+dhe Posted April 27, 2022 Share Posted April 27, 2022 I think I have found a bug!?! I start MAME with: D:\mame>mame genmod -bios 1.00 -peb:slot3 horizon -peb:slot5 tirs232 -peb:slot8 hfdc -peb:slot8:hfdc:h1 generic -peb:slot8:hfdc:h2 generic -peb:slot8:hfdc:h3 generic -peb:slot8:hfdc:f3 525dd -peb:slot8:hfdc:f4 525dd -hard1 genos7boot.HD -hard2 Bootdisk2.HD -hard3 Bootdisk3.HD -flop1 DSDD1.dsk -flop2 DSDD2.hfe -flop3 DSDD3.dsk -flop4 DSDD4.dsk -serl1 socket.localhost:10000 GeneveOS 7.3 boots up. If I do a: dir h: (scsi1) I get device error. If I do a: dir i: (scsi2) things lock up. What tools are available to see if this is a bug in MAME or a bug in GeneveOS? Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 27, 2022 Share Posted April 27, 2022 What is your SCSMAP settings? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 27, 2022 Author Share Posted April 27, 2022 The same happens for me. I'd vote for a GeneveOS bug. If you start the debugger (command line option "-debug") you see that it is spinning in these lines when you do a "dir i:" or "dir j:": 0d24 movb @>4fe2,R2 0d28 andi R2,>4000 0d2c jeq >0d24 Maybe we can locate that in the source code. Edit: This looks like waiting for the SCSI arbitration-in-progress bit. Interestingly, SCS1 does not lead into this loop. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 27, 2022 Author Share Posted April 27, 2022 2 minutes ago, 9640News said: What is your SCSMAP settings? It seems as if he does not use the SCSI card. I have these scsmappings: SCS1 = 0 SCS2 = 1 SCS3 = 2 SCS4 = 8 SCS5 = 9 SCS6 = A Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted April 27, 2022 Share Posted April 27, 2022 There might not be a device error trap to detect whether a SCSI card is present before performing the low level IO. Long ago, a DSR EPROM was not required to use the SCSI card with a Geneve. I think we've moved beyond that and if validation hasn't already been added to 7.3x as part of the in-process cleanup, the code should be added before a next release. Can someone please add this issue to the Geneve OS development thread if it is not a MAME issue? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 29, 2022 Author Share Posted April 29, 2022 MAME 0.243 has been released today. Luckily, my recent works are included already, that is, async mode for TIPI, and the details about the counter behaviour of the 9901. 5 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 29, 2022 Share Posted April 29, 2022 Coming to Whtech soon (please)? 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 29, 2022 Author Share Posted April 29, 2022 There you are. Just uploaded. 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 30, 2022 Share Posted April 30, 2022 @mizapf I am not sure if I am trying something presently unsupported with the TIPI and MAME. Using the Geneve emulation. I am able to access directory listings on the PI without issue. I have both the embedded telnet client in MDOS as well as MyTerm for the TIPI. When I attempt to use the TCP services, MAME aborts without any error messages and closes out the emulation. I guess my first question, is if TCP services are working, does Matt's telnet client work? Beery Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 30, 2022 Author Share Posted April 30, 2022 I'd need some more detailed descriptions to test it. I have certainly not tested every single edge of the TIPI emulation yet, so I expect to find some issues here and there. If MAME stops suddenly, this looks like a programming error that I have to fix. Did you try to enable logging with "-log" or "-oslog"? Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 30, 2022 Share Posted April 30, 2022 58 minutes ago, mizapf said: I'd need some more detailed descriptions to test it. I have certainly not tested every single edge of the TIPI emulation yet, so I expect to find some issues here and there. If MAME stops suddenly, this looks like a programming error that I have to fix. Did you try to enable logging with "-log" or "-oslog"? OK, here is what I got with -log error.log 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted April 30, 2022 Share Posted April 30, 2022 The TIPI TCP stuff is just messages using the same TIPI ROM functions that the TIPI DSRs use to send messages to and from for disk access. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 30, 2022 Author Share Posted April 30, 2022 MID interrupt; this happens inside the emulation: An invalid opcode was encountered. As it seems, the page that is mapped to execution page 0 is empty (at least at its beginning). Maybe you should use the debugger, set a breakpoint at 0068, and check the mapper at F110. The initial cause is not shown here, but the return vector should be there. Quote Link to comment Share on other sites More sharing options...
+9640News Posted April 30, 2022 Share Posted April 30, 2022 I used MAME's debugger and set a breakpoint at 0068 and MAME still crashed where I was not able to see what was at >F110. I will send you privately a set of files for you to review. Beery Quote Link to comment Share on other sites More sharing options...
Eric Lafortune Posted May 3, 2022 Share Posted May 3, 2022 For a new project, I'd like to create a cartridge file with a paged 8 MB ROM. I've started with layout <pcb type="paged377">, but I'm running into its 2 MB limit. I'm now considering a multicart setup with 4 such cartridges, but that seems a bit cumbersome to manage. Are there any other options? Sorry if I'm missing something obvious. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 3, 2022 Author Share Posted May 3, 2022 Can a 74LS377-paged cartridge manage more than 256 pages * 8 KiB = 2048 KiB? 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 3, 2022 Share Posted May 3, 2022 1 hour ago, mizapf said: Can a 74LS377-paged cartridge manage more than 256 pages * 8 KiB = 2048 KiB? With only 8 inputs/outputs, I would think not. Perhaps 2 chips could be ganged for more pages? ...lee 3 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 4, 2022 Share Posted May 4, 2022 @mizapf would you mind giving me the command line for a pure TI pbox and one for an ALL SNUG System? As far as you know, is there any problems with sharing a scsi hard drive image between an ALL SNUG system and Geneve Based system (or course not accessing at the same time)? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 4, 2022 Author Share Posted May 4, 2022 @Eric LafortuneIf you tell me how you plan to build such a cartridge, I'd be ready to add that to the set of cartridge types. The point is that I cannot just extend the 377 type, not only because it does not reflect what you can do with a 377, but I simply don't know how to map so many pages. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 4, 2022 Author Share Posted May 4, 2022 @dheFrom this list (https://www.mizapf.de/en/ti99/mame/emufeat) what do you want to see in the boxes? Currently I don't have the SNUG ASCSI in the list, so you would have to pick the WHTech SCSI. I don't see a problem with using the same SCSI drive in one or the other system. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted May 4, 2022 Share Posted May 4, 2022 (edited) 30 minutes ago, mizapf said: but I simply don't know how to map so many pages Just extend the existing system with more bits controlled by writing to more words in cartridge space. That's how the cart Dragons Lair cartridge works (the demo at least). Classic99 and JS99er supports it. DragonsLairDemo.rpk Edited May 4, 2022 by Asmusr 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 4, 2022 Author Share Posted May 4, 2022 I just checked my implementation; I would not suggest that you use the paged378 but gromemu instead. @Eric LafortuneThis should be the proper way for you, too. I planned the type gromemu as a catch-all for all kinds of GROM emulations (by EPROM) and also for the widest range of ROM sizes. It measures the ROM size and creates a bank mask from it. So, for setting the bank, in the extreme case you can write from 6000 to 7ffe (even addresses), i.e. up to 4096 banks by 8 KiB and hence up to 32 MiB. 3 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 4, 2022 Share Posted May 4, 2022 @mizapf you really need a buy me a coffee on your webpage! ? Original TI: TI-99/4A Peripheral Expansion Box 32K Memory Expansion Card RS232/PIO card (TI) TI Floppy Disk Controller Card DSK1 - DS/SD <= Which can be made with the TI Image Tool. DSK2 - DS/SD Questions: Is it possible to 'print' from the PIO port? SNUG Configuration: SGCPU (SNUG, TI-99/4A in the box) Peripheral Expansion Box RS232/PIO card (TI) Enhanced Video Processor Card 1 (SNUG) High Speed GPL Card (SNUG) BwG Floppy Disk Controller (SNUG) DSK1 - DS/DD DSK2 - DS/DD Two Items I see missing from the SNUG portfolio - High Speed RAM Disk - which is pretty kewl. SNUG Enhanced Speech Card. Reference: https://www.mizapf.de/en/ti99/mame/emufeat 1 Quote Link to comment Share on other sites More sharing options...
Eric Lafortune Posted May 4, 2022 Share Posted May 4, 2022 Thanks @mizapf -- gromemu is exactly what I need! It didn't occur to me that its ROM is paged too. Building new hardware would be beyond my capabilities. 2 Quote Link to comment Share on other sites More sharing options...
Eric Lafortune Posted May 5, 2022 Share Posted May 5, 2022 Actually trying it out now... The gromemu type seems to be subject to the same safety check as paged378: "Fatal error: Cartridge ROM size exceeding 2 MiB" (cartridges.cpp, line 148, introduced in Mame 0.205). I guess the check is not intended for gromemu? Quote Link to comment Share on other sites More sharing options...
