Start Here
SpiceWare
NOTE: This tutorial is being replaced with one for CDFJ+.
NOTE: I want to clarify up front that this is an advanced Atari 2600 programming series. As such, I will not be covering basic things like triggering a Vertical Sync, what a Kernel is, why you need to set a timer for Vertical Blank, etc. If you need to learn that you should check out with the following:
  • Collect - detailed development of a 2K game
  • 2600 Programming for Newbies - use the Sorted Table of Contents topic that's pinned at the top in order to easily access the tutorial topics in order.
CDFJ Tutorial Index
NOTE: Check out Start Here in the General forum for instructions on how to set up an environment for CDFJ development.
  • Like 6
