+SmittyB Posted January 26, 2019 Share Posted January 26, 2019 (edited) To help speed up building phrases for the AtariVox I've completely overhauled a previous test utility I made to improve on a few gripes I had with it. This is designed to allow someone (namely me) to use the SpeakJet reference sheet to build a list of commands while being able to freely edit parameters like volume and pitch. You can also change the colours used from the title screen to make the text easier to read on some displays. I've considered adding the ability to insert and delete rows, and I've added keypad support but haven't mapped the keys to anything yet. As this is primarily a tool I made for myself to speed up work on other things I will probably only make changes as and when I need them. ~Disclaimer~ You can send any command to the AtariVox, including the 'Reserved' commands from 32 to 127 inclusive so if anyone accidentally sends the self-destruct sequence, or otherwise damages the Vox or their saved data, then sorry you're on your own. ~Columns~ Tracker: No - The number of the row from 0 to 31 F/S - Send the 'Fast' or 'Slow' command to change the play time of the next phoneme S/R - Send the 'Stress' or 'Relax' command to add stress or relaxation to the next phoneme Vol - Set the current volume Spd - Set the current speed Ptc - Set the current pitch Bnd - Set the current bend Phone - The phoneme or other command to send Data: No. - The number of the row from 0 to 255 Data - The compiled speech data. A reset command (31) is automatically added at line 0, and the end of phrase command (255) is automatically added at line 255. If the volume, speed, pitch, or bend is the same value as the previous line it is ignored. ~Controls (Joystick / pad)~ Title Screen: L/R - Change foreground colour U/D - Change background colour Button 1 - Go to the tracker screen Button 2 - Go to the tracker screen Tracker Screen: L/R - Select column U/D - Select row Button 1 + L/R - Change value by 10 Button 1 + U/D - Change value by 1 Button 2 - Play phrase Select - Go to the data screen Reset - Go to the title screen Data Screen: U/D - Select row Select - Go to the tracker screen Reset - Go to the title screen Voxolotl.a78 Voxolotl.bin Edited January 26, 2019 by SmittyB 4 Quote Link to comment Share on other sites More sharing options...
Jinks Posted January 26, 2019 Share Posted January 26, 2019 Really neat. Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted May 14, 2020 Author Share Posted May 14, 2020 I've recently given Voxolotl! a complete overhaul to better suit my needs for it. Rather than sticking with the awkward joystick button combinations it now uses a keypad in the left port with the AtariVox in the right as usual. I've cut out the fast/slow, stress/relax, and volume controls as I just wasn't using them. Instead I've used the space to show the description text from the speakjet documentation so it's easier to see what's been entered. A problem I had with the previous version is that while the speech data would ignore parameters if they were the same across consecutive rows, changing any of the values in the editor would require changing it across multiple rows. Now if you enter an invalid value for a parameter it will blank it out and use whatever the previous valid entry was (or the speakjet defaults). Pitch can normally be set all the way to 255 but for the sake of consistency here it removes the value change. Keys: 01|02|03 04|05|06 07|08|09 10|11|12 01 - Toggle between the editor and hex-data view 02 - Move cursor up 03 - Play speech 04 - Move cursor left 05 - Move cursor down 06 - Move cursor right 07 / 08 /09 - Edit value 10 - Delete selected row 11 - N/A 12 - Insert row above Voxolotl!.a78 Voxolotl!.bin 4 Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted August 9, 2020 Author Share Posted August 9, 2020 As a natural extension of the 7800 version I have now developed a Windows version of Voxolotl! which can make use of a 2600-daptor II to play the speech from the PC through an attached AtariVox. It's not perfect and has a shed-load of flaws, but it's good enough for me and is so much faster than using the 7800 versions. Given that this now doesn't require having a 7800 and one of the few elusive 7800 flash-carts to run this should be good for both 2600 and 7800 developers interested in getting speech into their games. Edit: I've attached a zip with a folder 'platforms' containing an additional DLL. The 'platforms' folder may need to be in the program folder to allow it to run. Voxolotl! - AtariVox Voice Tracker.zip platforms.zip 6 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted August 9, 2020 Share Posted August 9, 2020 I've been waiting for an excuse to muck about with my AV+ Thanks @SmittyB 2 1 Quote Link to comment Share on other sites More sharing options...
SlidellMan Posted August 10, 2020 Share Posted August 10, 2020 Blake, that has to be a must for those who plan on Atari Vox support. 3 1 Quote Link to comment Share on other sites More sharing options...
