GDMike Posted October 29, 2020 Share Posted October 29, 2020 (edited) regarding my 1000 bytes in my CRAM.. Ive got 40 col screens and they total 1000 bytes if I read more ill overlap into my SNPS2 page or 3, 4. could I just PAD the following 28 BYTES with something? would that make things easier? ill just have to place something in my code during a READ that deletes them out Edited October 29, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 29, 2020 Share Posted October 29, 2020 (edited) ill set my VMBR to read my CRAM PAGE and get it to >1000 and set that routine up. ive already setup my routine for my SNPS1-4. as R4(record counter increases, I move only the coresponding 1000 bytes and pad 28 bytes to follow, I have another counter,R3 that counts up to 4 and places R3 into PAGE at every increment, then it resets to 1 and SAVES again to PAGE BUT increases my SAMS page >0100 and sets my correct SNPS1-4 again for moving again. anyway, it adjusts my SAMS pages to make sure im moving the right data in sequence when its time. Edited October 29, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 29, 2020 Share Posted October 29, 2020 (edited) ive got my data over to the VRAM Buffer @>1000 R3 contains my pages SNPS1-4, BUT one at a tiime as its going to loop AFTER I do a BL @ DSR then it will incremnt my record counter and adjust what pages need to be moved again, and loop until SAMS page ### OR EOF, OR no room on DISK, BUT hopefully I can plan to save out the DATA UP TO disk Full or prior! I have SBUFF1 EQU >FE4 RFPRC MOV R3,R1 * CRAM DATA LI R0,SBUFF * VRAM BUFFER LI R2,1000 BLWP @VMBW LI R0,SBUFF1 LI R1,PADD * 28 SPACES LI R2,28 BLWP @VMBW Edited October 29, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 30, 2020 Share Posted October 30, 2020 (edited) I added some things and I had to rename some of my previous labels, as some interfered with LABELS i was already using, IF the label IS NOT listed here, its existence is in another file, but it does exist. i just wanted to get everything out into the post that ive gotten made so far NOTE: DSRS is the entry point and Ive stopped at STOP because, well, im not sure what to do at this point. I do know, I tried to run this and received ERROR and I was returned back to my SNP program and everything was normal. BUT no write to DISK occured. **************************************** * FILEM - FILE MANAGAMENT 06/04/20 * * * * LAST UPDATE: 10/23/20 * * HIST:FIX ERRROR HONK TIMING * * NEED: SAVE PAB SETUP * * * **************************************** * BYTE 1 /0=OPEN 1 = CLOSED * BYTE 2 FILE TYPE >12 =OUTPUT,VARIABLE DISPLAY * NEXT POSITION=BUFFER ADDRESS * NEXT RECORD LENGTH >50 = 80 BYTES * NEXT CHARACTER COUNT * NEXT RECORD NUMBER * NEXT CASSETTE OFFSET * LAST IS FILELENGTH DESCRIPTOR LENGTH * NOTE: FILE DESCRIPTOR LENGTH * FOR FILE: 'DSK1.FILE1' = 10 >0A TLOAD TEXT 'LOAD DSK ' *** * * SAVE DSK FILE * *** GFERR1 B @GFERR DSRS LI R1,>1100 * SET TO PAGE 1 SAMS MOV R1,@BANK# CLR @PAGE INC @PAGE * SET PAGE TO 1 LI R0,929 CLR R2 INC R2 * R2=1 LI R3,>3000 * "0" BLWP @VSBR * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME IN R2 CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,>3900 * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,>2E00 * NOW ITS LEGAL, CONTINUE LOOKIN SG FOR "." PERIOD MARK INC R0 INC R2 * R2=2 BLWP @VSBR CB R1,R3 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R0 INC R2 * R2=3 LI R3,>4100 * LOOKING FOR A CHAR VALUE UPPER A-Z BLWP @VSBR CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,>5A00 * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,>2000 * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH INC R0 INC R2 BLWP @VSBR CB R1,R3 * FOUND END OF NAME YET?, NO, KEEP LOOKING JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,2 * WE ADD IN THE "DSK" 3 BYTES TO GET OUR FULL DESCRIP # MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR * START PROCESSING... LI R0,120 LI R1,>2000 * CLEAR SCREEN AREA CSVA BLWP @VSBW INC R0 CI R0,960 JLT CSVA BL @BEEP LI R0,324 * MESSAGE "SAVING..." LI R1,SVMG LI R2,12 BLWP @VMBW LI R0,337 LI R1,FLNM MOV @COUNTP,R2 BLWP @VMBW * DO THE WRITE! LI R5,>1000 * USED T SET BANK# CLR R3 LI R0,PBAD LI R1,FSPAB MOVB @COUNTP,R2 SRL R2,8 AI R2,10 BLWP @VMBW CLR R4 * RECORD COUNTER AI R5,>0100 * SET BANK# MOV R5,@BANK# * INITIALLY >1100 INC R3 * R3=PAGE# 1-4 MOV R3,@PAGE INC R4 * IS A 1 THE FIRST TIME RFPB BL @GTBNK * GET THE BANK SET TO >1100 AND PAGE TO 1 (SNPS1) RFPC MOV @PAGE,R3 CI R3,1 JNE RFPD LI R3,S32P1 B @RFPRC RFPD CI R3,2 JNE RFPE LI R3,S32P2 B @RFPRC RFPE CI R3,3 JNE RFPF LI R3,S32P3 B @RFPRC RFPF LI R3,S32P4 RFPRC MOV R3,R1 * CRAM DATA LI R0,SBUFF * VRAM BUFFER LI R2,1000 BLWP @VMBW LI R0,SBUFF1 LI R1,PADD * 28 SPACES LI R2,28 BLWP @VMBW * LOOP HERE BL @DSR EOJPP B @EOJP MOVB @WRITE,R1 BLWP @VSBW CLR R4 * RECORD COUNTER WRITEF BL @DSR MOV @EOFP,@EOFP JNE EOJPP *** STOP STOP LIMI 2 LIMI 0 JMP STOP MOV @PAGE,R3 * AFTER DSR IS DONE INC R3 CI R3,4 JLE CJPB * HIGHER THAN PAGE 4, INC SAMS BANK SET PAGE TO 1 LI R3,1 MOV R1,@PAGE MOV @BANK#,R1 AI R1,>0100 MOV R1,@BANK# JMP RFPB CJPB MOV R3,@PAGE * CONTINUE MOVING JMP RFPC * READ SNPS 1-4 PAGES * SET BANK# BL @DSR MOVB @READ,R1 * SET TO OPEN! LI R0,PBAD BLWP @VSBW CLR R4 * RECORD COUNTER * NOT USED BELOW READF * AND EXIT BL @PSTPG BL @CCREST LI R0,120 MOV R0,@POS B @CRTN * GFERR ERROR! AND RESTORE SCREEN AND HONK GFERR BL @HONK LI R0,920 LI R1,TER1 LI R2,40 BLWP @VMBW GFERS CLR @>837C CLR @>8375 LIMI 2 LIMI 0 BLWP @KSCAN MOVB @>837C,R0 JEQ GFERS GFEXIT BL @CCREST LI R0,120 MOV R0,@POS CLR @COUNTP B @CRTN *** * * OLD DSK.FILE * *** DSRL LI R0,533 LI R1,TLOAD LI R2,10 BLWP @VMBW B @DSRL *** * * VARIABLES AND BUFFERS *** * * SAVE FILE PAB INFORMATION DV 80 FORMAT * *** SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES PBAD EQU >79E * PAB ADDRESS FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 * OP DV 128 COUNTP BYTE 0 FLNM BSS 48 STATUS EQU >837C POINT EQU >8356 READP BYTE >02 WRITE BYTE >03 CLOSP BYTE >01 EVEN EOFP DATA 0 ERRM TEXT '* I/O ERROR * ' CPUBF BSS 80 LENP BSS 2 RETURN BSS 2 PADD TEXT ' ' TER1 TEXT '* INVALID DISK NUMBER * - PRESS ANY KEY ' SVMG TEXT 'SAVING FILE:' *** * * USED FOR TRACING, DEBUGGING * *** TRACE LI R0,0 LI R1,>2A00 BLWP @VSBW TRASP LIMI 2 LIMI 0 JMP TRASP DSR MOV R11,@SAVRTN LI R6,FSPAB+9 BLWP @DSRLNK DATA 8 JEQ DSRERP MOV @SAVRTN,R11 RT *R11 DSRERP INC @EOF LI R0,PBAD+1 BLWP @VSBR SRL R1,13 CI R1,5 JNE IOERP MOV @SAVRTN,R11 RT *R11 IOERP AI R1,>30 SLA R1,8 LI R0,288 LI R1,ERRM LI R2,14 BLWP @VMBW EOJP MOV @EOF,@EOF JNE NCLOSP MOVB @CLOSP,R1 LI R0,PBAD BLWP @VSBW BL @DSR NCLOSP DECT @RETURN MOV @RETURN,R11 RT *R11 GTBNK MOV R11,@SAVRTN MOV @BANK#,R1 LI R12,>1E00 SBO 0 * this sets my sAMS pages to the correct BANK# LI R3,>4006 MOV R1,*R3 SBZ 0 MOV @SAVRTN,R11 RT Edited October 30, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
Stuart Posted October 30, 2020 Share Posted October 30, 2020 Before *each and every* call to DSRLNK, you need to put a pointer to the PAB name length field in >8356 (MOV @PABADR9,@>8356 or similar). I can't see that you do this, and *may* be the cause of the error. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 30, 2020 Share Posted October 30, 2020 I'll hit it tomorrow with fresh eyes Thx sir! Quote Link to comment Share on other sites More sharing options...
apersson850 Posted October 30, 2020 Share Posted October 30, 2020 (edited) Just some hints. When you comment like this, it gives you very little information about the size of the different data items. * BYTE 1 /0=OPEN 1 = CLOSED * BYTE 2 FILE TYPE >12 =OUTPUT,VARIABLE DISPLAY * NEXT POSITION=BUFFER ADDRESS * NEXT RECORD LENGTH >50 = 80 BYTES * NEXT CHARACTER COUNT * NEXT RECORD NUMBER * NEXT CASSETTE OFFSET * LAST IS FILELENGTH DESCRIPTOR LENGTH * NOTE: FILE DESCRIPTOR LENGTH * FOR FILE: 'DSK1.FILE1' = 10 >0A TLOAD TEXT 'LOAD DSK ' Do it like this instead. * BYTE Opcode 0=OPEN 1 = CLOSED * BYTE FILE TYPE >12 =OUTPUT,VARIABLE DISPLAY * DATA BUFFER ADDRESS * BYTE RECORD LENGTH >50 = 80 BYTES * BYTE CHARACTER COUNT * DATA RECORD NUMBER * BYTE CASSETTE OFFSET * BYTE FILELENGTH DESCRIPTOR LENGTH * NOTE: FILE DESCRIPTOR LENGTH * FOR FILE: 'DSK1.FILE1' = 10 >0A TLOAD TEXT 'LOAD DSK ' Now you can see the structure of the PAB. Here is a code snippet. CLR @PAGE INC @PAGE * SET PAGE TO 1 LI R0,929 CLR R2 INC R2 * R2=1 LI R3,>3000 * "0 This is a better version LI R0,929 LI R2,1 MOV R2,@PAGE LI R3,'0 ' It's more compact and obvious enough to make the comments you had there redundant. Here too, use the character load for clarity BLWP @VSBR * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME IN R2 CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,>3900 * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,>2E00 * NOW ITS LEGAL, CONTINUE LOOKIN SG FOR "." PERIOD MARK INC R0 INC R2 * R2=2 BLWP @VSBR CB R1,R3 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R0 INC R2 * R2=3 LI R3,>4100 * LOOKING FOR A CHAR VALUE UPPER A-Z BLWP @VSBR CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,>5A00 * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,>2000 * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH INC R0 INC R2 BLWP @VSBR CB R1,R3 * FOUND END OF NAME YET?, NO, KEEP LOOKING JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,2 * WE ADD IN THE "DSK" 3 BYTES TO GET OUR FULL DESCRIP # MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR When you read incremental data from the VDP, there's no need to use the VSBR procedure. The VDPRD address is autoincrementing, so it will give you the next byte each time you access it. SWPB R0 * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME INTO R1 MOVB R0,@VDPWA * Set up the VDP address for reading SWPB R0 MOVB R0,@BDPWA NOP MOVB @VDPRD,R1 * Now you fetch consecutive characters by just reading the data, which is much faster than calling VSBR CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,'9 ' * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,'. ' * NOW ITS LEGAL, CONTINUE LOOKING FOR "." PERIOD MARK INC R2 * R2=2 CB @VDPRD,R3 * Here you only compare once, so you don't need to save the value in R1 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R2 * R2=3 LI R3,'A ' * LOOKING FOR A CHAR VALUE UPPER A-Z MOVB @VDPRD,R1 * Here you must save it in R1, since you want to compare it against two values CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,'Z ' * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,' ' * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH CB @VDPRD,R3 * Since you are using the value only once here, you can compare what you get from the VDP directly to your match value. No need to store it in R1 JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,3 * WE ADD IN THE "DSK" 3 BYTES TO GET OUR FULL DESCRIP # So you better add three, not two MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME Where is COUNT? The file name counter you have defined is called COUNTP. Since it's a byte, you can't move it like this either LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR This part is still wrong. First you define 10 bytes with PAB data. Then you have COUNTP (or should it be COUNT?) as the first byte after the PAB data fields. But it shouldn't be there, it should be the last byte in the PAB data field. The file name shall start at where COUNTP is now. The count should be at FSPAB+9, but now it's at FSPAB+10. FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 * OP DV 128 COUNTP BYTE 0 FLNM BSS 48 You can take advantage of the fact that you don't intend to offer cassette storage when you move the file name length to the PAB. That means that instead of doing something like SWPB R2 MOVB R2,@FSPAB+9 You can do this MOV R2,@FSPAB+8 This means that the byte before the count will get the value zero, but since it's used by the tape DSR only, that doesn't matter here. You still don't have to save R11 in routines where you don't destroy R11 inside the routine. Besides, when you don't use all workspace registers, it's more efficient to save R11 into a register, like R10. At the end, you can then just B *R10. RT is not an instruction. It's a macro, which translates to B *R11. You can use RT, but then it's only RT, not RT *R11. Edited October 30, 2020 by apersson850 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted October 30, 2020 Share Posted October 30, 2020 20 hours ago, GDMike said: regarding my 1000 bytes in my CRAM.. Ive got 40 col screens and they total 1000 bytes 24 lines with 40 characters each is 960 characters, not 1000. So it's something else. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 31, 2020 Share Posted October 31, 2020 (edited) 7 hours ago, apersson850 said: 24 lines with 40 characters each is 960 characters, not 1000. So it's something else. It's 840 bytes. I'm not saving 24*40 My editor starts at pos 120. Then I have some tag data in ram that gets added after my 840 bytes, this happens when a user hits pgup/down. And that brings it up to 1000 bytes. I also, DID forget, to add a counter for each of my 120 byte writes(1 record) to track the next 120 bytes written, making it record#2 and so on. I can fix that. And I'll have to adjust that COUNTP mistake you found, and the MOV R2,@FSPAB+8 Thank you. Edited October 31, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 31, 2020 Share Posted October 31, 2020 (edited) 8 hours ago, apersson850 said: LI R2,1 Without clearing my register first has gotten me into trouble before when I tried a CI against it, so I got into the habit of clearing it First. Edited October 31, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 1, 2020 Share Posted November 1, 2020 (edited) No, that does not get you into trouble. Unless you want to compare it to zero. For which you don't need to compare against anything special, since a MOV R2,R2 will compare the data in R2 against zero. Since a CI also always compare a register against a literal, clearing the register before you make a comparison is redundant, since you then already know the register is zero. You have made som other mistake that took you into that trouble, and then you fixed that by adding a kludge. Perhaps you did a MOVB into the register, then did the CI? And forgot about that the MOVB only changes half of the register, but CI always compare all of it? That's a special case where clearing the register before moving a byte into it and finally compare the whole register against something could make sense. But special cases should be kept special, not made any kind of general reason for complicating the code more than necessary. Anyway, if you want to make a register to contain 1 by using INC, then of course you must start from 0. So CLR R2 INC R2 will indeed load one into R2. But it's a tad less obvious than LI R2,1, which consumes the same amount of memory and executes a little faster. It's also general, i.e. works with any value. Once you do a LI, anything that was in the register before is overwritten. So a preceeding CLR is completely redundant in that case. The sequence CLR @SOMEPLACE INC @SOMEPLACE CLR R2 INC R2 is very inefficient and illogical compared to LI R2, 1 MOV R2,@SOMEPLACE If a certain constant, like 120, is frequently used in a piece of code, it may be useful to load it into a register, if you have one available. CON120 EQU 9 LI CON120,120 will give you a register (R9) with the value 120, and a name for it. Then you can use MOV CON120,R2 MOV CON120,@SOMEPLACE C *R2+,CON120 A CON120,R2 It's of course important that you don't mess that register up. Don't do A R2,CON120, since the result will end up in the second parameter, and R9 will then contain 120+what was in R2. As long as you keep that in mind, all these instructions are faster, and require less memory, than dealing with the immediate value (120) over and over again. Remember that programming is not just about getting it to work. It's also about making the program elegant. If it is, then it's easier to understand, which makes it easier for you to work with. Both now and at a later date, when you want to change something. It's also easier for everybody else here to help you. Besides, an elegant program usually executes faster and require less memory, simply because it doesn't contain so many unnecessary things. Edited November 1, 2020 by apersson850 1 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 Good news, I'm back on this DSRLNK code again. I'm trying to figure it out. I'll post all NEW code once I see what is happening here. Thx Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) ENTRY is DSRS I added in MY POINT(er) that was "pointed" out to me. But i just ended up rebooting instead of getting the error i was getting prior. i beleive, the FILENAME address is still incorrect. here is the latests code. ALL DATA,BYTE, TEXT, BSS..are defined- either here or in another file. NEW CODE COMING Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) **************************************** * FILEM - FILE MANAGAMENT 06/04/20 * * * * LAST UPDATE: 10/23/20 * * HIST:FIX ERRROR HONK TIMING * * NEED: SAVE PAB SETUP * * * **************************************** TLOAD TEXT 'LOAD DSK ' *** * * SAVE DSK FILE * *** GFERR1 B @GFERR DSRS LI R1,>1100 * SET TO PAGE 1 SAMS MOV R1,@BANK# CLR @PAGE INC @PAGE * SET PAGE TO 1 LI R0,929 CLR R2 INC R2 * R2=1 LI R3,>3000 * "0" BLWP @VSBR * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME IN R2 CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,>3900 * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,>2E00 * NOW ITS LEGAL, CONTINUE LOOKING FOR "." PERIOD MARK INC R0 INC R2 * R2=2 BLWP @VSBR CB R1,R3 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R0 INC R2 * R2=3 LI R3,>4100 * LOOKING FOR A CHAR VALUE UPPER A-Z BLWP @VSBR CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,>5A00 * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,>2000 * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH INC R0 INC R2 BLWP @VSBR CB R1,R3 * FOUND END OF NAME YET?, NO, KEEP LOOKING JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,2 * WE ADD IN THE "DSK" 3 BYTES TO GET OUR FULL DESCRIP # MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR * START PROCESSING... LI R0,120 LI R1,>2000 * CLEAR SCREEN AREA CSVA BLWP @VSBW INC R0 CI R0,960 JLT CSVA BL @BEEP LI R0,324 * MESSAGE "SAVING..." LI R1,SVMG LI R2,12 BLWP @VMBW LI R0,337 LI R1,FLNM MOV @COUNTP,R2 BLWP @VMBW * DO THE WRITE! LI R5,>1000 * THIS JUST SETS THE SAMS BASE BANK# CLR R3 LI R0,PBAD LI R1,FSPAB MOVB @COUNTP,R2 SRL R2,8 AI R2,10 BLWP @VMBW CLR R4 * RECORD COUNTER * THE FOLLOWING CODE JUST SETS UP THE PAGE TO PLACE INTO THE BUFFER AI R5,>0100 * SET BANK# MOV R5,@BANK# * INITIALLY >1100 INC R3 * R3=PAGE# 1-4 MOV R3,@PAGE INC R4 * IS A 1 THE FIRST TIME RFPB BL @GTBNK * GET THE BANK SET TO >1100 AND PAGE TO 1 (SNPS1) RFPC MOV @PAGE,R3 CI R3,1 JNE RFPD LI R3,S32P1 * THIS IS >3000 B @RFPRC RFPD CI R3,2 JNE RFPE LI R3,S32P2 * THIS IS >3349 B @RFPRC RFPE CI R3,3 JNE RFPF LI R3,S32P3 * THIS IS >3692 B @RFPRC RFPF LI R3,S32P4 * AND THIS IS >39DB * NOW WE HAVE THE PAGE AND DATA TO PLACE INTO THE BUFFER RFPRC MOV R3,R1 * CRAM DATA LI R0,SBUFF * VRAM BUFFER LI R2,1000 BLWP @VMBW LI R0,SBUFF1 LI R1,PADD * 28 SPACES LI R2,28 BLWP @VMBW * LOOP HERE BL @DSR MOVB @WRITE,R1 BLWP @VSBW CLR R4 * RECORD COUNTER WRITEF BL @DSR MOV @EOFP,@EOFP JNE EOJPP *** STOP STOP LIMI 2 LIMI 0 JMP STOP MOV @PAGE,R3 * AFTER DSR IS DONE INC R3 CI R3,4 JLE CJPB * HIGHER THAN PAGE 4, INC SAMS BANK SET PAGE TO 1 LI R3,1 MOV R1,@PAGE MOV @BANK#,R1 AI R1,>0100 MOV R1,@BANK# JMP RFPB CJPB MOV R3,@PAGE * CONTINUE MOVING JMP RFPC * READ SNPS 1-4 PAGES * SET BANK# BL @DSR MOVB @READ,R1 * SET TO OPEN! LI R0,PBAD BLWP @VSBW CLR R4 * RECORD COUNTER * NOT USED BELOW READF * AND EXIT BL @PSTPG BL @CCREST LI R0,120 MOV R0,@POS B @CRTN EOJPP B @EOJPP * GFERR ERROR! AND RESTORE SCREEN AND HONK GFERR BL @HONK LI R0,920 LI R1,TER1 LI R2,40 BLWP @VMBW GFERS CLR @>837C CLR @>8375 LIMI 2 LIMI 0 BLWP @KSCAN MOVB @>837C,R0 JEQ GFERS GFEXIT BL @CCREST LI R0,120 MOV R0,@POS CLR @COUNTP B @CRTN *** * * OLD DSK.FILE * *** DSRL LI R0,533 LI R1,TLOAD LI R2,10 BLWP @VMBW B @DSRL *** * * VARIABLES AND BUFFERS *** * * SAVE FILE PAB INFORMATION DV 80 FORMAT * *** SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES PBAD EQU >79E * PAB ADDRESS FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 * OP DV 128 COUNTP BYTE 0 FLNM BSS 48 STATUS EQU >837C POINT EQU >8356 READP BYTE >02 WRITE BYTE >03 CLOSP BYTE >01 EVEN EOFP DATA 0 ERRM TEXT '* I/O ERROR * ' CPUBF BSS 80 LENP BSS 2 RETURN BSS 2 PADD TEXT ' ' TER1 TEXT '* INVALID DISK NUMBER * - PRESS ANY KEY ' SVMG TEXT 'SAVING FILE:' *** * * USED FOR TRACING, DEBUGGING * *** TRACE LI R0,0 LI R1,>2A00 BLWP @VSBW TRASP LIMI 2 LIMI 0 JMP TRASP DSR MOV R11,@SAVRTN LI R6,FSPAB+9 MOV R6,@POINT BLWP @DSRLNK DATA 8 JEQ DSRERP MOV @SAVRTN,R11 RT *R11 DSRERP INC @EOF LI R0,PBAD+1 BLWP @VSBR SRL R1,13 CI R1,5 JNE IOERP MOV @SAVRTN,R11 RT *R11 IOERP AI R1,>30 SLA R1,8 LI R0,288 LI R1,ERRM LI R2,14 BLWP @VMBW EOJP MOV @EOF,@EOF JNE NCLOSP MOVB @CLOSP,R1 LI R0,PBAD BLWP @VSBW BL @DSR NCLOSP DECT @RETURN MOV @RETURN,R11 RT *R11 GTBNK MOV R11,@SAVRTN MOV @BANK#,R1 LI R12,>1E00 SBO 0 * EACH CONTAINING SNPS1-4 LI R3,>4006 MOV R1,*R3 SBZ 0 MOV @SAVRTN,R11 RT my problem so far, is this: i need to keep track of the 128 bytes per record counter. I thought I was doing this JUST PRIOR to the RFPB LABEL in R4. But not true, that is only tracking my PAGE for SAMS! im lost on how to track that, is it done at the DSR routine or ? Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) IM not sure, BUT the BL @DSR prior to the REM * LOOP HERE, might be out of place. removing it is ok, Im now in the area to where I MOVB @write to R1. then I clear my R4 record counter to prepare for the 128 bytes record #1, and call DSR routine. but Im getting a reboot. Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) I THINK at this point, im going to wipe this ALL out and start over. @BEERY sent me a piece of code, his SEARCH routine, that has an example of using DSRLNK. And Ill try to see how it works from that point of view. Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 1, 2020 Share Posted November 1, 2020 The DSRLNK only executes one I/O operation. Like writing one record. I've now understood that you seem to plan to store 120 bytes in each record. My previous comments were related to that when people use the internal fixed 128 format, it's usually due to a desire to use the entire sector on a floppy disk. The I/F 128 format allows two records in a sector, and that fills it completely. But you can very well use 120 bytes in a record. You'll waste a few bytes, but when it makes your program simpler, then that's no problem. However, if the code two posts up is what you're working on now, you still haven't done any of the fixes I showed you. Some of them are just to increase the quality of your coding, but the PAB is still not correctly defined, which is catastrophic. It also seems you haven't grasped the concept of records in a file. Here's a piece of pseudo code to show how to do file handing, storing a buffer that's larger than the record. const recordSize = 120; // How much you actually use in each record const screenSize = 1000; // How much you want to save screenIndex: interger; // Index into the current position in the screen recordNumber: integer; buffer = array[0..recordSize]; // The file handling buffer screen = array[0..screenSize]; // The screen with characters open(file); screenIndex := 0; // Start with the beginning of the screen recordNumber := 0; while screenindex<screenSize do // As long as you haven't reached the end of the screen begin move(screen[screenIndex],buffer,recordSize); // Move one chunk of data from the current position in the screen to the file buffer write(file(recordNumber),buffer); // Write the file buffer recordNumber := recordNumber+1; screenIndex := screenIndex+recordSize; // Move index to the start of the next record in the screen end; close(file); 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 1, 2020 Share Posted November 1, 2020 Well, if you are going to start over, which indeed may be a good idea, since your original code is pretty much a mess, then I suggest you plan your code on a pseudo code level. Like the one I suggest above, or anthing that's appropriate to you. It's easier to set a game plan that way, and only when you are certain it seems functional, do you enter into all the details that need to be correct to get an assembly program working. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) **************************************** * FILEM - FILE MANAGAMENT 06/04/20 * * * * LAST UPDATE: 11/01/20 * * * **************************************** *** * * SAVE DSK FILE * *** * the following ASKS the user to enter a filename to be used: EX: DSK2.FILE DSRS LI R1,>1100 * SET TO PAGE 1 SAMS MOV R1,@BANK# CLR @PAGE INC @PAGE * SET PAGE TO 1 LI R0,929 LI R2,>0001 LI R3,>3000 * "0" BLWP @VSBR * 1ST WE NEED TO GET THE LENGTH OF THE FILENAME IN R2 CB R1,R3 * ERROR! CANT BE "0 OR LESS" JLE GFERR1 * DISPLAY A MESSAGE LI R3,>3900 * IT HAS TO BE A NUMBER CB R1,R3 JGT GFERR1 * ERROR, NOT 1-9 LI R3,>2E00 * NOW ITS LEGAL, CONTINUE LOOKING FOR "." PERIOD MARK INC R0 INC R2 * R2=2 BLWP @VSBR CB R1,R3 JNE GFERR1 * NOT VALID! ERROR GOTTA HAVE "." INC R0 INC R2 * R2=3 LI R3,>4100 * LOOKING FOR A CHAR VALUE UPPER A-Z BLWP @VSBR CB R1,R3 JLT GFERR1 * NOPE NOT A-Z, ERROR- WAS LESS THAN "A" LI R3,>5A00 * CHECK FOR GREATER THAN "Z" CB R1,R3 JGT GFERR1 * NOPE, NOT A-Z, WAS GREATER THAN "Z" LI R3,>2000 * CHECK FOR SPACE TO GET TOTAL COUNT KLNMH INC R0 INC R2 BLWP @VSBR CB R1,R3 * FOUND END OF NAME YET?, NO, KEEP LOOKING JNE KLNMH * KEEP LOOKING FOR NAME HERE AI R2,2 * WE ADD IN THE "DSK" 3 BYTES TO GET OUR FULL DESCRIP # MOV R2,@COUNT * SAVE THE LENGTH OF FILENAME LI R0,926 LI R1,FLNM * FILENAME BUFFER BLWP @VMBR * FLNM contains the PATH * COUNT contains the length of the PATH LI R0,120 LI R1,>2000 * CLEAR SCREEN AREA CSVA BLWP @VSBW INC R0 CI R0,960 JLT CSVA BL @BEEP LI R0,324 * MESSAGE "SAVING..." LI R1,SVMG LI R2,12 BLWP @VMBW LI R0,337 LI R1,FLNM MOV @COUNTP,R2 BLWP @VMBW * DO THE WRITE: here is where we need to SET WRITE operation for DF 128 * i got nothing... BUT im looking at * @BEERY's SEARCH routine. MAYBE itll give me * SOME insight on how to setup the * structure. THANKS MR. BEERY! * *** SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES PBAD EQU >79E * PAB ADDRESS FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 * OP DV 128 COUNTP BYTE 0 FLNM BSS 48 STATUS EQU >837C POINT EQU >8356 READP BYTE >02 WRITE BYTE >03 CLOSP BYTE >01 EVEN EOFP DATA 0 ERRM TEXT '* I/O ERROR * ' CPUBF BSS 80 LENP BSS 2 RETURN BSS 2 PADD TEXT ' ' TLOAD TEXT 'LOAD DSK ' TER1 TEXT '* INVALID DISK NUMBER * - PRESS ANY KEY ' SVMG TEXT 'SAVING FILE:' *** * * USED FOR TRACING, DEBUGGING * *** TRACE LI R0,0 LI R1,>2A00 BLWP @VSBW TRASP LIMI 2 LIMI 0 JMP TRASP here is my starting point Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) 20 minutes ago, apersson850 said: screenIndex: interger; // Index into the current position in the screen yeah, im not using screens...but I can look at how to adjust this to memory. thank you!! Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 1, 2020 Share Posted November 1, 2020 (edited) Then begin by fixing the PAB structure, as I outlined it for you. Then you get that right. The above one doesn't work. Whatever data structure you use to represent the data on the screen is what I meant by "screen". Edited November 1, 2020 by apersson850 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) 11 minutes ago, GDMike said: PBAD EQU >79E * PAB ADDRESS FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 are we talking about this? ahh, maybe you didnt notice, i erased most of everything so i can start over. Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) ill look at @BEERYS code. Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 (edited) 2 hours ago, GDMike said: PAB ADDRESS FSPAB DATA >0012,SBUFF,>8000,>0000,>0000 Yup >0002,SBUFF.... should be. Edited November 1, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 1, 2020 Share Posted November 1, 2020 I also corrected, not shown in code, where I'm clearing R1 and incrementing it at the next instruction. Fixed I just forgot to adjust it.. Quote Link to comment Share on other sites More sharing options...
