 2600 games, both RF and composite modded. The 27" Wega I got was 120 pounds and it was at the upper limit of my lifting ability. Based on how my fart sounded like, another 5 pounds and I would have had prolapsed rectum and slipped discs. Both y'all should like the set I just picked up. I've already got plenty so this spare is currently for offers: http://atariage.com/forums/topic/256741-interest-check-flat-wide-hd-crt-whdmi-in-and-remote/ Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 7, 2016 Share Posted September 7, 2016 I samsung 4k tv un55js700dxfa has only 1 rca port. It is shared with a component port. Soon it will be outdated. But as long as there is coax you can always hook up a vcr. But nes picture looks horrible and pixilated. 2600 However looks better than ever. And 5200 and 7800 are not bad either. Quote Link to comment Share on other sites More sharing options...
+phoenixdownita Posted September 7, 2016 Share Posted September 7, 2016 .... But as long as there is coax you can always hook up a vcr. ..... ...mmmmh .... no because it requires an analog tuner and many last gen TVs only offer a digital tuner (ATSC or DVB depending on continent) so the COAX plug is really useless to old console players. Even the VCR signal needs to be tuned in (usually channel 3 or 4 in NTSC land, can't remember what PAL suggested) on an analog channel. Quote Link to comment Share on other sites More sharing options...
ziggystar Posted September 7, 2016 Share Posted September 7, 2016 I believe Cartman had this problem in an episode of South park that took place in the future! Sent from my SM-T713 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Austin Posted September 7, 2016 Share Posted September 7, 2016 Obviously we can always seek out older tube TV's and early era flat screens, but can we expect that in 5-20 years a TV won't be able to play a 2600, NES or Genesis? Will this make classic gaming inaccessible to most who don't have the time/resources/space to seek out and set up in a special area a "retro gaming" TV? There will always be upscalers available that people can use to display their old hardware on their new displays. The issue is as simple as that. 1 Quote Link to comment Share on other sites More sharing options...
Dripfree Posted September 7, 2016 Share Posted September 7, 2016 As was said before most tv's do have a shared composite/component conection. I owned my tv for quite a while before I realized this, I actually did not say it on the tv or in the manual. My tv has a weird issue of not always detecting component but if I switch back and forth inputs it works. Im not too worried I believe I will always be able to get my hands on free crts for the rest of my life, and I believe for me thats the way I'll always prefer to play. Quote Link to comment Share on other sites More sharing options...
keepdreamin Posted September 7, 2016 Share Posted September 7, 2016 I don't think component is going to be on TV's much longer either... Already there. The samsung 8000 series 4K have no analog inputs whatsoever. 1 Quote Link to comment Share on other sites More sharing options...
Schizophretard Posted September 7, 2016 Share Posted September 7, 2016 I think just advancing video game technology has and is going to render older consoles obsolete to most. Quote Link to comment Share on other sites More sharing options...
omegadot Posted September 7, 2016 Share Posted September 7, 2016 My inlaws have a Vizio TV that I just couldn't get their old hand held plugin console to work on. To my credit it was at a fairly boozy holiday. If I recall it had this odd shared port setup for component / composite that was a new setup to me. Messing with the menus for a while just didn't seem to do much and now the little gaming box sits unused. I see a similar device (or the same one) was mentioned here already: http://atariage.com/forums/topic/193098-new-led-tv-annoying-combined-ports/ Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted September 7, 2016 Share Posted September 7, 2016 A little switch box with component and composite connectors is easy to find if someone absolutely positively must have many old things hooked up at once. I've got stuff like that but life is intervening ...and now I'm starting to see the appeal of a single HDMI port for a DVR or streaming device and nothing else needed. I suspect much of the non-gaming world rolls that way. Aren't they WEIRD? :-P Quote Link to comment Share on other sites More sharing options...
Newsdee Posted September 7, 2016 Share Posted September 7, 2016 (edited) In my limited experience with TVs, I noticed brands like Samsung are removing inputs and (in an older model) didn't seem to have good composite upscaling compared to an XRGB-Mini. Recently I picked up a lesser brand TV (AOC, they usually do monitors) and I was pleasantly surprised that it had a lot of physical inputs except SVideo. All without those proprietary dongle cables which tend to get lost that seem common on my Samsung TVs Edited September 7, 2016 by Newsdee Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted September 7, 2016 Share Posted September 7, 2016 This may be the time for everyone to go out and buy a TV that has all the different inputs before it is too late. Early Xmas? Quote Link to comment Share on other sites More sharing options...
keepdreamin Posted September 7, 2016 Share Posted September 7, 2016 A little switch box with component and composite connectors is easy to find if someone absolutely positively must have many old things hooked up at once. I've got stuff like that but life is intervening ...and now I'm starting to see the appeal of a single HDMI port for a DVR or streaming device and nothing else needed. I suspect much of the non-gaming world rolls that way. Aren't they WEIRD? :-P I think they're saying with a shared input, where yellow and green are combined together, a switchbox won't matter. Even though you could send composite through a green input on the switch box to the tv. The tv is not going to actually switch over to composite if it detects plugs inserted in Red/Blue. Someone correct me if I'm wrong. If these tv's do actually have manually selectable composite, even if you leave Red/Blue plugged up, then what I said above what actually work. For one component input on the switchbox, plug your composite source up to Green. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted September 7, 2016 Share Posted September 7, 2016 I think they're saying with a shared input, where yellow and green are combined together, a switchbox won't matter. Even though you could send composite through a green input on the switch box to the tv. The tv is not going to actually switch over to composite if it detects plugs inserted in Red/Blue. Someone correct me if I'm wrong. If these tv's do actually have manually selectable composite, even if you leave Red/Blue plugged up, then what I said above what actually work. For one component input on the switchbox, plug your composite source up to Green. Whoops, you're right! It's either composite or component. I have a TV like that. Buyer beware when you get a TV/monitor, I suppose. Quote Link to comment Share on other sites More sharing options...
Professor Gull Posted September 7, 2016 Share Posted September 7, 2016 I got a weird setup or as my friends would say a mass of wires and switch boxes and all of it ending in an up converter going to the plasma via HDMI from a s-video input. The one comment I did get from friends was the plasma looked to have a smoother animated frame for the 2600 hooked directly into it over the LCD. Anyone else notice this at all? I know thats probably a generic example but a Samsung 1080p 600 Hz plasma vs a Vizio 120HZ 55 1080p LCD is more precise for people that want a little more info. Quote Link to comment Share on other sites More sharing options...
Schizophretard Posted September 7, 2016 Share Posted September 7, 2016 This may be the time for everyone to go out and buy a TV that has all the different inputs before it is too late. Early Xmas? A couple Black Friday's ago I bought an Emerson TV and it still had all the inputs including s-video. That was actually the feature that made me buy it. 1 Quote Link to comment Share on other sites More sharing options...
