+Larry Posted December 12, 2017 Share Posted December 12, 2017 Does anyone remember this program? It is just one of many BASIC programs to check your drive speed. But it has an Error 164 (file number mismatch) on my disk, and I thought that someone might remember it and could provide a copy. I think it is about 12 sectors long, and definitely BASIC. Please don't do a deep dive to hunt for it. I have backup copies of the disk, but they all have the same file system error. I just thought that someone might be able to put their finger on it easily. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 12, 2017 Share Posted December 12, 2017 (edited) 100 FOR I=0 TO 72:READ A 110 POKE 1536+I,A:NEXT I 120 PRINT CHR$(125) 130 PRINT "DRIVE #";:INPUT DRIVE 140 POKE 1610,DRIVE 150 X=USR(1536) 160 A=PEEK(1611):B=PEEK(1612) 170 MINUTES=(256*B+A)/3000 180 RPM=INT(100/MINUTES+0.5) 190 ? :? "RPM'S= ";RPM 200 END 1000 DATA 104,169,1,141,10,3,169,0 1010 DATA 141,11,3,141,4,3,169,5 1020 DATA 141,5,3,173,74,6,141,1 1030 DATA 3,169,82,141,2,3,169,5 1040 DATA 141,73,6,32,83,228,206,73 1050 DATA 6,208,248,169,100,141,73,6 1060 DATA 169,0,133,19,133,20,32,83 1070 DATA 228,206,73,6,208,248,165,20 1080 DATA 164,19,141,75,6,140,76,6,96 This is the only disk RPM checker I could find in basic .... Never used it I prefer the Binary RPM. Edited December 12, 2017 by rdea6 1 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted December 12, 2017 Share Posted December 12, 2017 Would this be APX 20010 Disk Fixer (FIX)? The disk I have also is missing data on Sector 700... Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted December 12, 2017 Share Posted December 12, 2017 DISK-041-B.ATR You'll have to fix line 450, but it now runs... 3 Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 13, 2017 Author Share Posted December 13, 2017 Thanks! Outstanding -- that is the program. Did you have an uncorrupted copy or somehow fix the error? AFAIK, I've never been able to fix a 164 error on a BASIC program. -Larry Quote Link to comment Share on other sites More sharing options...
Madi Posted December 13, 2017 Share Posted December 13, 2017 Attached is an RPM test file in .LST format. It was part of the Book with Software ( I lost the the disk) I found it quite useful in the back days. madi rpmtest.lst 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 13, 2017 Author Share Posted December 13, 2017 Thanks to Roy and Madi. I'll add those to the RPM testers in my utility collection! The first one of these I think that I ever used was from Analog -- SNAIL.BAS? Probably around 1983. I hadn't had my 810 too long when it was published. -Larry Quote Link to comment Share on other sites More sharing options...
1050 Posted December 13, 2017 Share Posted December 13, 2017 AFAIK, I've never been able to fix a 164 error on a BASIC program. Can you post one of your corrupted ones Larry? That shouldn't really be possible unless someone was using a MyDOS ED disk and then slapped DOS 2.0 on it somehow. Or they added a file, or 'undeleted' one with a sector editor, or ... Just curious what the issue might be and the fixed disk is useless for that. If this is a common issue for you, I might find a cure? I didn't see anything wrong with line 450 myself, just me being me? SNAIL.BAS was my favorite, cute little snail too. Doesn't work very well on a Happy though 10,000 RPM is just not possible. I might be exaggerating an itsy little bit there. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted December 13, 2017 Share Posted December 13, 2017 Thanks! Outstanding -- that is the program. Did you have an uncorrupted copy or somehow fix the error? AFAIK, I've never been able to fix a 164 error on a BASIC program. -Larry The Disk I posted originally had the last sector of the file filled with $1A's and $00 filling the Sector Link Bytes and prevented the file from loading. I fixed the Sector Link Bytes, then viewed the file in ATR Tools and then saved it as an ATASCII file. Then Created a new Dos 2 Image and copied the Saved File to this image. Booted this new image and Entered in Basic, I then added lines 450 and 460 and re-saved in Basic to the posted ATR image 3 Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 13, 2017 Author Share Posted December 13, 2017 The last sector of the Basic file on my disk is missing -- all zeros. When loading, the file system thinks that instead of Speed file, that the last sector belongs to file #0, which creates the mismatch error 164. It is a Dos 2.0s disk. I have no idea what happened to that missing sector. I'm pretty sure that at one time, the file was intact. -Larry Speed-Error164.atr 1 Quote Link to comment Share on other sites More sharing options...
