ZackAttack Posted December 10, 2017 Share Posted December 10, 2017 You could always pad the Sprite to make it 32 high. Of course that will waste space. Quote Link to comment Share on other sites More sharing options...
JeremiahK Posted December 10, 2017 Share Posted December 10, 2017 (edited) True. If you could find a way to fill the wasted space with other data, that would help. Are you aware that Stella can be made to show your labels and variables in the debugger using .lst and .sym files? This is how I execute DASM: dasm filename.asm -v5 -f3 -sfilename.sym -lfilename.lst -ofilename.bin The list and symbol files tell Stella extra information about the code, like labels. Sometimes it confuses constants with RAM, though, which can be confusing. Edited December 10, 2017 by JeremiahK Quote Link to comment Share on other sites More sharing options...
vidak Posted December 10, 2017 Author Share Posted December 10, 2017 I have managed to get the Che character to animate properly while he is moving up and down. This is how I solved the problem. The order of operations in the AnimationDelay subroutine used to be this: AnimationDelay: inc AnimFrameCounter lda AnimFrameCounter cmp #9 bcs .ResFrmCntr bcc .IncFrameNo beq .IncFrameYes ... rts Now BCS actually branches if A is GREATER THAN OR EQUAL TO the value in memory. This was causing the local frame counter to constantly be set to zero over and over again. I think THIS is the proper order in which you should test if a number is equal to a certain number, or if it has gotten too high for the loop: beq .IncFrameYes bcc .IncFrameNo bcs .ResFrmCntr Changing the order of testing to this caused the animation sequence for Che moving up and down the screen to work. guerrilla8_6.bin coloured_guerrilla009.asm Quote Link to comment Share on other sites More sharing options...
vidak Posted December 10, 2017 Author Share Posted December 10, 2017 Are you aware that Stella can be made to show your labels and variables in the debugger using .lst and .sym files? This is how I execute DASM: dasm filename.asm -v5 -f3 -sfilename.sym -lfilename.lst -ofilename.bin The list and symbol files tell Stella extra information about the code, like labels. Sometimes it confuses constants with RAM, though, which can be confusing. I DID NOT KNOW THAT. WOW!!!! I know that may be an over-reaction but that actually makes my life so much easier!! 2 Quote Link to comment Share on other sites More sharing options...
vidak Posted December 10, 2017 Author Share Posted December 10, 2017 Okay. I've completely solved the issue. Che will now animate and walk around the screen (a) with the proper limits; (b) at a delay of 10 screen frames per animation frame. Please find the source code, symbol files, and binary attached. This was the problem: AnimateHorizontalYes: inc AnimateHor0 AnimateHorizontalNo: lda AnimateHor0 and #2 sta AnimateHor0 sta Animation0 jmp SaveFrame The AND operation is a bitmask operation. It will only let this value through: %00000010. Because we are counting up from 0 to 2, it masks and returns a value of 0 every time. So we are never allowed to count up to 2. This means Che will never animate horizontally. This is what I replaced the code with: AnimateHorizontalYes: inc AnimateHor0 AnimateHorizontalNo: lda AnimateHor0 cmp #2 beq .CntHorCntr bcc .CntHorCntr bcs .ResHorCntr .ResHorCntr lda #0 .CntHorCntr sta AnimateHor0 sta Animation0 jmp SaveFrame It's slower, and more ugly, but it works. Now my goal of getting Che to walk around the screen has been completed. This marks the end of the first phase of the development of this game. There may be 20 or 50 phases of development, but this is a huge step for me. One thing I need to do right now is fix the colours on the graphics to make sure they all match. coloured_guerrilla010.asm guerrilla10.bin guerrilla10.lst guerrilla10.sym.zip Quote Link to comment Share on other sites More sharing options...
JeremiahK Posted December 10, 2017 Share Posted December 10, 2017 Is that bcs command neccesary? It branches to the very next instruction. Quote Link to comment Share on other sites More sharing options...
vidak Posted December 10, 2017 Author Share Posted December 10, 2017 oh you're totally right! that'll totally increase the parsimony of the programming Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 10, 2017 Share Posted December 10, 2017 he hops quite nicely Quote Link to comment Share on other sites More sharing options...
+stephena Posted December 10, 2017 Share Posted December 10, 2017 I DID NOT KNOW THAT. WOW!!!! I know that may be an over-reaction but that actually makes my life so much easier!! In the future, we hope to extend this in Stella, and when debugging a ROM that was generated by DASM, have it display all info generated by DASM. This is then very close to eventual the end goal: source-level debugging. 1 Quote Link to comment Share on other sites More sharing options...
vidak Posted December 14, 2017 Author Share Posted December 14, 2017 I am moving onto the next phase of the development of the game. This phase of the development is writing a kernel which will draw multiple bands of GRP1 down the screen. Find inline below the code for one of the 5 kernels of the overall screen. I am using an approach to SpiceWare's Stay Frosty, except I am not using a mask to blank out the Player0 character on the lines it is not supposed to appear. I am using FlipDraw to prevent myself from having to juggle between two scanline counters. This way I can set the Y offset for GRP0, and it will draw somewhere throughout the 5 kernels as the kernels go about drawing the screen. Also, because the Y offsets for all the different GRP1 graphics are "local" (relative to the number of scanlines within their respective kernel), I do not need to adjust them relative to a global scanline counter. FlipDraw is the slowest method of drawing graphics down the screen, but for the fact that it does not need a scanline counter, which is what was pushing me over 76 cycles while I was using DoDraw. I will have to readjust how all the pointers are set, but I am lead to believe FlipDraw allows for much easier setting of pointers. Let me know if something doesn't seem right. ;--------------------------------- ; ; SECTION 4 KERNEL ; ;--------------------------------- ;================================= ; ; Preload GRP0 (Che) Graphics ; ;================================= Kernel4: lda #P0_HEIGHT ; 2 18 dcp Player0Offset ; 5 23 bcc .p0FlipPre ; 2 25 (3 26) ldy Player0Offset ; 2 27 lda (Player0Ptr),y ; 5 32 sta CheGfxTemp ; 3 35 lda (Player0Clr),y ; 5 40 sta COLUP0 ; 3 43 (27) .p0FlipPre ;(3 26) ;( 43) - Longest way ; We will not be showing Player1 on the first line of the section. lda #0 sta EnvGfxTemp ldx Heights+4 dex ;================================= ; ; Start of the actual kernel ; ;================================= .KernelLoop4 sta WSYNC ; 3 72 ;------------------------------------------------------------------ ;================================= ; ; Draw Che Graphics in time for left-most ; side of the screen. ; ;================================= lda CheGfxTemp ; 3 3 sta GRP0 ; 3 6 lda EnvGfxTemp ; 3 9 sta GRP1 ; 3 12 ;================================= ; ; Calculate Environment Graphics ; ;================================= lda EnvHeight4 ; 3 15 dcp EnvGfxOffset4 ; 5 20 bcc .p1FlipDraw ; 2 22 (3 23) ldy EnvGfxOffset4 ; 2 24 lda (EnvGfxPtr4),y ; 5 29 sta EnvGfxTemp ; 3 32 lda (EnvClrPtr4),y ; 5 37 sta COLUP1 ; 3 40 (28) .p1FlipDraw ;(3 23) ;( 40) - Longest way ;================================= ; ; Calculate Che Graphics ; ;================================= lda #P0_HEIGHT ; 2 42 dcp Player0Offset ; 5 47 bcc .p0FlipDraw ; 2 49 (3 50) ldy Player0Offset ; 2 51 lda (Player0Ptr),y ; 5 56 sta CheGfxTemp ; 3 59 lda (Player0Clr),y ; 5 64 sta COLUP0 ; 3 67 (27) .p0FlipDraw ;(3 50) ;( 67) - Longest way ;================================= ; Even though we're using FlipDraw, ; we still need a scanline counter ; to keep track of which section ; we're in. ;================================= dex ; 2 69 bne .KernelLoop4 ; 2 71 (3 72) coloured_guerrilla014.asm Quote Link to comment Share on other sites More sharing options...
vidak Posted December 19, 2017 Author Share Posted December 19, 2017 (edited) I think I am moving into the final version of the kernel of the first part of the game! Please find the inline code for my current MACRO for a single band of the screen. This kernel allows each GRP1 to be independently positioned within each band of the screen. This will allow me to animate some of the GRP1s within their respective bands on the screen. I will have Cuban peasants, and Batista soldiers. I will also have non-animated graphics such as trees. The GRP1 graphics will have to be 3 scanlines shorter than the height of the band of the screen, due to timing constraints caused by the need to strobe HMOVEat the beginning of the first scanline. I am using Manuel Rotchkar's FlipDraw for this kernel, because it means I don't have to use a scanline counter for the graphics Y offset when I don't want to. FlipDraw is the slowest method for drawing graphics on any individual scanline, but it completely removes the need to juggle line counters, which makes it faster overall when you compare it to other drawing methods WITH line counters. I have counted the LDY instructions in the FlipDraw as 2 cycles, when they are in fact 3. I think I'm still within the goal posts, though - I'll fix up that counting issue later. (Actually I've just looked over this, there are a lot of counting issues... Could I fit the calculation for line 2 of GRP0's graphics in after HMP1?) Anyway it is my hope that this macro will enable me to draw as many as FIVE bands of multicoloured GRP1s down the screen. I am about to develop a 2LK for the "Lock and Load" part of the game, the second part, which will feature: 2 coloured sprites 1 missile a coloured asymmetrical playfield *** If someone would like to look over my work, I'd be very grateful. *** ;--------------------------------- ; ; KERNEL MACRO ; ;--------------------------------- MAC SCREEN_BANDS .BAND SET {1} ;================================= ; ; Preload GRP0 (Che) Graphics ; ;================================= lda #P0_HEIGHT ; 2 dcp Player0Offset ; 5 bcc .p0FlipPre0 ; 2 (3) ldy Player0Offset ; 2 lda (Player0Ptr),y ; 5 tax ; 3 lda (Player0Clr),y ; 5 tay ; 3 (27) .p0FlipPre0 ;(3 XX) ;( XX) - Longest way ;================================= ; Position GRP1 independently for ; each band of the screen. ; ; Accumulator holds X value. ;================================= .PositionGRP1 lda EnvObjectX+.BAND sec sta WSYNC ;----------------------------------------------------- ENTER FIRST SCANLINE stx GRP0 ; 3 3 sty COLUP0 ; 3 6 DivideLoop1 sbc #15 ; 2 8 bcs DivideLoop1 ; 2 10 eor #7 ; 2 12 asl ; 2 14 asl ; 2 16 asl ; 2 18 asl ; 2 20 sta RESP1 ; 2 23 <- set object position sta HMP1 ; 3 26 ; Could I fit the below second scanline precalculation here? sta WSYNC ;------------------------------------------------------ ENTER SECOND SCANLINE sta HMOVE ; 3 3 ;================================= ; We haven't had time to preload ; any graphics, so now we have to ; rush and try and make sure we have ; something to draw on this line ;================================= lda #P0_HEIGHT ; 2 5 dcp Player0Offset ; 5 10 bcc .p0FlipPre1 ; 2 12 (3 10) ldy Player0Offset ; 3 15 lda (Player0Ptr),y ; 5 20 sta GRP0 ; 3 23 lda (Player0Clr),y ; 5 28 sta COLUP0 ; 3 31 (28) <-- delayed. So we'll have to restrict ; Che's movement on the left of the ; screen? .p0FlipPre1 ;(3 10) ; (35) ;================================= ; Preload Che Graphics for THIRD ; scanline. ;================================= lda #P0_HEIGHT ; 2 37 dcp Player0Offset ; 5 42 bcc .p0FlipPre2 ; 2 44 (3 45) ldy Player0Offset ; 3 47 lda (Player0Ptr),y ; 5 52 sta CheGfxTemp ; 3 55 lda (Player0Clr),y ; 5 60 sta COLUP0 ; 3 63 (27) .p0FlipPre2 ;(3 45) ;( 63) - Longest way ; Load the scanline counter ldx Heights+.BAND ; 3 66 - This variable equals the band height - 2 ; Prime the NUSIZ1 register with the right copies/sizing data lda EnvCopies+.BAND ; 3 69 sta NUSIZ1 ; 3 72 ;================================= ; ; Start of the actual kernel ; ;================================= .KernelLoop sta WSYNC ; 3 75 ;----------------------------------------------------- ENTER THIRD SCANLINE ;================================= ; ; Draw Che Graphics in time for left-most ; side of the screen. ; ;================================= lda CheGfxTemp ; 3 3 sta GRP0 ; 3 6 lda EnvGfxTemp ; 3 9 sta GRP1 ; 3 12 ;================================= ; ; Decrement line counter, and ; branch out if we're at zero. ; ; Even though we're using FlipDraw, ; we still need a scanline counter ; to keep track of which section ; we're in. ; ;================================= dex ; 2 14 beq .EndKernel ; 2 16 (3 17) ;================================= ; ; Calculate Environment Graphics ; ;================================= lda EnvHeight+.BAND ; 3 19 dcp EnvGfxOffset+.BAND ; 5 24 bcc .p1FlipDraw ; 2 26 (3 27) ldy EnvGfxOffset+.BAND ; 2 28 lda (EnvGfxPtr+.BAND*2),y ; 5 33 sta EnvGfxTemp ; 3 36 lda (EnvClrPtr+.BAND*2),y ; 5 41 sta COLUP1 ; 3 44 (28) .p1FlipDraw ;(3 27) ;( 44) - Longest way ;================================= ; ; Calculate Che Graphics ; ;================================= lda #P0_HEIGHT ; 2 46 dcp Player0Offset ; 5 51 bcc .p0FlipDraw ; 2 53 (3 54) ldy Player0Offset ; 2 55 lda (Player0Ptr),y ; 5 60 sta CheGfxTemp ; 3 63 lda (Player0Clr),y ; 5 68 sta COLUP0 ; 3 71 (27) .p0FlipDraw ;(3 54) ;( 71) - Longest way ;================================= ; ; We branch out of the kernel at the ; beginning of the last scanline AT ; THE TOP. So if we are allowed to ; reach this part of the kernel, ; we unconditionally jump back to the ; top! ; ;================================= jmp .KernelLoop ; 3 74 ;================================= ; END OF THE KERNEL. ; Here we "fall into" the next band ; of the screen! ;================================= .EndKernel ; (3 17) ENDM coloured_guerrilla015.asm Edited December 19, 2017 by vidak Quote Link to comment Share on other sites More sharing options...
vidak Posted December 19, 2017 Author Share Posted December 19, 2017 Here is the updated kernel with the proper timing. The guts of the kernel are now so finely timed, I would need to completely rewrite it if I wanted to put something else in. the unconditional jump back to the top of the kernel now finishes exactly as a new scanline starts. coloured_guerrilla016.asm Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted December 19, 2017 Share Posted December 19, 2017 I wasn't able to build 016.asm: guerrilla.asm (508): error: Value in 'cpy #PF_HEIGHT*2+2' must be <$100. --- Unresolved Symbol ListEnvGfxOffset 0000 ???? (R )--- 1 Unresolved Symbol Quote Link to comment Share on other sites More sharing options...
JeremiahK Posted December 19, 2017 Share Posted December 19, 2017 (edited) I had the same issue. Since PF_HEIGHT is 192, PF_HEIGHT*2+2 = 386, which doesn't fit into 8 bits. I think line 508 needs to be changed: cpy #PF_HEIGHT*2+2 ; Test for bottom of screen ...to this: cpy #PF_HEIGHT ; Test for bottom of screen Unless there was a reason for performing the PF_HEIGHT*2+2. Line 528 needs to be changed, as well. Also, "EnvGfxOffset" is never defined, though "EnvGfxOffset0" through "EnvGfxOffset4" are defined. One thing you could do is define the first one as both "EnvGfxOffset" and "EnvGfxOffset0". Edited December 19, 2017 by JeremiahK Quote Link to comment Share on other sites More sharing options...
vidak Posted December 20, 2017 Author Share Posted December 20, 2017 Oh! Thanks for noticing that. The code was never in a buildable state!I'm going to try and get it to a buildable state today...Anyway thanks so much for taking a look in any case! Quote Link to comment Share on other sites More sharing options...
vidak Posted December 20, 2017 Author Share Posted December 20, 2017 Okay! I have prepared something which compiles. This version 18 does not draw 262 scanlines. It draws between 192 exactly and 197-198. I think it may have something to do with the offset of the pointers and the heights of the different sections of the bands of the kernel. Take a look if you feel like it, or don't! This source file definitely compiles, I just don't have enough effort today to completely debug it. I suppose I like to be really verbose on this thread to show I am working through the different problems as they crop up. *** Any debugging would be very appreciated. coloured_guerrilla018.asm Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted December 20, 2017 Share Posted December 20, 2017 (edited) Okay! I have prepared something which compiles. This version 18 does not draw 262 scanlines. It draws between 192 exactly and 197-198. I think it may have something to do with the offset of the pointers and the heights of the different sections of the bands of the kernel. Take a look if you feel like it, or don't! This source file definitely compiles, I just don't have enough effort today to completely debug it. I suppose I like to be really verbose on this thread to show I am working through the different problems as they crop up. *** Any debugging would be very appreciated. hI vidak!! i'm using stella 3.5 and when running this program i just get a black screen, could be something related to my emulator? cheers Edited December 20, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted December 20, 2017 Share Posted December 20, 2017 hI vidak!! i'm using stella 3.5 and when running this program i just get a black screen, could be something related to my emulator? Stella 3.5 is ancient. Please upgrade to Stella 5.0.2. Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted December 20, 2017 Share Posted December 20, 2017 (edited) Stella 3.5 is ancient. Please upgrade to Stella 5.0.2. will try this bin at work, must upgrade my desktop pc at home. ty DirtyHairy. Edited December 20, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted December 20, 2017 Share Posted December 20, 2017 will try this bin at work, must upgrade my desktop pc at home. If you have a recent browser, you can also use Stellerator (see my signature). However, mind that Vidak posted assembly source; you'll have to assemble it with DASM before you can run It with any emulator. 1 Quote Link to comment Share on other sites More sharing options...
vidak Posted December 20, 2017 Author Share Posted December 20, 2017 I think it might have something to do with the fact this version is drawing WELL under the proper 262 scan line limit. I'm glad it seemed to compile okay for you! I will step through everything in the Stella debugger tomorrow. I recommend you get Stella 5! 1 Quote Link to comment Share on other sites More sharing options...
vidak Posted December 21, 2017 Author Share Posted December 21, 2017 Okay!I figured out why I was not drawing enough lines. I was counting the cycles in the kernel for when both GRP1 and GRP0 were being drawn. When both are drawn on a scanline, the cycles add up to 76. When neither are drawn, the unconditional JMP back up to the top of the kernel was returning at cycle 40-46, which is waaaay too early. So I economised some code and forced a WSYNC at the start of each line. Now we're drawing 263 lines - much better. There are still problems: GRP0 doesn't move properly vertically OR horizontally. Every band of the screen GRP0 moves vertically it seems to shear left when moving up, and shear right when moving down. When moving horizontally, GRP0 seems to be "glued" between horizontal bands on the screen, and oscillates between them. My best guess as to why this is happening is that the HMOVE for GRP1 seems to be interfering with the HMOVE for GRP0. There are strange artifacts for GRP0 occuring on every band of the screen. *** If anyone would like to help debug, I would be very grateful! I like to post the work I finish at the end of the day here just anyone feels like they want to help out : ) guerrilla19 binary, lst and sym.zip coloured_guerrilla019.asm Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 21, 2017 Share Posted December 21, 2017 My best guess as to why this is happening is that the HMOVE for GRP1 seems to be interfering with the HMOVE for GRP0From Stella Programmers Guide: 8.0 Horizontal Motion Horizontal motion allows the programmer to move any of the 5 graphics objects relative to their current horizontal position. Each object has a 4 bit horizontal motion register (HMP0, HMP1, HMM0, HMM1, HMBL) that can be loaded with a value in the range of +7 to -8 (negative values are expressed in twos complement from). This motion is not executed until the HMOVE register is written to, at which time all motion registers move their respective objects. Objects can be moved repeatedly by simply executing HMOVE. Any object that is not to move must have a 0 in its motion register. With the horizontal positioning command confined to positioning objects at 15 color clock intervals, the motion registers fills in the gaps by moving objects +7 to -8 color clocks. Objects can not be placed at any color clock position across the screen. All 5 motion registers can be set to zero simultaneously by writing to the horizontal motion clear register (HMCLR). There are timing constraints for the HMOVE command. The HMOVE command must immediately follow a WSYNC (Wait for SYNC) to insure the HMOVE operation occurs during horizontal blanking. This is to allow sufficient time for the motion registers to do their thing before the electron beam starts drawing the next scan line. Also, for mysterious internal hardware considerations, the motion registers should not be modified for at least 24 machine cycles after an HMOVE command. Quote Link to comment Share on other sites More sharing options...
vidak Posted December 21, 2017 Author Share Posted December 21, 2017 Hmm... then the bizarre oscillating that GRP0 is displaying must be because the horizontal movement register for GRP0 is not zero when I set the HMOVE for GRP1. That sounds like that would fix that problem. I will have to do some thinking about this. I do a HMOVE for GRP1 every band, but a HMOVE for GRP0 every FRAME. I suppose I better look at your Stay Frosty a bit more... Quote Link to comment Share on other sites More sharing options...
vidak Posted December 21, 2017 Author Share Posted December 21, 2017 Oh!!! I could just write HMCLR before I position GRP1!! Quote Link to comment Share on other sites More sharing options...
