+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 3 minutes ago, wolhess said: I'm use the tipi Telnet program on my TI and the same behavior occure. So I think it has nothing to do with windows. That makes me wonder, unless something has changed, what the difference is between my Geneve setup and MyTerm client and the TI-99/4A setup client and AfterHours may be. Beery Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543157 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 So now I tried the login from my ipad with iterminal ssh. The same things happens. After a logout (pressing G from main menu) or fctn= from sysop or after timeout the BBS shows the login screen again. I will test this with the files you sent before yesterday, I didn't remember that this happens before today. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543172 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 I have tested the program version from Tuesday and it happens the same. After logout with G from the main menu the BBS shows the login screen again. So after a BBS session finished the BBS needs 6 minutes to accept the next caller. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543199 Share on other sites More sharing options...
+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 12 minutes ago, wolhess said: I have tested the program version from Tuesday and it happens the same. After logout with G from the main menu the BBS shows the login screen again. So after a BBS session finished the BBS needs 6 minutes to accept the next caller. OK, I will increase the timer setting. Just a FYI, you can press the L key (case does not matter) for local login if you desire. Beery 1 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543206 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 6 minutes ago, BeeryMiller said: Just a FYI, you can press the L key (case does not matter) for local login if you desire Right now I tried the L key from the waiting sysop screen. No login! It is working, I have to press a longer time the L key!! Thank you! Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543207 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 8 minutes ago, BeeryMiller said: OK, I will increase the timer setting. Just a FYI, you can press the L key (case does not matter) for local login if you desire. Beery With the local login there is no second login loop after logout! Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543213 Share on other sites More sharing options...
+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 8 minutes ago, wolhess said: Right now I tried the L key from the waiting sysop screen. No login! It is working, I have to press a longer time the L key!! Thank you! I think that was in some of the TIPI docs I wrote. There is also a G at that same prompt that exits AfterHours and returns back to the Title Screen. There is about a 3 to 5 second loop involved right there which is why you have to hold the key sometimes a bit longer waiting for it to pass through that keyscan loop. That was required to give the CRON job enough time to test the internet connection should it need to restart the TIPI services. Beery 1 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543222 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 I had changed some texts and it seems that all is working now. how can I make a new message group for e.g. German speaking users? Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543234 Share on other sites More sharing options...
+arcadeshopper Posted May 21, 2020 Share Posted May 21, 2020 I think that was in some of the TIPI docs I wrote. There is also a G at that same prompt that exits AfterHours and returns back to the Title Screen. There is about a 3 to 5 second loop involved right there which is why you have to hold the key sometimes a bit longer waiting for it to pass through that keyscan loop. That was required to give the CRON job enough time to test the internet connection should it need to restart the TIPI services. BeeryYou might want to make the screen change sometime. The current waiting screen is very static.. burning inSent from my LM-G820 using Tapatalk Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543241 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 @BeeryMiller is there a chance to assemble the complete software on a TI? Maybe I will change the language of the BBS to German. just a thought. 1 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543259 Share on other sites More sharing options...
+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 It's not going to assemble with the TI assembler as I used some long label names that the TI assembler will choke on. Rather, it will need a Geneve with GenASM. If you have MAME setup to run a Geneve system, then it should be rather easy. If you do, and/or want to setup a system and want to go that route, let me know. I can get you setup pretty quickly. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543279 Share on other sites More sharing options...
+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 58 minutes ago, arcadeshopper said: You might want to make the screen change sometime. The current waiting screen is very static.. burning in Sent from my LM-G820 using Tapatalk I have my system setup on a very old TI 13" monitor I pulled out of the closet this past weekend with a sidecar TIPI and console. Monitor is generally off. When I walk into my office, I just take a look at the sidecar TIPI. If the light is solid, it means it thinks there is a telnet connection and I will turn on my monitor. If it a periodic blink, about once every 4 to 5 seconds, it means it is just sitting there waiting for a call. If no light blinking, then the board crashed which is what I was experiencing early on until Matt updated the TIPI services software to be more robust. If someone recalls what can be written to the video register to 'blank' the screen and then what is written to restore, I could possibly just blank the screen after every disconnect and 'unblank' the screen afterwards. However, that would remove the "Status" display indicating what command the TIPI is doing while waiting for the call. Beery Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543288 Share on other sites More sharing options...
+arcadeshopper Posted May 21, 2020 Share Posted May 21, 2020 I have my system setup on a very old TI 13" monitor I pulled out of the closet this past weekend with a sidecar TIPI and console. Monitor is generally off. When I walk into my office, I just take a look at the sidecar TIPI. If the light is solid, it means it thinks there is a telnet connection and I will turn on my monitor. If it a periodic blink, about once every 4 to 5 seconds, it means it is just sitting there waiting for a call. If no light blinking, then the board crashed which is what I was experiencing early on until Matt updated the TIPI services software to be more robust. If someone recalls what can be written to the video register to 'blank' the screen and then what is written to restore, I could possibly just blank the screen after every disconnect and 'unblank' the screen afterwards. However, that would remove the "Status" display indicating what command the TIPI is doing while waiting for the call. BeeryDoesn't need to blank could change the colors like they did in the original version or move the text at each cycle maybe have it change locationSent from my LM-G820 using Tapatalk Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543319 Share on other sites More sharing options...
wolhess Posted May 21, 2020 Share Posted May 21, 2020 1 hour ago, BeeryMiller said: If you do, and/or want to setup a system and want to go that route, let me know. I can get you setup pretty quickly. I will think about it. I tried several times to install mame without success. Only the Gamebase is working, with mess I think. but anyway I will trie it again. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543337 Share on other sites More sharing options...
+9640News Posted May 21, 2020 Author Share Posted May 21, 2020 48 minutes ago, wolhess said: I will think about it. I tried several times to install mame without success. Only the Gamebase is working, with mess I think. but anyway I will trie it again. What I have done in the past was just copy my entire MAME folder. Then, it was just a matter of executing the batch file that loaded up the system. All images, everything with it ready to go. Beery 1 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543378 Share on other sites More sharing options...
wolhess Posted May 22, 2020 Share Posted May 22, 2020 With Michael Zapf's help, I was able to install MAME. Now I need some time to learn to work with Mame and the Geneve. 3 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543876 Share on other sites More sharing options...
+mizapf Posted May 22, 2020 Share Posted May 22, 2020 In particular by the help of this video: Too bad it's already buried deep in the thread, so just a short reminder. 2 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543942 Share on other sites More sharing options...
+9640News Posted May 22, 2020 Author Share Posted May 22, 2020 Wolfgang, If you go to http://9640news.ddns.net:8080/ you will see the PDF's for the complete GenProg package. Also, I found a thread where I had previously posted a copy of MAME I was using. It is not the latest MAME version since it was a 2019 post, however, inside is a hard drive image called Bootdisk1.hd You may want to substitute your current hard drive image (rename the files) and look at that image. It should have a bunch of programs on it. At the MDOS prompt, you should be able to type ASM and it should find the program in the path and give you a response. Typically, I name the batch file for the assembly process "ASS" for ASSemble. I've got two batch files. One is "ASS", and the other is "ASS-EA". You should be able to use the "ASS-EA" as that is setup to save an ~24K image set of files for the TI-99/4A without using cartridge memory. If you see your third file is being saved as more than 8100 bytes, then you are getting close to the cutoff boundary. On the ZIP file for the AfterHours BBS, you would only want the files in the Source Code directory to be copied to a DSK image file. Then, MAME should reference that DSK image file, and then copy those files to a new directory on the hard drive image. The files in the source code directory already have TIFILES headers on them, so I am not sure how a program like TIDIR will handle copying those to a DSK image. My only concern here is that they do not get an extra TIFILES header when you copy them to a DSK image. The code that is there has the new user signup issue when it checks for new messages. That is just a matter of commenting out a couple of lines that I can post a note on how/where to do it. If you are running my hard drive image, you should be able to type MW to get My-Word, the 80 column editor. Typing GPL, will get you to the TI-99/4A what we call GPL mode of things. There are a number of programs in the E:\MDOS1. directory that should be on the drive. And, if you want, there is no reason you couldn't mount my Bootdisk1.hd image as a second hard drive image, and copy only the files you want from it to your primary image Michael helped you setup. I am sure my AUTOEXEC file has more involved that the base case setup you are using now. 1 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4543974 Share on other sites More sharing options...
+arcadeshopper Posted May 22, 2020 Share Posted May 22, 2020 ok after talking to Matt he says "He shouldn't have close the server socket on every 'connection'... he was doing that as part of diagnosing why he wasn't getting any incoming connections after his PI gave up on network" this is regarding the 'false login' after you disconnect from the BBS it thinks a new connection is there and trys to login.. in the logs i see: accepting... 2020-05-22 10:47:06,142 TiSocket : INFO accept conn: <socket._socketobject object at 0x76085960> 2020-05-22 10:47:06,142 TiSocket : INFO connection socket given handleId false "bad connection": 2020-05-22 10:48:17,251 TiSocket : INFO failed to bind socket: 0 Traceback (most recent call last): File "/home/tipi/tipi/services/TiSocket.py", line 177, in handleBind sock.bind(server) File "/usr/lib/python2.7/socket.py", line 228, in meth return getattr(self._sock,name)(*args) error: [Errno 98] Address already in use 2020-05-22 10:48:17,252 TiSocket : INFO closing socket 2020-05-22 10:48:17,257 TiSocket : INFO bind socket(0) *:9918 2020-05-22 10:48:17,257 TiSocket : INFO bind socket(0) *:9918 2020-05-22 10:48:17,258 TiSocket : INFO failed to bind socket: 0 Traceback (most recent call last): File "/home/tipi/tipi/services/TiSocket.py", line 177, in handleBind sock.bind(server) File "/usr/lib/python2.7/socket.py", line 228, in meth return getattr(self._sock,name)(*args) error: [Errno 98] Address already in use 2020-05-22 10:48:17,259 TiSocket : INFO closing socket 2020-05-22 10:48:21,247 TiSocket : INFO handleAccept 2020-05-22 10:48:21,248 TiSocket : ERROR no socket bound with id: 0 2020-05-22 10:48:21,256 ClockFile : INFO clock mode:corcomp 2020-05-22 10:48:21,276 ClockFile : INFO close special? PI.CLOCK 2020-05-22 10:48:21,314 TiSocket : INFO No socket open for handleId 255 2020-05-22 10:48:21,317 TiSocket : INFO No socket open for handleId 255 Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4544115 Share on other sites More sharing options...
+9640News Posted May 23, 2020 Author Share Posted May 23, 2020 I just checked, my MyTerm TIPI program does a clean exit without the BBS trying to log back in with the existing code. When a user logs out, I do some cleanup and CLOSE the socket. I then do a short delay loop, write some stuff to the screen, and then drop back to near the beginning of the program at MSAT3. Is the issue because I initiated a socket CLOSE command to break the connection? Should I have used an UNBIND instead? I'm trying to follow what the log is doing versus the code and what is suggested in the above post. I had to add some LIMI 2 instructions in there as between the interrupt clock and some of the video routines, there was an issue if I didn't have them there. MSAT3 LI R1,8 MSAT1 LI R0,>FFFF MSAT2 DEC R0 JNE MSAT2 DEC R1 JNE MSAT1 CLR @REBNOW BLWP @SERVU UNBIND THE SERVER LI R1,TIPIUNBIND BL @UPDATESTATUS LI R1,8 MSQT1 LI R0,>FFFF MSQT2 DEC R0 JNE MSQT2 DEC R1 JNE MSQT1 CLR @REBNOW Clear reboot flag BLWP @SERVB BIND SERVER ON INTERFACE AND PORT ADDRESS MOV R0,R0 JEQ MSET2C LI R1,TIPIBIND BL @UPDATESTATUS **************************************** LI R1,TIPICLOCK BL @UPDATESTATUS MSET3 BLWP @SERVB Bind server again MOV R0,R0 JEQ MSET3 LI R1,TIPIBIND BL @UPDATESTATUS LI R1,5 MSET7A LI R2,>FFFF MSET6A DEC R2 JNE MSET6A DEC R1 JNE MSET7A CLR @REBNOW CLR @NOWAIT This clears a flag so the interrupt timer doesn't process a program reset. CLR R0 LIMI 2 BLWP @SERVA LIMI 2 MOV R0,R0 JNE MSET3A LI R1,TESTKEYS BL @UPDATESTATUS CLR R0 CLR R1 MOVB R1,@KEYVAL BLWP @KSCAN LIMI 2 4.26.2020 MOVB @KEYVAL,R1 CI R1,'L'*256 JEQ MSET4A CI R1,'l'*256 JEQ MSET4A CI R1,'G'*256 JEQ EXITME CI R1,'g'*256 JEQ EXITME JMP MSET3 MSET4A LIMI 2 LI R1,TESTKEYS BL @UPDATESTATUS JMP MSET4AA EXITME BLWP @0 MSET3A LI R1,TIPIACCEPT BL @UPDATESTATUS Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4544488 Share on other sites More sharing options...
+jedimatt42 Posted May 23, 2020 Share Posted May 23, 2020 I provided some TidBit TI Extended BASIC code... From the assembly above, I can't tell what happens after the first bind attempt... my best guess is you are binding when you have already bound... which would mean the log is telling the truth... Are you sure the false connections aren't people queued up to connect? Several connections can be established, waiting for an accept to unblock them. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4544615 Share on other sites More sharing options...
+arcadeshopper Posted May 23, 2020 Share Posted May 23, 2020 I provided some TidBit TI Extended BASIC code... From the assembly above, I can't tell what happens after the first bind attempt... my best guess is you are binding when you have already bound... which would mean the log is telling the truth... Are you sure the false connections aren't people queued up to connect? Several connections can be established, waiting for an accept to unblock them. At least in my testing it's just me coming in from the BBS dialout so not multi connectionSent from my LM-G820 using Tapatalk Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4545055 Share on other sites More sharing options...
+9640News Posted May 23, 2020 Author Share Posted May 23, 2020 (edited) it is so repeatable with with Windows Telnet, it would not be multi connection unless there was something unique about Windows. It doesn't happen from my Geneve when I use MyTerm to connect which is leaving me a bit confused. I haven't tested Matt's telnet client, but I believe both Greg and Wolfgang report the problem with it. It has me a bit puzzled. I extended the delay after the CLOSE connection, but no luck there. I may look at extending the time between the two BIND's or perhaps jumping over the second BIND to see what happens before I go into the loop. Beery Edited May 23, 2020 by BeeryMiller Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4545109 Share on other sites More sharing options...
+jedimatt42 Posted May 23, 2020 Share Posted May 23, 2020 14 minutes ago, BeeryMiller said: it is so repeatable with with Windows Telnet, it would not be multi connection unless there was something unique about Windows. It doesn't happen from my Geneve when I use MyTerm to connect which is leaving me a bit confused. I haven't tested Matt's telnet client, but I believe both Greg and Wolfgang report the problem with it. It has me a bit puzzled. I extended the delay after the CLOSE connection, but no luck there. I may look at extending the time between the two BIND's or perhaps jumping over the second BIND to see what happens before I go into the loop. Beery You should not do a second bind unless you know the first one has failed and is closed. Connection hangups from the outside world do not require a new bind... the server socket is capable of handling multiple accepts. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4545124 Share on other sites More sharing options...
+jedimatt42 Posted May 23, 2020 Share Posted May 23, 2020 https://github.com/jedimatt42/tipi/wiki/PI.TCP BEGIN: ON ERROR BINDERR OPEN #1:"PI.TCP=*:8080.BIND" PRINT "Bound server port 8080" POLCON: ON ERROR SOCERR INPUT #1:HANDLE IF HANDLE=255 THEN ACCERR IF HANDLE<>0 THEN GETCON CALL SOUND(1000,40000,30) GOTO POLCON GETCON: OPEN #2:"PI.TCP=*:8080."&STR$(HANDLE) PRINT #2:"Hello, I am a TI-99/4A"&CHR$(13)&CHR$(10) PRINT #2:"Who are you? " GETNAME: LINPUT #2:LINE$ IF LINE$="" THEN GETNAME PRINT "Login from: "&LINE$ PRINT #2:"Hello "&LINE$&CHR$(13)&CHR$(10) CLOSE #2 GOTO POLCON ACCERR: PRINT "Accept Error" SOCERR: PRINT "Closing port" ON ERROR SOCE2 CLOSE #1 SOCE2: CALL SOUND(1000,40000,30) GOTO BEGIN BINDERR: CALL SOUND(3000,40000,30) GOTO BEGIN You can see in GETNAME, we have a live connection, then we close connection, which is what you should do when the user tells you to hangup, or you detect that they have been idle too long... It then goes to POLCON, which polls for a connection... by doing an accept... ( in the basic interface, reading from the server socket performs accept and gives you a incoming client connection... If the accept fails 255, then the server socket is toast, and we jump down to ACCERR ( accept error ) which closes the server socket.. then waits a second, and goes back up to BEGIN BEGIN binds the server socket and starts the POLCON over again. When I run this, on the PI log side, you'll see that rebinding often fails... but it will then succeed... if it fails, this code goes to BINDERR, which waits 3 seconds before trying to bind again. Quote Link to comment https://forums.atariage.com/topic/300715-after-hours-bbs-program/page/4/#findComment-4545129 Share on other sites More sharing options...
