+InsaneMultitasker Posted June 12, 2020 Share Posted June 12, 2020 3 hours ago, BeeryMiller said: That's the information I was looking for. I did not know it was documented on Ninerpedia. Together with the ninerpedia info @mizapf linked you to, review the Additional Info Block. The file transfer routines will be coded to copy bytes between the TIFILES header record and the AIB during level 2 IO. The last 4 bytes of the AIB are extensions used by the hard drive devices for larger files/record sizes. I don't believe that any terminal programs transfer these last 4 bytes, with possible exception of PORT and MyTerm. Fred's site is a great reference beyond the earlier TI and Myarc docs, as @jedimatt42 reminded me not too long ago. http://www.ti99-geek.nl/ [documentation->level 2 -> additional info] 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 13, 2020 Author Share Posted June 13, 2020 Whew, I got the Excel tool to properly write a TIFILES header and a DV80 file out properly for 40, 64, and 80 column screen displays. Major accomplishment for the day. I also got all the files renamed to remove the "." extension, so that will not be an issue either. Next step is to break things down into the categories Wolfgang specified, then lay out created filenames to that organization. Time for dinner now. Beery 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 16, 2020 Author Share Posted June 16, 2020 Wolfgang and/or Greg, I had to go back and do some editing on the spreadsheet as I discovered an issue with some longer files. Then, got it prepared for distribution to others. I've got an Excel spreadsheet that creates the files to be used for the next upgrade of AfterHours BBS. It will provide 2800 files for downloading capability from a master and submenu system. I've got the spreadsheet broken down into 71 categories according to Wolfgang's menu layout. The spreadsheet generates TIFILES formatted DIS/VAR 80 files for 40, 64, and 80 column viewing with the future upgrade to AfterHours. Only about half the file categories have been populated, and some of the files in some of the categories could be copied and pasted into the other categories to clean it up a bit. If someone wants to clean it up a bit before, that would be great. If someone adds files (character length 13 max), then I would suggest keeping a separated file addition listing directory so we can all benefit. Anyways, this is the first part with the included files. See the txt file in the zip folder. Beery FileCreator1.zip 2 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 17, 2020 Share Posted June 17, 2020 On 6/16/2020 at 4:00 AM, BeeryMiller said: Only about half the file categories have been populated, and some of the files in some of the categories could be copied and pasted into the other categories to clean it up a bit. If someone wants to clean it up a bit before, that would be great. Hi Beery, I will clean up the complete file library, but I need a few day's to do this, I think. I will also add some more files (<10) to the library with actual versions of programs. For this I will provide an extra list. The DV80 file creation works very well, you had a very good idea to use Excel for this. Thank you. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 17, 2020 Author Share Posted June 17, 2020 2 hours ago, wolhess said: Hi Beery, I will clean up the complete file library, but I need a few day's to do this, I think. I will also add some more files (<10) to the library with actual versions of programs. For this I will provide an extra list. The DV80 file creation works very well, you had a very good idea to use Excel for this. Thank you. Thanks, no problem on the time. Yeah, the Excel tool is quite useful. I had originally hoped I would be able to just write out normal Windows .TXT files and let TIPI do the work, but the end of line character handling gave me problems which would be an issue then should someone want to edit the files in TI-Writer. So, now that the files are written out with a TIFILES header, all is well. Because I did write the files out with a TIFILES header, I took the "easy" route that for each file/description written out, it consumes 1 sector. I did not do a Description length test for the file description, but I would limit the description to no more than about 130 characters. Everything I have there now is 80 characters or less. I pad each sector with the bytes >FF, and fill with >00 to the end of sector. TI-Writer and TIDIR have no issues with the extra padding, and it just makes things simpler to code in Excel. I would have liked to have had something in a TI System, however, the number of files, name sorting, category areas, and the shear number of files needed would take forever to process on a TI or Geneve. As it is, with my Windows system, I am going to estimate it takes about 2 minutes to process the files. Beery 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 17, 2020 Share Posted June 17, 2020 Your Excel tool is working with file names of up to 12 character, but the TI will accept only 10 characters for a file Name. So I have to cut some file names to the proper length. Maybe I will use onle xxx-A so all info before is save. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 17, 2020 Author Share Posted June 17, 2020 1 hour ago, wolhess said: Your Excel tool is working with file names of up to 12 character, but the TI will accept only 10 characters for a file Name. So I have to cut some file names to the proper length. Maybe I will use onle xxx-A so all info before is save. Yes, the TI can only accept 10 character filenames, but that does not matter on the PI. That only matters on the TI and the user specifies the filename when he does a file transfer and save. You will not need to rename any files. Many of those filenames were actually 12 character length filenames with the 8.3 MS-DOS naming I had on another BBS back in the 90's. What I will need to do in the two XMODEM source files is expand the filename length in the PAB to accommodate longer filenames for user entry. That's it. Beery 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 18, 2020 Author Share Posted June 18, 2020 15 hours ago, wolhess said: Hi Beery, I will clean up the complete file library, but I need a few day's to do this, I think. Just realized the Sound and Picture folder categories doesn't match up correctly as wrong files are in the wrong areas there (CAT511 and CAT25). There may be some other issues. Looks like I typed the wrong category name. Beery 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 18, 2020 Share Posted June 18, 2020 No Problem, I saw this and some others. I will make the corrections. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 18, 2020 Author Share Posted June 18, 2020 2 hours ago, wolhess said: No Problem, I saw this and some others. I will make the corrections. Not sure if I mentioned it in the zip file folder notes, but there is no problem if a filename/description is listed in multiple categories if it would be appropriate to be in more than one file area. Beery Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 18, 2020 Share Posted June 18, 2020 2 minutes ago, BeeryMiller said: Not sure if I mentioned it in the zip file folder notes, but there is no problem if a filename/description is listed in multiple categories if it would be appropriate to be in more than one file area. Yes, you mentioned it in the FileCreator text file. Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 18, 2020 Share Posted June 18, 2020 @BeeryMillerHi, it was nice to have a sysop Chat in the BBS with you. The sysop break in Routine is in the file BBSSUBS, but the Problem Maybe should solve on another place. In BBSSUBS on line 392 there is a remark about giving the user credit for time spent with sysop. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 18, 2020 Author Share Posted June 18, 2020 (edited) Thanks Wolfgang. I'll get a timer reset routine added into the chat routine so we do not time out after 3 minutes. The piece of code needed is a CLR @NOWAIT. Just need to find the right line where we are typing back and forth to add it. Beery Edited June 18, 2020 by BeeryMiller 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 20, 2020 Author Share Posted June 20, 2020 Got the chat timeout fixed. I added a CLR @NOWAIT just after the following line: SYSNT1 SETO @RSINWS+10 in the BBSSUBS file, around line 368. Beery 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 20, 2020 Author Share Posted June 20, 2020 Got a question for our more tech savvy individuals. I just upgraded my AT&T DSL to AT&T Wireless to get better reliability and better service. AT&T has disabled port forwarding on their cellular network. Does anyone know how to get around this complication? AT&T told me if I wanted port forwarding, I needed to go back to DSL. Right now, that has disabled access to my AfterHours BBS from external access as well as my other BBS connected to fidonet. Didn't know if there is some kind of service out there that allows me to keep an open port to somewhere else, and then they would stream a connection back to me...…….. Beery Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 22, 2020 Author Share Posted June 22, 2020 Wolfgang, I think I have the code working properly now with all the submenus for the data library. Still need to do some testing, but I think it looks good. No pressure on your spreadsheet work as I want to do some testing with all the menu options before I release the code. Menus are recursive so they back up one level as one hits the <ENTER> key until they eventually back up all the way to the main menu. Only took about 1054 bytes at present with much of that the data statements for all the menu structures and filenames for the 40 column files. Code adjusts the pab name for the 64 and 80 column files. Anyways, got that done, as well as the Chat timeout issue resolved. Beery 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 22, 2020 Share Posted June 22, 2020 Most of the excel work is done, I think during this week I will finish it. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 22, 2020 Author Share Posted June 22, 2020 7 hours ago, wolhess said: Most of the excel work is done, I think during this week I will finish it. Sounds good. I discovered I need to change some code on how the file terminates after reaching the end. There appears to be a couple of control character bytes I am missing for AfterHours to terminate the file. That will not affect your work. Beery 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 24, 2020 Share Posted June 24, 2020 @BeeryMiller I finished the work on the Excel sheet today. BBS.zip "TableNames": - The CAT02 has the same text file names as CAT11, I used CAT11! - CAT09 is missing in TableNames! - I have renamed the 2nd submenu from "Disk Utilities" to "Tools" in CAT44 and CAT45! All files are sorted into categories 1 to 73. There are 7 new files: Archiv Byte Description Category MXT-ARK 98688 Actual Mass Transfer Program for TIPI CAT01 ARTIST-ARC 60800 TI-Artist, INSCEBOT Program for TIPI and TIPI mouse CAT11 ROS842-ARK 69248 ROS 8.42C vom 14.03.2020 CAT03 STRAT-ARK 31104 XB Game Stratego compiled with XBGDP CAT20 TIPIT-ARK 52864 Tipi Tools Config, Map, Browser CAT40,CAT46 TBOXNE-ARK 1664 TBOX99 Newsletter in English and in German CAT70 DIR-LIST 6273 Directory list of all files CAT71 "New Files.xlsx" file with three tables: New Files This is the New Files list, same as above. File List This is a list of all downloadable files with category and description Manu Text This is a alphabetic sorted list of the download file menues like the table "Table The Tool creates all the Textfiles correct. Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 24, 2020 Author Share Posted June 24, 2020 Thanks. I should have some time tonight to work on it. I should be able to get a release out sometime this Friday evening or Saturday. Beery 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 27, 2020 Author Share Posted June 27, 2020 OK, got the spreadsheet tool to use everything as 10 character filenames. Took about 30 minutes to write the code to rename the files, do a search and replace across the whole workbook, and then confirm there were no hiccups with the file naming. I will do some testing tomorrow as time permits, and hopefully have something available by tomorrow evening. Beery 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 28, 2020 Author Share Posted June 28, 2020 OK, here is the update to AfterHours BBS. Files in the DL directory in this archive should be copied to your existing DL folder. Any existing files in this directory will need to be added to the new setup using the FileCreator1.xlsm Excel utility. The Excel utility will write out files to the TIPI "BBS" folder with a TIFILES header in DIS/VAR 80 format. A new directory, BBS, has been created that contains all the menus in 40, 64, and 80 column format. The chat/page timeout issue is fixed as well. Now, at any file listing area, one can drop into the File transfer menu. This update includes a 2800+ file download setup ready to go. Let me know if you see any issues. My testing thus far has not shown an issue. Beery 20200627 AfterhHoursBBS.zip 1 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 29, 2020 Author Share Posted June 29, 2020 Greg, I was on The Keep last week, and was unable to find how to get to AfterHours. Can you post that information again? Beery Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 29, 2020 Share Posted June 29, 2020 Greg, I was on The Keep last week, and was unable to find how to get to AfterHours. Can you post that information again? BeeryLoginType "/go dialout" hit enterThen "d 19" enterSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 29, 2020 Author Share Posted June 29, 2020 Greg, Thanks for the info. You can remove my BBS from the list of BBS's users can connect to. After upgrading to AT&T wireless internet, I no longer can port forward to direct users to the two BBS's I have. It's a disappointment for sure. I still get my fidonet mail, etc. as I can poll other systems, just not receive inbound connections. I've got a couple of ideas yet for AfterHours. I see you are still on a much earlier release. I wanted to do a string search within a D/V 80 file for finding a file associated with a file description, however, I am beginning to think that may be more work than originally anticipated. The other is trying to interface with fidonet, however I have not found the utilities I need on the Windows side of things I need. I was hoping to be able to export individual messages by message number. At this point, I would be just happy to be able to export a message as a text file, but I can not even find anything yet that even allows that. Beery Quote Link to comment Share on other sites More sharing options...
