First Spear Posted November 20, 2018 Share Posted November 20, 2018 (earlier code increments #goRun variable and then Gosub TextShow then Wait 3 seconds) TextShow: Procedure Restore TextTable For #nom = (#goRun*11) to (#gorun*11+11) Read #titleText Next Print At 220 Color 7 , #titleText Return End TextTable: Data "posting " Data "a new topic" Data "is fun " I want this to show "posting" then pause for 3 seconds then show "a new topic" then pause for 3 seconds then "is fun". Each string is forced to 11 characters. What is wrong with that code? Am I missing multiplication somewhere due to using PRINT? Thanks. Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 20, 2018 Share Posted November 20, 2018 I'm not sure what you're doing with that loop structure. You're reading values in a loop and only doing something with the last one after the loop. Something like this might be more effective: . #tmp = #goRun * 11 FOR #num = 0 TO 10 #BACKTAB(#num + 220) = (TestTable(#tmp + #num) - $20) * 8 + 7 NEXT #num . I don't know that PRINT offers a "print string at pointer." I'm sure some IntyBASIC experts will offer better ways to encode your strings so you don't have to do the offset-and-multiply I'm doing above. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 20, 2018 Share Posted November 20, 2018 TextShow: Procedure Print At 220 For #nom = (#goRun*11) to (#gorun*11+10) ' Plus 10 not 11 because zero counts. Print TextTable(#nom) * 8 + 7 ' Convert to GROM and add color Next Return End TextTable: Data "posting " Data "a new topic" Data "is fun "Of course this would be somewhat inefficient because the continuous multiplication by 11, but it should work. Remember that using a variable or expression directly copies that word value into the screen without changes. Quote Link to comment Share on other sites More sharing options...
