Shawn Posted February 2, 2018 Share Posted February 2, 2018 Hey all, I'm looking for a push button option that acts like an on-on switch but I have no idea what the proper name of such a thing would be. All the ones I'm finding are 3 stage with on - off - on when what I need is a 2 stage on - on. What I'm after is something like a rocker switch that is controlled via a push button. Anyone able to follow my non-sense? Shawn Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 2, 2018 Share Posted February 2, 2018 (edited) An on-on switch I cannot comprehend? I know what you are trying to say actually I do believe. You are looking for a SPDT(single pole double throw) non momentary switch. Search that you will probably find what you are looking for. EDIT: This is what you mean right? Here is a pic of an actual switch Which can be found here https://vetco.net/products/spdt-bat-handle-toggle-switch-on-on-10a And as you can see on the page you had the correct name for it, ON-ON or SPDT works. Edited February 2, 2018 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted February 2, 2018 Share Posted February 2, 2018 No, he wants a push button toggle switch. 1 Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted February 2, 2018 Share Posted February 2, 2018 Hey all, I'm looking for a push button option that acts like an on-on switch but I have no idea what the proper name of such a thing would be. All the ones I'm finding are 3 stage with on - off - on when what I need is a 2 stage on - on. What I'm after is something like a rocker switch that is controlled via a push button. Anyone able to follow my non-sense? Shawn I get the impression you need a controller for games such as track and Field and the Epyx Summer and Winter games; The tap back and forth to gain runner speed? There is the dedicated track Field controller with two buttons, but I found something at the swap meet that really works out well. The switches are independent, but a "rocking" controller perfect for the running games. http://www.racketboy.com/forum/viewtopic.php?p=411999#p411999 Panasonic RP-2692 Footpedal At first I thought the this was a foot pedal to work with a PC. It has a Backspace Button and a Start Button. It plugs right in the PC PS/2 port. OH CRAP, my sensor mouse stopped working when I tried the foot pedal with a USB adaptor. The Red LED light in the mouse completely died, now worried if I did some damage. After hard resetting my precious CRT iMac, waiting forever panicking for the defrag reboot, the mouse worked again. Popping the cover reveals a direct wire lead from the micro switches to the plug, no internal PCB. Whew! The USB port prevented permanent damage. Upon research which stupid me should have done first, this foot pedal plugs into a Dictaphone Transcriber Deck. Panasonic RR930 and RR830 Cassette Deck used in courtrooms, medical offices and sales. Okay, so I have to pick up a cheap PC PS/2 keyboard and solder in the PCB. So what is the point of this two switch unit? It has very accurate micro switches inside and is a perfect switch box for Track and Field and any rapid rocking switch games! Easily a Mame capable using a gutted PC PCB keyboard encoder. By sticking with the PC PS/2 connector it can also hook into the PS2 SmartJoy Frag box. Remember PSX Metal Gear during the torture scene? How about PS2 Ravin Rabbids or more recently the Castle Crashers level in PAL Alien Hominid. The foot pedal switches are HUGE and very responsive, great for the thumbs or slapping with the entire hands. So much better then the regular button switches Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 2, 2018 Share Posted February 2, 2018 (edited) No, he wants a push button toggle switch. I completely over looked the "push button" I probably didn't finish reading the whole thing so I apologize for not being thorough but this will work then. It is a DPDT switch you can use it as SPST just leave one poll and its set of contacts alone(edited out a mistake getting all kindsa mixed up tonite) Can be found here https://www.delcity.net/store/Power-Window-Rockers/p_788898.h_788899.r_IF1003?mkwid=saMeLDwEL&crid=38094426869&mp_kw=&mp_mt=&gclid=EAIaIQobChMIh-qz_raI2QIVwR-GCh1Rrg5OEAQYASABEgJxnfD_BwE Edited February 3, 2018 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 3, 2018 Share Posted February 3, 2018 Now just to clear things up. I missed the push button on the first reply I made. Then it is pointed out so I do find a momentary push button as apposed to the on-on toggle I originally posted, but am still unclear do you want a momentary or toggle? Reason I'm asking is because there is a toggle or momentary push button and there are also toggle or momentary rocker switches. That is where the confusion comes in. Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2018 Author Share Posted February 3, 2018 Think of an arcade button. Press it once it rocks to one side, press it again it rocks to the other side. Or when it's pressed it hits the left and middle pole, when it's depressed it hits the right and middle pole. But is controlled with a vertical push button, not a rocker. Toggle not momentary. Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2018 Author Share Posted February 3, 2018 I want this function: in this form factor: Make more sense now? Sorry for sounding like such a dumbass here but currently the shoe fits so I'm wearing it. 1 Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 3, 2018 Share Posted February 3, 2018 (edited) https://www.circuitspecialists.com/66-2246.html That should be it It is an ON-ON toggle Hope it helps Edited February 3, 2018 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 3, 2018 Share Posted February 3, 2018 (edited) Your reply came in after mine so now I found something that you may like better http://cablesandconnectors.com/PIX/phi3010055.jpg You would want Part number 30-10055 EDIT: Or here is an ebay link to some others you might like instead https://www.ebay.com/itm/10-Pcs-SPDT-Round-Button-On-On-Rocker-Black-Red-Switch-AC-6A-125V-3A-250V/272884696393?hash=item3f89320549:g:uKQAAOSwAClZ3107 Edited February 3, 2018 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2018 Author Share Posted February 3, 2018 Yes but a real push button, not a rocker. like this crude ms paint winner: So when it's in it's pressed or depressed it hits 2 out of 3 polls with the middle being the common connection. Maybe they don't exist and I will just be stuck with a rocker or spdt Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 3, 2018 Share Posted February 3, 2018 Yes but a real push button, not a rocker. like this crude ms paint winner: d.png So when it's in it's pressed or depressed it hits 2 out of 3 polls with the middle being the common connection. Maybe they don't exist and I will just be stuck with a rocker or spdt This should do if it is the right size you need https://www.ebay.com/itm/AC-250V-5A-SPDT-1NO-1NC-5-Pins-Latching-Green-Push-Button-Switch-w-220V-LED-K0H3/172801968777?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20150817211758%26meid%3D551a11017b0c4622b4d414472a77933e%26pid%3D100507%26rk%3D1%26rkt%3D1%26%26itm%3D172801968777&_trksid=p2045573.c100507.m3226 If you already have a SPST on-off toggle the right size you need for whatever you are putting it in you could also make it work using a relay perhaps but I think the one I posted above should do. 1 Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted February 3, 2018 Share Posted February 3, 2018 (edited) Make more sense now? Sorry for sounding like such a dumbass here but currently the shoe fits so I'm wearing it. I'm the dumbass. You said it pretty clear what you wanted and only 5 replies later I got it(maybe). I kinda glanced over the whole thing and saw kinda like a rocker switch and showed you the bat type toggle switch, then thought maybe since like a rocker switch but like a push button thought maybe you might a meant a momentary push button action in an actual rocker switch style, then after that I misinterpreted what you said and showed you a toggle rocker switch, then finally get to the actual "push button" toggle switch that many replies later, after CPUWiz pointed it out after the first reply I made and I still kept getting it wrong, lol. I'm the dumbass. Edited February 3, 2018 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
SIO2 Posted February 3, 2018 Share Posted February 3, 2018 (edited) Hopefully post #12 is what you wanted. What I make out of what you have said is that you want a latching push button that completes one circuit when depressed and a different circuit when released with one common lead. This maybe? https://www.walmart.com/ip/19mm-Mounted-Thread-3-Pins-SPDT-High-Head-Latching-Push-Button-Switch/163277284?wmlspartner=wlpa&selectedSellerId=571&adid=22222222227042227065&wl0=&wl1=g&wl2=c&wl3=106305758477&wl4=pla-293289304157&wl5=9024793&wl6=&wl7=&wl8=&wl9=pla&wl10=111838760&wl11=online&wl12=163277284&wl13=&veh=sem They sell them as on/off but, with three terminals I think they are the equivalent of a SPDT slide in push button form. But what you want is like an Atari difficulty switch but a push button yes? Edited February 3, 2018 by SIO2 3 Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 3, 2018 Author Share Posted February 3, 2018 Hopefully post #12 is what you wanted. What I make out of what you have said is that you want a latching push button that completes one circuit when depressed and a different circuit when released with one common lead. But what you want is like an Atari difficulty switch but a push button yes? Correct 1 Quote Link to comment Share on other sites More sharing options...
+GoldLeader Posted February 3, 2018 Share Posted February 3, 2018 OOOooohhh, I thought maybe ya wanted a Butt Rocker. Quote Link to comment Share on other sites More sharing options...
+GoldLeader Posted February 3, 2018 Share Posted February 3, 2018 Sorry...The title here triggered a memory. I couldn't help but notice the words Button Rocker ...And back in the thrash days, I had a friend who'd call bands like Ratt and Def Leppard "Butt Rockers"...Always kinda cracked me up! Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted February 6, 2018 Share Posted February 6, 2018 Sounds like you are looking for an SPDT (Single Pole Double Throw) latching pushbutton switch if you want two permanent states (push for one state, then push again to return to the previous state). Otherwise you are after a SPDT momentary pushbutton switch (sprung to one state, held in the other only while being pushed). If you are just replacing an existing switch you should not have any other considerations, if you are building something yourself remember that when the switch is a particular position the other throw connection will be floating (no connection to the pole). That is generally a bad idea (creates random results as the circuit responds to any stray signal pickup) and so depending on your application the throw connections will need to be pulled either high (if the pole is connected to Ground) or low (if the pole is connected to the supply) via a resistor so that a defined high/low input is always fed to the respective part of the circuit. 1 Quote Link to comment Share on other sites More sharing options...
BigO Posted February 6, 2018 Share Posted February 6, 2018 ^^ What he said ^^. Quote Link to comment Share on other sites More sharing options...
