SDrive-MAX ATX support
Farb
Hello, I asked this a while ago but never got a good answer. I’m using the SdriveMax on an 800. I think I have the latest sdrive.atr file on it. My issue is, I can’t get the “find” functionality to work to locate a file. (I’ve read the docs) I hit ctrl-f, it displays “Find:” but nothing happens. Doesn’t find any files. Also the supposed shortcuts (shift-a, etc) don’t work either. Makes navigating a long list of files tedious. Anyone got any thoughts?  Thanks.
For the find command to work, you need to hit Ctrl-F to display the Find prompt. At that point, you enter a portion of the beginning of the file name. It doesn’t look like Find works to search in the middle of a file name.
I’m not familiar with the keyboard shortcuts you mention, but the shortcuts on this page work for me:
https://atari8bit.net/everything-sdrive-max/#Controlling_SDrive-Max_from_the_Atari
Bob C
Bob C
Ummm... that’s exactly what I said I did.... hit Ctrl-F and type. Nothing happens. (Ok, I didn’t explicitly say I typed something to find, but figured it was implied...)
and the shortcuts I mentioned are in the original docs linked from that page - https://atari8bit.net/wp-content/uploads/SDrive_en.pdf
Well it seems no-one has any more info, I went digging through the Github repo for the SDriveMax firmware, especially the sdrive-ctrl code (https://github.com/kbr-net/sdrive-max/tree/v13/sdrive-ctrl)
I have a feeling it has to do with 800xl vs 800 (as there were similar issues with the SIO2SD device). I see in the code here: https://github.com/kbr-net/sdrive-max/blob/df7448b9571ac660e994da74c1f377213614e661/sdrive-ctrl/sdrive.xa#L1239 that it's looking for an XL specific keyboard table (https://www.atariarchives.org/mapping/appendix12.php - KEYDEF). So I'm guessing that's part of the issue. I guess I'll take a stab at the rest of the code (unfortunately, the comments are in Czech.. Google translate, here I come!
Good catch, people who have or use a real 800/400 are very rare, unpayable :)
I will keep it in mind, the input methods could have an update anyway, the OPTION key for scroll down is suboptimal in my opinion, but the atari side of programming is not my biggest goal...
@kbr Thanks! I wanted an 800 since I was in high school (quite a while ago :) ) so jumped on the chance to get one (I actually end up with two!) I'd love to get my hands on an 800xl at some poing.
I will give it a try as soon as I can. I'm curious though, where did you find reference to how you're converting the keys on the 800?
atari800
lda $fefe,y
I can't find any reference to that location in the memory mapping book (Mapping the Atari, etc.)
Thanks again!
First i looked at the hardware sheet, and found no difference to the key wiring, so i thought, we can take the same mappings.
There is known, that on XL/XE the key table pointed on ($79)(121) is at $FB51. So i used the emulator for atari 800, and diged through the ROM, and found the same table at $FEFE, that's all.
  • 3 weeks later...
Quote
V12c files do not compile properly. After recompilation, the SDrive.hex file is 91 KB and cannot be loaded
Why use V12c, this was a development branch only and is no more present. It may be, that in some stages the code was too big for some display variants...
Use the Master branch for a clean version, or if you are risky V13 :)
It could also depend on your compiler version, i use avr-gcc version 5.4.0.
I compiled this version.  I am sure it was successful, both the compilation and the flashing of the arduino.  However, my SDrive-MAX still lists "v1.2" on the touch screen.
Is there something I overlooked doing?
-SteveS
15 hours ago, kbr said:
The Master branch is equal to V1.2, right, the last stable version.
V13 is the actual unstable development branch, a daily snapshot, if you want.
Branch v13 is what I cloned but the display still indicates v1.2.
p.s.
Nevermind.
The fourth attempt was the charmer.  v1.3b now installed.
Edited by a8isa1
Hi,
Thank you for this great project.  Will the below work.  I don't want a Arduino board or any touch screen stuff.  I just want the below SIMPLE board like below.
1) Get an ATMEGA328P, flash the eeprom_writer.hex and the SDrive.hex.
2) Wire the pins of the ATMEGA328P as indicated on the web site https://atari8bit.net/everything-sdrive-max/ to the Atari SIO connector's pins.
3) Then wire the MISO/MOSI/SCK/SS pins of the ATMEGA328P to my SD CARD adapter.
4) Wire all the ATMEGA328P pins to the buttons shown in the image.
5) Wire all the ATMEGA328P pins to the LEDs shown in the image.
My questions are:
1) Is there a firmware version available that does not have the touch screen stuff in it with the buttons and LEDs handling?
2) Can my entire board, as described above, can run with 3.3V at 16Mhz for the ATMEGA328P? Basically, I take the +5V from the Atari's SIO connector and feed it to an LDO to have 3.3V to power the ATMEGA328P and the SD CARD.
3) I can simply copy the sdrive.atr file into the SDCard, and the Atari computer will load this diskette file, so that I can run a menu program on the Atari computer?
4) Is there a schematic already available for the simple SDMax board I described above?
Many thanks!
3 hours ago, unebonnevie said:
Hi,
My questions are:
Many thanks!
You want the original SDrive I think?
https://atari8bit.net/wp-content/uploads/SDrive20090403.zip
Looks like a wish list, basically he wants the old unit's firmware updated to be like sdrive max minus all the code for hardware it doesn't have like screen and digitizer etc... and that way the new on screen menu etc could be used possibly with a sprinkling of a feature request.
Edited by _The Doctor__
Oh, best of luck then ?
7 hours ago, unebonnevie said:
Hi,
My questions are:
Many thanks!
No.
No.  I just wanted something simple to try first.  Thanks to mimo for the link to the zip file!
