Byte Knight Posted July 5, 2019 Share Posted July 5, 2019 Just fired up some PGA Golf today and the best I could do was a 37 (par is 38). The manual states "A very skilled player can probably play a 32 or even a 30 stroke game with a little luck." There is no way in HELL that someone could get a 30 stroke game, let alone a 32. What's the lowest score you've ever gotten? 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 5, 2019 Share Posted July 5, 2019 (edited) If you can do all nine holes without having to use your putter you might do under 30. My best score is 33, done back in 1982/83. The location of the trees change every time you play; sometimes that helps. Edited July 5, 2019 by mr_me 1 Quote Link to comment Share on other sites More sharing options...
gavvv Posted July 8, 2019 Share Posted July 8, 2019 I believe 36 is the best my friend and I could ever do back in the day on his intv. Maybe one 'mistake' mixed with one hole-out. Once I got back into intv and I discovered Chip Shot, haven't really played much PGA. 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 8, 2019 Share Posted July 8, 2019 A skilled player should birdie holes 3, 4, 9 regardless of where the trees are. With help from tree placement holes 5 and 8 can be easy birdies. Hole seven looks like a possible birdie but your putter is so week you might as well try and chip it in. So is a 32 possible without luck with the irons? You can keep resetting until you birdie hole one and maybe get lucky in a couple of other holes. 1 Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted July 9, 2019 Author Share Posted July 9, 2019 That would take a ton of luck, so I still think the manual is unrealistic... Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 9, 2019 Share Posted July 9, 2019 One thing I've always had trouble with is judging trajectories and hitting over trees. PGA Golf is 3D. With more aggressive play maybe there's an extra stroke or two that I'm missing. You have to be good to be lucky. It doesn't take many retries to birdie the first hole and chipping balls in does happen. I'm thinking that's what gavvv means by hole-out. Having two of those in one round might bea little lucky. It's even possible to eagle a hole or two. If you play enough, like I did in 1982, these things happen regularly. Quote Link to comment Share on other sites More sharing options...
poconojo Posted February 5, 2020 Share Posted February 5, 2020 On 7/5/2019 at 12:58 PM, mr_me said: If you can do all nine holes without having to use your putter you might do under 30. My best score is 33, done back in 1982/83. The location of the trees change every time you play; sometimes that helps. 33. Thats really good. I have been playing a lot lately. My lowest score is a 37. I should have shot a 36, but I bogeyed the last hole. My best score in the early eighties was 39 I think. Quote Link to comment Share on other sites More sharing options...
poconojo Posted February 5, 2020 Share Posted February 5, 2020 Finally shot 36. 2 Quote Link to comment Share on other sites More sharing options...
