Atari Forth programming.
Allan
Question to anybody familiar with Atari Forth programming.  Is there any way to import a text file into a Forth editor? Or do you have to create Forth code in a Forth editor? There are a few Forth listings in early Antic magazine issues and I would like to include them with other language listings on a ATR disk image, but don't want to waste my time typing them in if there is no way to import an atari text file Forth listing into a Forth editor. Any input would be helpful.
None of the fig-FORTH environments had a way to read DOS files into screens.
You could literally cut and paste into the FORTH environment, you would load the fig-forth editor (e.g. 21 LOAD on extended fig-forth), and then you could add screen edit words in front of the text:
0 P  ( This is the first line  )
1 P  ( This is the second line )
2 P  ( This is the third line  )
You can then flush the screen to disk.
and cut and paste that into the forth environment (e.g. with Altirra)
You just need to be aware of the screen size in the forth you are using (e.g. extended fig forth uses screens sized 80 columns by 16 lines)
-Thom
Thanks, Thom.
I will add a text file of the Forth listings then so people can cut and paste them into an emulator. I am putting a later Antic menu program on each disk which also included a help file to explain file extentions. I will add your comments to the help file on disks that have Forth listings on them.
Allan
Thom is right on the fig-FORTH implementations, but there are a few implementations that can read DOS files:
X-FORTH, VolksForth for example. They both have an INCLUDE" word, used like:
INCLUDE" D1:MYFILE.FS"
Edited by robdaemon
added screenshot from voilksForth
  • 3 weeks later...
When I was doing something similar last year with a large OCR of Forth code, I wrote a Perl tool that would punch the data directly into an atr.  You can probably adapt it.
qfigs1.zip
  • 5 months later...
  • 2 years later...
