Atarisid VI
ivop
Hi all,
Atarisid is a software emulation of the SID soundchip used in the Commodore C64.
Recently, a conversation with wrathchild got me interested in atarisid again and here's the result.
What's new in version 6?
- Use three pokey channels instead of one
- Newly calculated wave forms
- Higher fidelity and dynamic range (over 21dB per channel)
- Use pokey noise generators for a much cleaner sound and different frequencies of noise
- Disables basic at startup
- 34 new songs for a total of 64 (which is not a coincidence :))
  Adam Gilmore                        -   Ninja Commando
  Adam Gilmore                        -   Zybex
  Ari-Pekka Paljakka (Zardax)         -   Retrograd
  Ben Daglish                         -   Bulldog
  Ben Daglish                         -   Cobra
  Ben Daglish                         -   The Vikings
  Ben Daglish                         -   Thing Bounces Back
  Chris Huelsbeck                     -   Metro Dance
  David Whittaker                     -   Glider Rider
  David Whittaker                     -   Loopz
  David Whittaker                     -   Speedball
  Hein Holt (Hein)                    -   Alien Seahorses Invading Heaven
  Jens-Christian Huus                 -   No Filter
  Jeroen Tel                          -   Alternative Fuel
  Jeroen Tel                          -   JT42
  Jeroen Tel / Maniacs of Noise       -   Alloyrun
  Jeroen Tel / Maniacs of Noise       -   Cybernoid
  Jeroen Tel / Maniacs of Noise       -   Cybernoid II
  Jeroen Tel / Maniacs of Noise       -   Hawkeye
  Jeroen Tel / Maniacs of Noise       -   Ice Age
  Jeroen Tel / Maniacs of Noise       -   Kinetix
  Jeroen Tel                          -   Myth Mix
  Jeroen Tel                          -   Noisy Pillars
  Jonathan Dunn                       -   Ocean Loader 4
  Lasse Oorni (Cadaver)               -   Aces High
  Lasse Oorni (Cadaver)               -   Escape From New York
  Lasse Oorni (Cadaver)               -   GoatTracker Example (MW1 Title)
  Lasse Oorni (Cadaver)               -   Metal Warrior
  Lasse Oorni (Cadaver)               -   Metal Warrior 2
  Lasse Oorni (Cadaver)               -   Nintedo Metal
  Lasse Oorni (Cadaver)               -   Tarantula
  Lasse Oorni (Cadaver)               -   Unleash The Fucking Fury
  Mark Cooksey                        -   Battle Ships
  Martin Galway                       -   Ocean Loader 1
  Martin Galway                       -   Ocean Loader 2
  Peter Clarke                        -   Ocean Loader 3
  Reyn Ouwehand                       -   What Have I Done To...
  Rob Hubbard                         -   Chimera
  Rob Hubbard                         -   Commando
  Rob Hubbard                         -   Crazy Comets
  Rob Hubbard                         -   Delta
  Rob Hubbard                         -   IK+
  Rob Hubbard                         -   International Karate
  Rob Hubbard                         -   Lightforce
  Rob Hubbard                         -   Monty On The Run
  Rob Hubbard                         -   Ninja
  Rob Hubbard                         -   One Man And His Droid
  Rob Hubbard                         -   Sanxion
  Rob Hubbard                         -   Spellbound
  Rob Hubbard                         -   The Master Of Magic
  Rob Hubbard                         -   Thing On A Spring
  Rob Hubbard                         -   Warhawk
  Stellan Andersson (Dane)            -   Escape From Reality
  Stellan Andersson (Dane)            -   The Slap Mix
  Thomas E. Petersen (Laxity)         -   Freeze
  Thomas E. Petersen (Laxity)         -   Highscore
  Thomas E. Petersen (Laxity)         -   Syncopated
  Thomas E. Petersen (Laxity)         -   Wisdom
  Thomas Mogensen (DRAX)              -   Scarlet
  Thomas Mogensen (DRAX)              -   Spunk
  Timo Taipalus (Abaddon)             -   Hamlet
  Tomas Danko                         -   Groove
  Torben Hansen (Metal)               -   Ramloesa
  Volker Meitz (PRI)                  -   Pool Party
atarisid6-xex.zip
atarisid6-src.zip
  • Like 14
Hi all,
Nice improvements.
I like this composition a lot.
Seems not to be working on Atari800WinPLus - anyone else having an issue or are most on Altirra?
Atari800WinPlus does not correctly emulate Read-Modify-Write instructions on pokey registers. Neither does the current atari800, but there's a patch here: https://sourceforge.net/p/atari800/mailman/message/34233143/
Altirra works fine, but it's enjoyed best on real hardware ;)
This is excellent! Question: It seems like your pulse wave duty cycle has greatly reduced resolution compared to the 12-bit resolution of the SID. How many steps do you support? Would adding more blow up the required number of tables beyond available memory?
It currently supports 20%, 40%, 60% and 80%. If I were to keep all the 8580 waveform mixing capabilites adding more pulsewidths would indeed exceed the available memory. I am thinking about removing those though as they are hardly ever used on 6581 tunes. Mapping them all to either pulse or triangle might be enough. That will open up two new possibilities. 1) all the tables will fit in one cartridge bank, or 2) more pulsewidths or more volume levels (also 4 right now).
Edited by ivop
Any possibility of detecting and compensating for speed difference on NTSC machines in the future?
Ah, I forgot all about that. This is doable as wrathchild already did it with as5. The other way around, i.e. playing NTSC tunes faster on a PAL machine, is a bit trickier.
btw. how to convert my own .SIDs to the player?
and what is those 3 IRQ mode you mention in the source code? Might it be possible to adapt for other consoles? Like 5200/7800 or even Atari Lynx? (I am searching for nice player...)
I have little time atm, but I could write a full guide in the future. In short it comes down to this:
You need sidreloc, siddasm2, atasm, atarisid6 sources, mads
- find a sid file that's not too big and would fit in $9000-$bfff (preferably $a000-$bfff)
- relocate the sid file; relocate zero page to $d0-$ef ($c0-$ff max); relocating to $9000 sometimes fails when relocating to $a000 works
- test resulting sid file
- disassemble with siddasm2
- replace 29 equates at the top with the contents of remap.txt (remapping the sid hardware registers)
- fix ill instructions, L_00xxx references and unknown labels (there are three scripts to automate that, or run fixall.sh foo.dis)
- assemble with atasm -r
- copy binary to songs directory, create corresponding .inc
- use setsong.sh to set the song name and use build.sh to build a.xex and test
- or run buildall.sh and test the file in xex/.
Some tunes need further patching (see for example zybex.dis, included in the songs directory) because those players toggle the gate bit twice within one call to the player routine and this would go unnoticed by the adsr emulation.
edit: the three irq thing refers to the three different irq routines that are run in a round-robin way. See irq.inc for those routines.
Edited by ivop
I downloaded all the XEX files and put it on a real 5.25 inch floppy to try on my 130XE. it works nice with Bibodos. But i am trying to get it to work with a menu system on my 130XE. SpeedMenu 3 loads all nice, but i am not able to do a hard reset. So, i tried some others that do the hard reset. But some of the XEX files dont work. even while most of the front screens with the info about the song show on the screen. Anybody an idea for a nice menu that uses RESET good. Oh, i put the files on several floppys in 180K DD format.
Employing the same technique as before, which was to adjust the ASDR timing table by 5/6 and skip one frame after having done five. This kicks in by itself if NTSC is detected and so the same executable runs PAL too. The results seem to come out OK in Altirra.
I will try if I have time at the weekend to incorporate this into Ivo's v6 source and an updated set of the existing binaries can be built.
I had a slightly different approach to the porting of a SID which involved hand editing the SID file in a hex editor to remap and spotted SID area read/write to the A8 player's shadows.
Once hooked into the player then Altirra debugging could easily spot any missed, e.g. used a write-to detection between when the PC is in the SID player's code area.
Additionally, any zero-page writes could affect the IRQ routine and so these should, as pointed out earlier, be remapped - but for example in Sanxion I tweaked the irq.inc to leave a hole where the SID player wrote to.
To get around loading of a SID player's code/data under the OS, I delegate that to exomizer and then included the self-extracting code during the loading. Just Sanxion in this set does that, but during this the font is lost (which is easy to fix).
Regards,
Mark
HyperSportsSid.xex
OceanLoader1Sid.xex
OceanLoader2Sid.xex
SanxionSid.xex
SpdBallSid.xex
Edited by Wrathchild
