+KylJoy Posted June 20, 2017 Share Posted June 20, 2017 Hi, I am trying to get the IntelliVoice to work in my MAME configuration. I have an archive named "intv_voice.zip" that contains "sp0256-012.bin" in my "intv" directory along with the "intv.zip" archive. All non-voice games work as expected but I can't get voice produced from any voice enabled game even if the game will run. Any help greatly appreciated. Here is my folder structure: MAME ROMS intv intv.zip intv_voice.zip game roms here too... Thanks! Quote Link to comment Share on other sites More sharing options...
mr_me Posted June 20, 2017 Share Posted June 20, 2017 Are you using the "intv" system or the "intvoice" system? The "intv" system doesn't have intellivoice. Try moving the intv.zip and intv_voice.zip files into the "roms" folder. Unless you added "intv" to your search paths, mame will search an "intv" container as a folder or zip but not both (I think). If that doesn't work try renaming intv_voice.zip to intvoice.zip. What edition and version of mame are you using? Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted June 30, 2017 Author Share Posted June 30, 2017 I got it figured out. Actually, I was trying to use the MAME core in Retroarch to do this and that doesn't work right now but everything DOES work fine in plain old MAME. Thanks! Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 1, 2017 Share Posted July 1, 2017 I had looked at Retroarch for Intellivision. I was hoping it could be a solution for 2-player internet play. I found it had two problems. The libretro mame and mess cores in retroarch are not recommended for internet play. And the control seems to only support upto 8 directions. Most 2-player intellivision games use 16 directions. I found that MameHub actually works very well for 2-player internet play. Except it has a bug with analog controllers and the intellivision emulation uses analog control for 16 directions. Its a fixable bug but it doesn't look like its getting fixed anytime soon. Its okay if you want to play Biplanes. Quote Link to comment Share on other sites More sharing options...
