+jedimatt42 Posted June 4, 2017 Share Posted June 4, 2017 My continuity tester won't operate a diode. But the resistence (non-beeping) mode will. However I have to be careful not to bridge the diode with my fleshy conductive self or it will read misleading results. I designed the pcboard you show from the top diagram. I never thought much about it. I just trusted it. OUT and IN in the middle diagram are subjective.. more or less from a programming point of view, than an electrical current point of view. When I look at this diagram: ( from: http://www.unige.ch/medecine/nouspikel/ti99/keyboard.htm) The way I read this, the connections to the 9901 for up/down/left/right and fire are all held at +5v will pull-ups. The diode in the joystick allows the current from those pull-ups to sink to LOW at the 9901 input pins when you complete the switch AND the player is selected ( the 1Y2 or 1Y3 on the 74LS156 go LOW when the respective joystick is scanned ) -M@ 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted June 4, 2017 Author Share Posted June 4, 2017 So here are the final few photos. The rats nest was the first joypad I tried to mod that I goofed on - will fix at another time.The cleaner JoyPad attempt #2 is at the bottom. New 3 Quote Link to comment Share on other sites More sharing options...
