atrax27407 Posted August 12, 2020 Author Share Posted August 12, 2020 (edited) I have an adapter coming Friday or Saturday that will allow me to do 1 Meg and 2 Meg chips on the TL866CS. Then, of course, I just had to order a couple of each (27C800 and 27C160) to play with as well. It will also do 27C322 (4 Meg) and 27C400 (512K) as well. The chips are done in 512K chunks. We'll see how this works out! Edited August 12, 2020 by atrax27407 2 Quote Link to comment Share on other sites More sharing options...
Frank N Posted August 17, 2020 Share Posted August 17, 2020 Can I create a new part if it is not in the library. eg reading a 74188 PROM. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted August 17, 2020 Author Share Posted August 17, 2020 Not currently. Quote Link to comment Share on other sites More sharing options...
Frank N Posted August 19, 2020 Share Posted August 19, 2020 Is there a programmer that will let you create a part? Need to read really old roms and PLA's. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted August 19, 2020 Author Share Posted August 19, 2020 That function is scheduled for the T56 but I don't think it has yet been implemented. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted August 19, 2020 Author Share Posted August 19, 2020 TL866II and T56 updated to version V10.31 effective 08/19/2020 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 19, 2020 Share Posted August 19, 2020 8 hours ago, Frank N said: Is there a programmer that will let you create a part? Need to read really old roms and PLA's. One note, a lot of those really old PLAs had their fuses blown to prevent you from reading them out to copy them. Most of the time, you have to find copies of the equations used to generate the original programming (sometimes this exists) or go through the somewhat laborious process of running it through a cycle that tests every single input combination, record the outputs, and use that to figure out what the original program code was doing (this should let you recreate the equations, which can be used to recreate the programming file). Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted August 19, 2020 Author Share Posted August 19, 2020 Here are the Device Support Lists as of 08/19/2020: TL866CS Universal Programmer Davice List.txt TL866II Universal Programmer Device List.txt Xegcu T56 Universal Programmer Device List.txt Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 2, 2020 Author Share Posted September 2, 2020 TL866II/T56 updated to V10.33 as of 09/02/2020. More chips added. TL866II Universal Programmer Device List.txt Xegcu T56 Universal Programmer Device List.txt 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 3, 2020 Author Share Posted September 3, 2020 (edited) TL866II/T56 updated to V10.35 as of 09/03/2020: Version: V10.35 2020.9.3 Emergency repair of EMMC ISP a BUG in Version: V10.33 2020.9.2 Edited September 3, 2020 by atrax27407 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 17, 2020 Author Share Posted September 17, 2020 TL866II/T56 updated to V10.37 as of 09/17/2020. Multiple chips added and various fixes. Quote Link to comment Share on other sites More sharing options...
llopis Posted September 18, 2020 Share Posted September 18, 2020 After struggling to use the TL866II Plus to try to program some 2732 (which failed, probably because they were fake EPROMs) and then making a rather ugly 27C128 adapter on the fly (see video below), I would love to make or buy a small PCB that has those adapter connections built-in. Before I just make my own, is there one already available? Either as Gerber files or ready to buy somewhere? My initial search failed to find anything (mostly this thread comes up, but it seems to be more about the adaptor for the 2732 instead of a 28-pin one like I need). 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted September 18, 2020 Share Posted September 18, 2020 The failure with the 2732s probably had another cause: programming voltage. I'm pretty sure that the TL866-II lost the ability to program 21V chips. For those you would need a TL866CS instead. You do have to be careful even there, as early 2732s require 25V, but most later ones seem to be tolerant of 21V and all 2532As are 21V chips. On the adapter, I haven't seen any 2732 to 27C128 adapters either. There really hasn't been a need for such, as most of us can program the 2732s. 1 Quote Link to comment Share on other sites More sharing options...
llopis Posted September 18, 2020 Share Posted September 18, 2020 10 minutes ago, Ksarul said: The failure with the 2732s probably had another cause: programming voltage. I'm pretty sure that the TL866-II lost the ability to program 21V chips. For those you would need a TL866CS instead. Right, I saw that too. And after it failed, I tried the trick of applying 21V to VPP directly to one pin and it made no difference either. At that point I wasn't sure if it was the programmer just not supporting them (even though they claim to) even with the applied voltage, or if they were fake chips. The fact that they all had different die sizes and shapes doesn't fill me with confidence. If you're familiar with legit 2732s, can you have a look at the video and see if you think they're fakes? Here's the link with the time stamp to the close up (04:30) 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 18, 2020 Author Share Posted September 18, 2020 Unicorn Electronics is the best source for genuine, out-of-production chips - they are Hodge16 on eBay as well. They will usually combine shipping on multiple orders as well if you ask them. I have had good luck with the Chinese vendor Funkward as well. But Unicorn is always my first choice for old retro chips. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 18, 2020 Author Share Posted September 18, 2020 Here is an adapter board for 2732<->TMS2532s on eBay: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311&_nkw=2732+eprom&_sacat=0 Quote Link to comment Share on other sites More sharing options...
llopis Posted September 18, 2020 Share Posted September 18, 2020 7 minutes ago, atrax27407 said: Here is an adapter board for 2732<->TMS2532s on eBay: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311&_nkw=2732+eprom&_sacat=0 Yeah, but I can't program the 2732 easily either with my crappy programmer. I'm looking for a 27128 -> TMS2532 (so, 28 pin to 24). If not I can probably easily make one this evening, but I figured I would ask first in case there was one available. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 18, 2020 Author Share Posted September 18, 2020 Try this one : http://store.go4retro.com/23xx-adapter/ Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 18, 2020 Author Share Posted September 18, 2020 FYI, there are several 2732As that are listed as 12.5V in their datasheets: AMD AM2732ADC, Fujitsu MBM2732A, and the ST M2732A. All of them should work on the TL866II. 1 Quote Link to comment Share on other sites More sharing options...
llopis Posted September 19, 2020 Share Posted September 19, 2020 8 hours ago, atrax27407 said: FYI, there are several 2732As that are listed as 12.5V in their datasheets: AMD AM2732ADC, Fujitsu MBM2732A, and the ST M2732A. All of them should work on the TL866II. Oh! I didn't realize that. That's super useful. Thanks! Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted September 19, 2020 Author Share Posted September 19, 2020 (edited) Most of the "A" variants are reduced voltage chips. The required voltage, however, depends on where the manufacturer started with the original (ex., 25V to "A" 21V, 21V to "A" 12.5V, etc.). I always download and examine the chip manufacturer datasheet before I order a batch of new chips and compare its specs with similar chips that I have in stock (I keep a table). If the chips are JEDEC-compliant (most are), to an EPROM programmer one 2764 (or 2732, 27128, etc,) looks very much the same as another. The only difference is usually the voltage requirements and pulse interval requirements. Programmers like the TL866CS/A and TL866II will program them even if they don't expressly appear in the "Support List" as long as the voltage and other requirements are the same for the "new" chip. In fact, those values can be manipulated in the programmer to a greater or lesser degree before you start burning the code. Just use a chip with similar requirements as the template and program the "new" chip as if it were the chip in the template. It works almost every time. Some of the others that are not on the Support List will need an adapter. For example, some years ago Tony Knerr discovered that the TMS2532 (25V) and the TMS2532A (21V) were really the same chip (neither are on the TL866CS Support List). Both are tolerant of being programmed at 21V without any problem whatever and by the extension so are the Motorola and Hitachi equivalent chips as well since they were licensed by TI. However, three of the lines needed to be changed to find an acceptable JEDEC template to use. So, he came up with a small adapter (Post #18) which used the TMS2732A (21V) as a template. I have programmed several hundred of them over the years on my TL866CS using this process. The only "hiccup" was when I ordered some chips from a Chinese supplier some years ago, half of which were blatant counterfeits and would not program at all. Now, I order from Unicorn Electronics or a very few reliable Chinese sources that I have had favorable dealings with in the past. Edited September 19, 2020 by atrax27407 Additional info 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted October 4, 2020 Author Share Posted October 4, 2020 (edited) The TL866II+/T56 has been updated to Vn 10.39 with multiple chips added. Edited October 4, 2020 by atrax27407 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 4, 2020 Share Posted October 4, 2020 2 hours ago, atrax27407 said: The TL866+/T56 has been updated to Vn 10.39 with multiple chips added. I presume you mean TL866II/T56? ...lee Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted October 4, 2020 Author Share Posted October 4, 2020 (edited) Sorry - that is correct. It has been edited. Edited October 4, 2020 by atrax27407 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted October 22, 2020 Author Share Posted October 22, 2020 T56/TL866II has been updated to Vn 10.41 effective 10/22/2020. More chips added. 1 Quote Link to comment Share on other sites More sharing options...
